Lawrie
Dimming DRLs with turn signal (OBD Eleven Coding)
Dimming DRLs with turn signal - Verified working with 2014 - 2017 pre-facelift Rs
1) Go to Central Electronics
2) Select Adaptation
3) Select or search for and select: Leuchte2SL VLB10
4) Choose Lichfunktion G 2 and select: "Blinken links aktiv (beide Phasen)".  The default is "not active"
5) Select Dimmwert GH 2 and set to "25"  The default is "0"
6) Select Dimming Direction GH 2 and change to "minimize".  Default is "maximize".
7) Select the green tick to confirm
8) Go back, search for and select: Leuchte3SL VRB21
9) Select Lichfunktion G 3 and select "Blinken rechts aktiv (beide Phasen)".  The default is "not active"
10) Select Dimmwert GH 3 and set to "25".  The default is "0"
11) Select Dimming Direction GH 3 and change to "minimize".  Default is "maximize".
12) Select the green tick to confirm.
09 central electrics
security access 31347
adaptation
Leuchte2sl > change the following
Lichtfunktion G3 - Blinken Links Hellphase
Lichtfunktion GH3 - Blinken Links Hellphase
Dimming Direction GH3 - minimise
click green tick
Leuchte3sl > change the following
Lichtfunktion G3 - Blinken Rechts Hellphase
Lichtfunktion GH3 - Blinken Rechts Hellphase
click green tick
DRL should now flash alternately with the indicators
Can't get this to work (2015 model).
It used to work, then came back from warranty not working.
All the coding was the same, so I reset lights on factory setting on car. Nothing.
Turned them all back to factory,  reset and nothing as expected.
Turned car off,  reconnected.
Put settings in again, reset lights on car.
Nothing.
Should I be doing the reset or that only for comfort blink?
Anyway the coding still there.
Dave
All aboard the fail wagon!
Works fine in the day :)  The lights are normally on auto, but i have them to activate early and guess last night was a little too dark.  I tried them turned to the other options, but not off :(
Dave
