Current Donation Goals
Recently Browsing 0 members
Similar Content
By Skip
All,
I recently had the clutch replaced on my VW Golf R 2015, Xtreme Clutch, I have done just over 1000kms and it has started slipping again.
The oil indicator light also came on at the same time. There are no visible sign of a leak.
Are these related?
By Bilegsaikhan
i got Volkswagen golf variant 2014
dashboard shows "Transmission faulty! Service vehicle." then engine not start.
my local service guy's computer shows "P175E00 - Clutch 1 closes unintentionally", "P060700 - Control module Performance"
i think before i get this error my car goes normally there is no any symptom for any clutch or transmission issue.
what should i do now. can you guys help me? pls. thanks
pls find pictures in attachment.
Engine - TSI 1.4
Transmission & Drivetrain
Drivetrain: Two Wheel Drive Type of Two Wheel Drive: FWD Transmission : Automatic Manual Type of Automatic: Dual-clutch Number of Gears: 7
Engine Specification
Power (kW): 103 kW Horsepower: 140 hp Horsepower: 138 bhp Rev. at Max Power: 4500 – 6000 Torque: 250 Torque (lb-ft): 184 Rev. at Max Torque: 1500 – 3500
By starrdogg
I've have a (2012 Volkswagen Golf R 4 Cylinders F 2.0L MFI Turbo DOHC)(MK6 Golf R) that I've been having some serious clutch issues with. It's Stage 2+ with a turbo-back exhaust, upgraded Powercore intake, Haldex controller, and custom tune (350hp). With this much power, the original owner put in a FX400 8-puck ceramic clutch kit and lightweight flywheel (single mass).
I had the misfortune of the slave cylinder failing 7 months ago, which got fluid on the clutch disk and caused it to slip. After contacting CM and following their guidelines, the clutch was cleaned and the flywheel was resurfaced. I prayed this was the end of the clutch issues (since clutch slips in VWs are something way too common for me ) but a week ago I had a slip in 6th, then 5th, and finally 4th.
I've read online that the FX400 only lasts 20k miles on average. I daily my Golf R and seldom get the chance to track it. Though I'm sure this is one of the most common threads seen on this forum, I wanted to ask for suggestions on a new clutch kit and flywheel. I want to have something that's reliable and good for a daily driver while still being fun and performance-based. I'd say I'm on a tight budget, but I'm willing to put out the extra penny for something that is quality and won't fail.
Thanks for the help guys
By Marty77
Hi lads, seen a post a while back with regards to the RTS and didn't look like anyone had tried one.
I currently have the Sachs sintered and was looking for anyone with first hand knowledge if these two are any friendlier? Thinking of a swap.
Does the helix judder or squeal and is it as on off as the Sachs?
Anyone with first hand knowledge of both?
Cheers
By tompower87
Hi guys,
New to the forum and I have had my (totaly stock) Golf R for just under a month. Looking at making my first mods. I’m adding a Racingline Filter to the stock filter box and having a Res deleted. I have a Manual so I’m unsure as to what difference it will make to the sound?
My question is, will I see a noticeable difference in the sound of the car? Also will it add a few more pops and bangs? I know the DSG it makes a big difference but not sure what the difference on a manual will be.
Thanks.
