Showing results for tags 'boot drain tube'.
More search options
    • VWROC Rewards
    • Member's Rides
  • Sponsors
    • Adrian Flux
    • Safe And Sound Vehicle Systems
    • Regal Autosport
  1. Folks, as the summer rains continue, it’s worth a quick check of the boot badge drain tube. I was surprised to see the end of mine had perished and almost detached completely. This is going to let water get inside the boot lid & needs a replacement (sub £6). I’m told this is a common problem, but extended warranty won’t cover it, at least in my case when I enquired. Overjoyed to learn that the boot lock/latch needs to come off to attach the new tube.... Check your grommets!
