Helix hifi upgrade review
I bought a second hand Golf R last year to find that it came with a Helix soundbox upgrade, six months on I thought I'd review it as I had some issues....
After initially opening the boot floor to see this huge shiny round sub where the spare wheel should be I though woah that looks powerful! However I found the sound overly bassy, boomy and the treble sounded harsh and boosted. I also noticed when turning up the volume (above 50%) that there was noticeable distortion in the tweeters.
first thing I did was replace the tweeters with some decent Focal ones that I knew were good as I'd used them in my old Fiesta ST. Sadly, they sounded incredibly over driven, despite the bass/treble controls being flat on the HU. I had to set the treble to about -6 to compensate. The bass was also way too boomy especially at low volumes. After a few weeks the tweeters blew.
This is prompted me to do some research into what was going on with this system. Turns out the built in amp is actually tiny and only needs a single 20amp fuse which speaks volumes about its power. Supposedly it has 35w per channel RMS which is not a lot but it feels like in reality it's less than that. Furthermore it has built in DSP which hugely oversdrives the tweeters (presumably to compensate for how shoddy the standard ones are). You aren't able to control the level of the sub as it's all pre-set. So little power going to your speakers means you end up straying into massive amount of harmonic distortion quite early into your volume dial and are effective sending square waves to your speakers - ruining them.
The sub speaker box itself is well made, heavy and of a good size. I has 2 fairly meaty looking 6" bass drivers which feel like they go pretty low. But it was certainly not at its best being driven by this pathetic little amp.
To sort this all out I decided to buy a small 5 channel Kenwood amp https://www.caraudiocentre.co.uk/product_m-kenwood-x801-5_p-33144.htm and another set of tweeters. The amp is fully class D so it's small and power efficicient. It sends 50w to 4 speakers and an additional 300w to the sub - much better! It's triplet of 30 amp fuses said a lot about it power output. Also no pesky DSP thinking it knows best, just straight forward amplification with separate controls for sub level and bandpass filters. The amp was small enough to fit under the floor beside the sub so it's a completely stealthy install with no boot space taken up. The amp takes speaker level inputs too so I simply spliced into the cable that was already sitting in the boot feeding the helix amp. All I did was wire up a nice fat power cable to the battery.
The difference is utterly unbelievable! Underlining for me that speakers only sound as good as the amp driving them.  The sound sparkles now and with everything set flat, sounds incredible. The whole system is orders of magnitude louder, cleaner and more effortless, with deeper, tighter bass and no distortion.
If any of you out there are at all feeling a bit dissatisfied with your helix system or have found that your tweeters distort or that you have to make sweeping changes to your eq to compensate for the overly aggressive DSP then I highly recommend simply buying a proper amp like this one, keeping all the speakers (well maybe swapping out the front tweeters as it's pretty cheap and they're the weakest part quality wise!) It's a night and day difference with no sacrificed space or hugely difficult wiring. The sub itself is pretty damn good once your feeding it a healthy amount of power :-)
Nice review :afro:, I have no doubt that will benefit someone, especially as the overlaying theme is portable (the bit I quoted is almost holy scripture in car audio :)).
For me, I usually focus on HU (source) > Amp (if required*) > speakers as a basic formula when approaching older cars for a progressive build, everything else is enhancement after the fact and should be used to compliment your core delivery items. I say older cars as newer ones are usually supplied with decent enough and/or fixed/difficult to change HU's so your focus changes to DSP at HU stage. Especially as a lot of them don't come with outputs needed i.e. sub etc. so a decent DSP can flatten your source signal and provide standard outputs.
*Always for me, but some are happy with just HU level volumes and run a tight budget.
Thanks, yeah I wasn't going for anything expensive / fancy, just good sound on a budget in a way that keeps the car looking stock and to be honest I was a bit blown away by just how much better it was! Especially for an amp so tiny. I remember back in the day Amos were huge in order to get decent power, guess all that has changed with this new generation of class D. I've attached a pic of the little guy squeezing in next to the original helix sub unit.
Totally agree regarding DSP, to me it's simply a clever tool that can be used to enhance or ruin sound depending on how it's implemented. Sadly it's too often the case that manufacturers use DSP to mask weaknesses or to make cheap components appear better than they are, like ramming up the treble signal going to some crappy tweeters or upping the bass at low volumes so it sounds impressive, only to roll it off as soon as you turn it up. I'd rather they stopped using it like some sort of audio photoshop!
Back in the day amps were bloody massive, I remember some of the set ups me and my friends had!
I haven't really looked seriously at car audio for years, how times have changed.
This is the first time I've heard about DSPs, they seem like great pieces of kit for modern car HUs.
Sent from my F8331 using Tapatalk
Hi, do you carry foam in a can now instead of a spare wheel?
I know some cars don't actually come with a spare wheel nowadays.
Cheers.
Yeah that's right, on the other side of the subwoofer is a little foam kit. Hopefully I won't need to use it! Having an actual spare wheel does seem to be getting rarer these days!
Yeah amps have really moved on tech wise since I last dabbled in this, cheaper, more powerful, smaller and with more features! Brilliant 😊
Hi Chunbaouk
Sorry to revive this old thread but I am looking to do exactly the same as you and I would really appreciate some help ...
