400bhp?
mikie22
 Share
  • 5 years later...
14 minutes ago, Cj7.5r said:
I’ve got a tuner near me that is saying that I can reach over 400bhp with R600, scorpion sports cat + downpipe, res delete and a TT turbo inlet.
Would this be safe to run on my 7.5R without an intercooler?
thank you!
Yes but the inter bigger cooler helps reduce inlet temps as when you do big pulls you’ll get more heat soak.
I spoke to APR when they were here in UK doing testing for European fuel and stage 3 about the positive effects running stage 2 even for fast road use in normal UK weather temps. High heat in summer definitely reduces power as you’ll see big timing swing with high inlet temps.
Turbo will run happy as it requires less boost to achieve target power levels with cooler denser air.
So would you personally go for this without an intercooler? Thank you
I had APR’s FMIC when I went stage 2 in 2017.
I found prior to the install when running APR HO Stage 1 that on track I had big heat soak and drop off in power.
Another good install is fitting a Catch Can . I run Racingline’s item and it works really well at any stage of tune. Much cleaner and safer with all the crud being caught in the can.
thank you!
What about the rest of the parts needed to make it stage2, like charge & throttle pipes or the muffler delete to smooth airflow to the turbo?
Going stg2 is possible on budget but my view is your going to get better results using all the right parts for the job, I'm also a fan of sticking with one brand as all the parts would have been developed to work together,
  • 2 weeks later...
intercooler is not needed for a dyno run to hit 400hp , but if you want it to be consistent its better off having it, and it will help, to give you an example i hve a 7.5r , turbo elbow, intercooler, apr coils, 200cel downpipe, and a simple drop in filter on 97ron fuel got 397bhp , so if your in england you will have the option of 99ron fuel which would easily make over 400bhp on my car,   to be honest if its a daily not tracked i dont think its worth the money, if you hve the above mods and 99 fuel it will make 400bhp
 Share
    • Raised £165
