Russellj
Suspension 'jiggle' after pothole encounter?
I hit a pothole with the nearside front wheel of my 16 plate estate recently and am now musing over a perception of a possible change in driving characteristics since then.
The car still steers and brakes fine, and there’s no steering wheel shake (as I’ve had with previous cars when a wheel needs balancing).  And on (rare perfectly) smooth motorway surfaces, the car is fine and feels as smooth as it used to (e.g. feels nicely damped over longer undulations).
However, what I’m noticing is that when driving over the usual surface imperfections (expansion gaps in motorway sections, ripples, bumps, etc) is that the car feels more "jiggly" or unsettled.  It feels like the car takes a bit longer to recover from encountering minor imperfections than it used to.  The closest analogy is that when you poke a jelly it wobbles, and continues to, for a while afterwards.  It feels like the car is no longer damping these wobbles after hitting a bump as quickly as it used to (or maybe it’s started to wobble when it didn’t used to?).  Ultimately, the car just feel more "fidgety" and unsettled than it used to when driving over less than perfect surfaces.
It’s not a major thing.  The car doesn’t feel unsafe.  And it may just entirely be in my imagination!!
The car has adaptive suspension (DCC).  I pretty much leave it in Comfort mode most of the time, and haven’t changed mode or the roads I’m driving recently, so that won’t be the cause.
The car has been for a 20k service since the pothole and I asked them to take a look.  They couldn't see anything untoward and the guy who collected/returned the vehicle (20 min drive each way) didn't think there was anything unusual. (Suspect he was too busy enjoying the drive 😀).
Maybe it's just one of those things that once you notice it (or *think* you notice it) you can't stop picking up on?
Alternatively, are there any suspension components that might be out after a pothole encounter?  I've only done approx 1,000 miles since, so there's not been enough mileage to show up different tyre wear pattern (e.g. if alignment was out).  I did take it to a tyre place that does 4 wheel alignment, but after asking some questions re: symptoms, the guy didn't want to take my money, and told me not to worry.
To make it worse, I went for a drive in my neighbour's M135i a couple of days ago and it seemed as smooth as mine over good surfaces, but without the jiggle over imperfections as I'm reporting here 😒
Would be grateful for any thoughts or previous experience on the above (besides "just ignore it") 😀
Thanks!
Hallo. Didn't find anything. But still have the same perception. Friend of mine who borrowed the car reports it being most apparent around 80-85mph (wouldn't be me as I never exceed 70) 😀
Cars now on 37k miles and due 4 new tyres very shortly, so am wondering/hoping that maybe balance may be out and problem goes away. Tyres haven't worn oddly so it shouldn't be tracking.
8 hours ago, Russellj said:
Hallo. Didn't find anything. But still have the same perception. Friend of mine who borrowed the car reports it being most apparent around 80-85mph (wouldn't be me as I never exceed 70) 1f600.png
Hi, thanks for that. Maybe it is just a perception thing then. But sounds like not. I guess it could be a bit of wear on the shocks?
The car has been for a 20k service since the pothole and I asked them to take a look.  They couldn't see anything untoward and the guy who collected/returned the vehicle (20 min drive each way) didn't think there was anything unusual. (Suspect he was too busy enjoying the drive ).
Thanks!
I am having the exact same issue as you have mentioned. I am guessing you haven't managed to find what is causing the issue?
Sent from my HTC 10 using Tapatalk
Nope. Car is now on 42k miles, has had four new tyres and Hunter 4 wheel alignment performed. Possibly *slightly* better but that niggling feeling that it just aint as smooth as it originally was is still there 😒
From reading other posts, I wonder whether suspension top mounts might be worth replacing, as some people report similar symptoms that can be resolved after this. Doesn’t seem too expensive to do. But then again, it doesn’t seem guaranteed and some continue replacing most of the rest of the suspension in an effort to fix.
It’s a real pain as the car was just *so* smooth, and still is some of the time!
Can I see where you have read this? I wouldnt of thought top mounts could cause the issue
I don’t have any links to hand but I recall googling and/or searching on here for suspension jiggle/unsettle etc and found some posts that flagged this as a possibility. My perception is that these have been a weak point on this and previous Golf generations.