I am going to buy the same Amp as you, I am just trying to figure out how to wire it in to my car, would you mind giving me an explanation including any additional cables I need to purchase? I do not know much about amps or installation unfortunately, however I would like to think I should manage to do it myself seeing as I installed the Helix Myself.
Also should this amp REPLACE the amp on the subwoofer so should I be removing the small black amp on the bottom of the helix, or should it be working in combination with the Kenwood amp?
Will I need to wire speaker cables etc back through the car or is it just the power cable I need?
Thanks!
  • Similar Content
    • By wolverine
      So, buy a car for driveability or for interior and looks...who wins?  Thoughts?
    • By Marty77
      Hi lads, seen a post a while back with regards to the RTS and didn't look like anyone had tried one.
      I currently have the Sachs sintered and was looking for anyone with first hand knowledge if these two are any friendlier? Thinking of a swap.
      Does the helix judder or squeal and is it as on off as the Sachs?
      Anyone with first hand knowledge of both?
      Cheers
    • By ellixtt
      Been pondering a clutch upgrade for some time now because I want to go to Stage 1 but been put off by the "judder" comments coming from some Sachs reviews.
      Has anyone got the Helix Organic Clutch fitted? If so what it like as a daily driver?? I can only find 2 comments which were positive but not much else.
      I understand DSG's are better for mapping but I really enjoy my manual therefore will be keeping for some years!
      Product link
      https://www.akstuning.co.uk/clutches/373-helix-orgnic-clutch-kit-for-vag-tfsi-engine.html#/with_or_without_fywheel-flywheel_included/select_drive_plate_type-organic_drive_plate
    • By basharR
      Volkswagen Golf R MK7 Test Drive & Review - A Great Hot Hatch!
      The new Volkswagen Golf R was a very good ride and I really enjoy it... It is very quick and exciting hot hatch.
      Enjoy and please don't forget to subscribe to my channel
      https://youtu.be/5kcxgeDm7rg
    • By ColinC2
      So since Rebecca is giving me a hard time for not producing a review yet I thought I had better respond. I may not be able to match her skills as a wordsmith but will try! Oh and don’t forget this is all my opinions and is not my intent to offend in any way. I might refer to the RS3 a bit as that is my personal reference point and to some a direct competitor … although others may say it’s the S3.
      C7 VWR – 0 to 400 Miles Review
      Before driving
      So when I first saw the car in the showroom after it had been detailed (Thanks yet again to [email protected] http://www.firstchoicedetailing.co.uk/services/ i)I was finally sure that I chosen the right colour. As I had predicted the silver shows the subtle lines of the Golf R  and that’s aligned with the subtle look I am after. The Golf R is a slightly more “delicate†look than my outgoing 8P RS3 so the softer colours suit it. A small detail I know but the look is certainly helped by the smooth number plates - Richard Steel @ Breeze VW must have got pretty tired of my constant reminder to ensure that they were not drilled!
      Partly due to a 24-hour test drive, partly due to VAG group standardisations, and partly due to all the stuff I have read here the interior of the car held no real secrets for me. The day before delivery when I took the showroom pictures I paired my phone and streamed some music. I like the R interior – it feels more compact and to hand than the RS3.
      The seats were always going to be a concern for me. Coming from the supportive buckets of the RS3, and before that the hugging and infinitely adjustable sports seats of the C63, I thought that I would end up sourcing some form of bucket seats in the future. More on that later.
      There is something really quite special about just sitting in a brand new car showing just 7 miles on the odometer. The last new car I had was my 135i Coupe and somehow I don’t remember feeling so special as I did absorbing the experience in a deserted showroom on a wet Sunday morning. Perhaps it is down to the fact that, in my opinion, the Golf R interior is actually a nice place to be!
      D Day
      Delivery day was wet and drab but that did not detract from my upbeat mood. Its only a Golf some may say – but its my Golf with only 7 miles on the clock. And although I had only spent 2 hours taking pictures and drinking the dealers coffee the previous day it is a special feeling having the expectation of driving a brand new car out of the showroom.
      Handover (a very nice bottle of Lanson Black label) was brief although that was my choice. Having driven a Golf R a couple of times including a 24 hour test drive it all seemed quite familiar. And the intricacies of the Tech would come with time. So plug in the iPhone – enable Apple Play and away I went. And it all felt so .. right! First journey was only a few miles to body shop to establish cost of Oettinger spray and fit and then back to working for the rest of the day. They say first impressions and all that – my abiding memory of Day One is a feeling. A feeling that the Golf R feels so planted and yet also dynamic – perhaps even nimble. It feels just so much lighter than the RS3 and yet the difference in unladen weight is only 80kg (1495 vs. 1575)
      Day Two – to now
      A 170 mile round trip to Guildford on Day 2 to have the forward facing camera wired in . First real opportunity to get above 4000 rpm , albeit only in bursts. I am “running in “ my car ,although I know I probably don’t need to , by staying away from the red line for the first 1000 miles and varying the speed and revs perhaps more than normal . Drive out in “Normal†with some miles in “Race†and amazed at the difference between the two – much more than I expected. And just for comparison back in Eco mode with ACC set between 65 and 70. The demo car I drove for a day was on 18†wheels and no DCC so I had specified 19†Pretorias and DCC blind really , trusting the opinions of others and my gut feeling. Definitely one of my better decisions – the Golf R IS those 2 cars that I expected it to be.  Perhaps 3… It is raw and “drive me!†in Race , its fast and controlled in “Normal†, and its still fast but soothing in Eco.  And petrol consumption for the round trip , that doesn’t really bother someone who does as few miles as I do but is interesting nonetheless , was 27.9 on the way (OK … couple of bursts on an empty A3 and some low gear stuff through the Hinehead Tunnel) and an amazing 36 on the way back.
