Mk7/7.5 (and also mk8R) - How to fit a replacement footrest
Fitting a replacement footrest
The standard plastic footrest cover is ok but there is a nicer alternative which looks very oem and matches in nicely with the pedals.  Purchased from Aliexpress.  Original link from which I purchased is no longer valid but one the same here.
https://www.aliexpress.com/item/32706138749.html
However I ordered this one for my mk8 and the quality is poorer
But same type available here on eBay and quality is good from feedback from another forum member.  Feedback and link courtesy of @NJS 👍
https://www.ebay.co.uk/itm/RHD-Right-Foot-Rest-Pedal-Steel-Kick-Panel-Stainless-Steel-For-VW-Golf-MK7/402655358851?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Also available here
http://www.superskoda.com/Volkswagen/Golf-VII/VW-Golf-VII-MK7-GTi-designed-footrest-for-RHD-cars-MANUAL-TRANSMISSION
This is suitable for both DSG and Manual cars.  Easy job - takes approx 20 mins.  Requires a T20 Torx bit and a sharp knife/blade.
Quick installation guide below:
OEM footrest cover - locate Torx screw
The screw recess is quite deep so you have to locate the torx screw head by feel with the screwdriver, but easy enough.
Undo Torx screw - T20 screw Torx bit required
Once unscrewed and torx screw set aside, remove the oem footrest by pushing it up towards the bulkhead, tilting it at the same time.  Once removed, note the square holes into which the locating lugs on the new footrest cover will slot into.
Locating holes
OEM locating lugs have a marginally wider slot than those on the aftermarket footrest cover, so a little of the plastic may need shaving off with a sharp knife
OEM slots
Replacement footrest slots - slightly narrower - may need a little slicing off.
Fit new footrest cover - angle it into place and slide it from the top pushing down and to the left at the same time.  Give it a moderate tap from the top and it will slot into place.  Screw Torx screw back into position.  The screw hole on  the new footrest is much shallower than on the oem one.
All done
  • Replies 66
Fitting a replacement footrest    The standard plastic footrest cover is ok but there is a nicer alternative which looks very oem and matches in nicely with the pedals.  Purchased from Aliex
I bought one on the 21st December It arrived 29th December All I can say is Quality oe style part Fitted in less than 5m And fits perfectly No remedial work with a blade either Looks sup
Installed footrest today. Thanks to Booth11 for the "How-to"
Posted Images
  • 1 month later...
  • 2 weeks later...
 Just placed my order  :azn:  How long did it take to turn up? Not bad for $42
Can't remember exactly but approx 2 weeks.  They state 3 weeks but it's usually quicker.  Someone I know has just received theirs and that took 15 days in total. It's worth the wait.  :afro:
  • 2 months later...
Ordered one of these last week as a 'back to work after the holidays treat'  :nerd: !
Will be fitting it this coming weekend so really appreciate stumbling across this 'how to'
Greatly appreciated  :afro:
Looks soooooo much better than the original
It will take you longer to find your tools than to actually fit it :-)
They are not perfect but look  a lot better than the standard offering and definitely a value for money upgrade
J.
  • Booth11 changed the title to Mk7/7.5 (and also mk8R) - How to fit a replacement footrest