Just an update to close this thread off, in case it’s of use to anyone else in future...
The front suspension bushes were replaced last week and that seems to have restored the smoothness. At least I couldn’t tell a difference between my car afterwards and the loaner 999cc base spec Golf (with regard to smoothness of ride 😀).
  • Similar Content
    • By DaveAberdeen
      Please can someone put my troubled mind at ease...
      Just put my Cadiz wheels back on for the winter. Imagine my surprise when I noticed that the nearside rear wheel arch gap is about 15mm bigger than the opposite side! The car looks positively lopsided! Fronts look fine. Had Eibach Pro springs fitted 2 months ago. Will they just settle or should I be heading to the garage asap?
    • By Yas_Man
      Hi All,
      Fitted my Bilstein Coilovers today, the B16 PSS10 version, not much info around on how to do it and half of what I found online was wrong plus the instructions are not the best.
      Tools
      For this job I used.
      Spring compressors
      13mm scocket
      16mm socket
      18mm ratchet spanner or 18mm ring spanner
      21mm ring spanner or 21mm swan neck spanner
      22mm ring spanner or 22mm swan neck spanner
      7mm allen key - DO NOT START THIS JOB WITHOUT A 7MM ALLEN KEY - THIS DOES NOT COME IN MOST ALLEN KEY KITS
      Socket set with 18mm sockets
      1/4" ratchet with 1/4" extension
      Vice or Mole grips
      Flat head screwdriver
      Masking tape
      2 jacks (you only need one) but two is easier
      18" piece of 2 x 4 wood or similar timber
      2 x axle stands
      M6CR-V splined drive
      M14CR-V splined drive
      Set of star bit screw driver bits
      2 x 20mm long cable ties
      Torque wrench and wheel sockets
      Ruler
      Let's start with the rear, break loose your wheel bolts, jack the car up, put your two axle stands where the rear arms bolt up to the center of the car, make sure you're careful to place the car gently on the stands when lowering the jack.
      Remove you wheels and put them somewhere safe along with you wheel bolts and wheel nut caps.
      Next move to the drivers side rear shock mount assembly and locate the three fasteners that hold the inner arch cover (you don't need to remove the cover just undo the three bolts that are closest to the shock as pictured below.)
      Now pull the guard back around the top of the shock tower to reveal the upper shock mount, undo the two 16mm bolts to loosen them off but don't remove totally just yet.
      Next look at the rear ARB (anti roll bar), get your 18mm ratchet or ring spanner on the nut and insert the M6 splined drive into the inner bolt to hold it whilst you undo the 18mm nut (don't try to pull it out yet as it's under tension)
      OK now there are two bolts between you and finishing the first part of this part, both require an 18mm ring or ratchet spanner along with a second 18mm spanner or 18mm socket. One holds the rear arm to the rear hub assembly and the other holds the bottom of the shock to the lower arm, remove them both.
      Note these pictures are for the rear passenger side (there is an extra step for this side when you come to it and that's to unclip the headlight leveling bracket )
      The bit in green pictured in both the image above and below.
      Undo this bolt
      And this bolt
      Now pull the rear hub assembly to the side to release the lower arm, now you can remove the two 16MM bolts at the top of the shock mount and remove the shock, if it wont come out, grab the top section of the shock in one and and the bottom section of the shock in the other and compress to shrink it down, now pull you can it out.
      Finally, you can now push the lower arm up to take the tension off the ARB and pull the rear drop link out the way - you might have to use both hands to pull it away.
      Part 2 - Disassembly & Reassembly - The Shock
      Right, grab the black plastic dome on the top of the shock you've just removed and pop it off to reveal the top nut, I found this nut really hard to get to without a top nut box socket so I cheated.
      Cut the cable tie off the dust boot and pull it down. Now wrap some masking tape around the very top of the piston, grab it with your mole grips or vice and just undo the top nut with a 16mm socket, they're not done up tight and undo with ease.
      Now pull off the top assembly, put the 16mm nut back on the old shock for safe keeping. Next pull the bump stop out of the top mount of the shock assembly and put it to the side - you don't need this but keep it in case you ever have to put the original suspension back on.