      On the return trip got to mess around with some of the tech and I have to say I am more than happy with it – I know others have had issues but touch wood I haven’t. DAB is clear and I have station logos , Music either streamed through BT when phone in my pocket or through Apple Play when its plugged in is superb. My music taste is pretty eclectic with a fair R&B / HipHop bias , I listen to a lot of Podcasts on long journeys (together with TalkSport) and everything I listened to sounded great to me. The sound in the car even in Race is fine for me although I do suspect now (a week or so later) that a sports exhaust may be under consideration. But more on that later… One of my concerns were the seats not being supportive enough compared to the superb racing buckets in the RS3 but so far  , and I have done a round trip to SW London this week , is that they are OK . Perhaps if I did 20k miles a year I might have to have a bit more lower back support.
      On the way back from London on Monday evening got to drive the car in the dark and the interior is a pretty cosy place to be. Dash Lighting is nice as is the foot wells  and the blue needles not as in your face as I remember the 6R I test drove before the RS3.
      I reckon that the ride in race mode (doing a very subjective speed bump comparison in the roads approaching mine) is very similar to the RS3 but just a tad softer – which is fine by me. In fact in race mode it is all very similar to the RS3 – perhaps with the dial @9  instead of @10. I have now settled on an Individual setting that I am happy with to use most of the time, for now anyway, DCC - Normal; Steering - Normal; Drive - Sport; ACC - Normal; Dynamic Cornering Lights - Sport; Air Conditioning – Eco (Although might change this when weather is warmer); Interior Engine Sound – Sport.
      Overall – so Far (of course)
      It’s not taken long to bond with this car. It’s definitely a bit more me than the very capable RS3 8P that I struggled to really bond with (Perhaps the Milltek and cat delete were a step too far as the drone was starting to get on my nerves and I would probably have looked for a less “bassy†sound exhaust if I had kept it)
      I like it – I like the look , I like the way it drives, I like the ride, I like the feel, I like the sound (manufactured though it may be). All very subjective of course but that’s a car enthusiasts prerogative!
      Did I do the right thing not waiting till March 1st? Too bloody right !!
      Random observations ,perhaps some minor dislikes, some questions?
      ·       I thought I wouldn’t like stop/start but am used it now. Same with AutoHold which is a great feature – although probably more beneficial to anyone following me! But how come stop/start doesn’t seem to engage in Eco? Is it saying its more efficient to keep the engine running than stop and start it ? Or is it just me ?
      ·       I like the dynamic cornering lights. I didn’t even realise that they were standard. They work really well
      ·       I have pictures on my contacts on my phone but they don’t import into the Phone book ? Although you get pictures if use the phone through Apple Play
      ·       The ride height definitely needs to drop. Not much (perhaps 20-25mm). But I don’t want either warranty issues or to ruin the ride as it is just right (in all modes)
      ·       The piano black trim, in fact most of the dash, is a dust trap. Perhaps Ms Booth has a solution ??
      ·       Perhaps more noticeable on silver is the way that the dirty air flows and sticks to the car. Its as though someone forgot to add tiny deflectors inside the wheel arch to push passing air a few nanometres away from the body. (I took some pictures but can't host them at the moment as Photobucket is down for maintenance)
      ·       How come VW don’t make a nice Key Fob holder for the key? With keyless (which I also really like because its cool to lock and unlock with just your hand and have a button to press to start the car!!) the key spends a lot more time in my pocket and hence I reckon will be more prone to being scratched. I have ordered my second one from China off EBay – the first one I got was pants but for £8 I can take the hit and use it to store the spare key!
      ·       I am already noticing that rust coloured dust is accumulating in the vents in the rear discs. This is the same as happened on the RS3. Needs to be monitored as does the state of the hub carriers although I do have a plan to treat those pretty soon.
      ·       Is it me or is the steering wheel perhaps an inch too big in diameter? I am still fiddling with my ideal driving position so perhaps its that.
      ·       The paddles are not as prominent as those in the RS3 but OK in the short term. My hands seem to be closer to quarter to 3 than I remember and so the paddles operated by ring/small fingers. The ST2 would work better , and look better, I think – I cant decide on the colour!! I know that black would blend in with the piano black trim but had a thought that there is also some nice silver accents around and that silver would look better … Have to decide pretty soon as they are in Februarys Car Spend Budget so need to get them ordered!
      Well that’s about it… thanks for listening
