Comfort Blink Cycle (indicators) (OBDeleven Coding)
ninja_geezer
Comfort Blink Cycle
Select Control unit 09 (Central Electrics)
Security access
Access Code 31347
Adaptation
Comfort Sinyal Sayısı (Cycles)
Value: 1-5 Value 3 (standard - 3x blinking)
Security access
Access Code 31347
Adaptation
  • 1 month later...
This is my version of comfort blink - proven out on MY2014 Golf R.
    Comfort Blink Cycle:
Security access
Access Code 31347
Select Adaptation
Scroll or search for Turn Signal Control - select this option
This opens up a set of options, select the 2nd Komforblinken Blinkzyklen
Input the required number 1 to 5 (default is 3, set mine to 4)
select OK
select Green Tick to confirm.
To fully activate this change you must then do the following:
On the infotainment unit select CAR
go into Set Up, scroll to the bottom and select Factory Settings
Scroll down to Mirrors & Wipers and select this option
This will open a dialog box stating "Reset Mirrors & Wipers setting - are you sure"
Select the RESET option.
This will now enable the value set in the Turn Signal Control option to become 'live'.
Until you Reset the Mirrors & Wipers this value will not be active, even though you have changed it in the Turn Signal Control option.
Please note this method does NOT use up any OBDeleven credits.
Used this in conjunction with dimming the DRL's when applying the indicators, looks pretty cool in my opinion.
Set the DRL's to dim to 25% which is just about perfect.
  • 4 weeks later...
    • Raised £165