      Next take your new Bilstein rear shock out of the box, remove the top nut, keeping the black rubber washer in place. Next take the dust cover from your old shock, cable tie it back into its original place on the top mount and put the top mount shock assembly from your original shock onto the new Bilstein shock, replace the nut and tighten (as the Bilstein design is built upside down you can just hold the shock to do the nut up)
      Great - all done on this part and now on to the spring and platform adjuster
      Part 2 - Disassembly & Reassembly - The Spring
      Take the platform adjuster and set you spring perch platform in place (as a rough guide - 35mm from the bottom of the threaded section to the bottom of the lower spring perch lock ring will give you a final arch to top of tyre gap of around 25mm)
      Next add the spring ensuring you place the blue nylon washer between the spring and the platform adjust to keep things nice and quite - without this is place the spring and perch will knock/clank. OK, just add the big black rubber washer on the top and return to the car.
      Place the spring in the spring mount of the lower arm being sure to use the rubber spring mount that should still be in fixed into the lower arm - if it came out with the original spring, go and get it and put it back in place - note, you do not need the upper rubber spring mount that was attached to the top of your original OEM spring.
      Line the new spring up making sure the lower end of the spring meets with the rubber stop in the lower spring mount that's still in the lower arm.
      Right, time to bolt it all back up again - you may want to use jack to raise the lower arm up so all the bolt holes line up perfectly. Note in this picture you can see I have invested in some shock socks from eBay - I've bought some for every set of coilovers I've ever owned and they are excellent for keeping all the crap off shocks.
      Now do the same for the other side, refit your wheels, remove the jack stands and you're ready to start on the fronts . . . . want some good news?  . . . . . .  the fronts are way less hassle than the rears.
      Part 3 - The Fronts
      Right, this is the easier part of the job.
      Undo the wheel bolts on the driver’s side, jack up the front of the car (just one side) place an axle stand in a safe place and remove the wheel.
      Now look at the top of the brake caliper and you’ll see your brake line is held in place with a small metal tab/spring clip, slip your flat head screw driver under the spring clip and prize it up.
      (NOW BE REALLY CAREFUL)
      (ONLY ON THE DRIVERS SIDE) You'll see another cable, right next to the brake line, this is the brake pad wear sensor cable and you'll need to very carefully, AND I MEAN very gently prize this apart with a flat head screwdriver, take your time because if you break this you'll need a new one wired in and that is going to be a nightmare.
      Now you've got your brake line free and separated the brake pad wear sensor cable coupling, you'll need to undo the 18mm bolt which clamps the lower hub assembly to the bottom of the shock using the M14 splined drive and an 18mm ring or ratchet spanner or an 18mm socket.
      Next undo the droplink which runs from the end of the anti roll bar up to the tab on the side of the shock leg (this is the same as the rear, M6 splinned and 18MM nut) - just like the rear, if you cannot pull it apart just yet, not to worry you will be able to do so in a minute.
      OK - this bit is a bit more tricky! To release the the shock from the lower hub assembly you can either undo the lower arm which takes a ton of work or you can do the following . . . .
      Take your 1/4" ratchet and 1/4" extension and feel around to the back of the where the shock goes into the lower hub assembly, now push it into the gap as pictured below, rotate the ratchet an a eighth of a turn to open the jaws of the lower hub assembly - imagine turning it from a square that sits in the jaws to a diamond that just opens them up - I forgot to take a picture of me removing the original shock but you can see what I mean from the picture of the new shock in place below.
      Now grab the top of the brake disc with one hand and the bottom of the brake disc with the other hand holding the bottom of the brake disc and wiggle - you'll see the lower hub assembly now comes part of the way down the shock leg and stops - this because there's a metal tab on the shock that's now hit your 1/4" ratchet extension. All you have to do is give the ratchet another eighth of a turn, pull it out, push it back in jaws but under the metal tab and give it the eighth of a turn like you did before, again grab the brake disc and wiggle - you'll notice that whilst everything is lose, you can pull more of the shock out but you cannot get the hub assembly low enough to get the shock free completely but fear not . . .
      Get your jack and piece of wood, place the piece of wood on the jack, placing one end of the wood on the jack platform and position the other end of the wood against the lip of the shock that the shock's coil spring sits on and jack the shock up about 2" - 3" and out pops the shock from the lower hub - it may need a little wiggle - doing this compared to striping down the lower arm is much, much quicker and easier.
      OK you're on the home straight, pop the bonnet open, find the three clips that hold the plastic trim below the windscreen in place - you're not going to remove it, you'll just need pull the clips out in order to to lift the trim up a little to reveal the three bolts that are now the only thing holding the original shock in place. There is one tab in the middle, and one either side - I've just taken a picture of one side and the one in the middle but you get the point.
      Middle
      One Side
      OK, gently lift up the front, get your 13mm socket and remove the three bolts from the top of the suspension turret mount.
      Great stuff, now move the shock clear of the car. The next job is to compress the spring with the spring compressors. Get your 21mm ring spanner on the top mount nut and your 7mm allen key to hold the shock's piston that the nut is screwed onto still whilst you undo the nut - do not undo this nut without spring compressors unless you know exactly how to fire a shock down the drive without taking your head off - THE SPRING IS UNDER A FAIR BIT OF TENSION AND THIS COULD BE VERY DANGEROUS WITHOUT SPRING COMPRESSORS.
      OK if your still reading this, you've successfully removed the top mount from the shock without killing yourself
      Now all you need to do is remove the bump stop from the top mount of the original shock. Next place the top mount from your original shock onto your new Bilstein shock, add the washer that came with the Bistein kit to the top of the top mount and do up the 22mm nut.
      REALLY IMPORTANT - Now make sure you top mount set up correctly . . . .
      1) If you look at the top mount you'll see two arrows, these need to point to the front and rear of the car when reinstalled.
      2) The start of the new spring needs to line up with the locating tab that holds the wedge shaped part of the top mount in place with the other part of the top mount - this will make sense when you have the parts in front of you.
      3) Now move your spring perches up like you did on the rear install (a 40mm gap from the bottom of the threaded section of the shock to the underside of the lower spring perch will give you roughly the same arch to tyre gap at the front as you have at the rear)
      When the shock is lined up to the car it will look like the picture below - I put a little blue paint mark on the outer bolt hole of the top mount to make it easier to see when lining everything up.  Start by doing up the three 16mm bolts that hold the shock in place to the top of mount but don't do them up fully as you need some wiggle room to get everything in place and then when everything is bolt up at the bottom of the shock . . . . YOU SHOULD STILL NOT DO THE TOP BOLTS BACK UP JUST YET.
      With everything bolted back up at the bottom of the shock you should have something that looks like this . . . .
      OK nice work, put the wheel back on, remove the axle stand and lower the car to the floor - NOW AND ONLY NOW SHOULD YOU DO THE THREE TOP MOUNT BOLTS UP - THIS ENSURES THE SHOCK IS IN THE CORRECT POSITION.
      Now do the other side - its exactly the same but there's not pad wear sensor wire to worry about. Once finished, put the three tabs back in that hold the trim below the windscreen in place , close the bonnet and skip around your drive at your pure awesomeness.
      Right, that's it - hope this helps.
      If you've got any smart tips or questions, just let me know.
    • By AdrianoJP
      Hello all,
      new to this forum, but not to vag's and car tuning/racing.
      I own a '14 R with 56k km, picked up in Feb '17, DCC, Pretoria's, Eibach rear ARB.
      The issue:
      the car feels as if both front and rear bushings are worn. In all conditions, especially accelerating and braking, she swerves and pulls.
      I tried various geo alignment variations, but the issue is always there.
      Has anyone had this issue or has seen prematurely worn bushings on our cars?
      Thanks in advance for sharing and accepting me here 👍
    • By njdriver66
      As per the other thread where I asked about my 19" rims (235/35-R19) that came stock on my MK VII DSG w/ DCC R and looking to switch to 18" rims for avoiding pothole damage, I am therefore considering 18" wheels (with all season tires):
      Even though VW's 18" standard on the 'base' (manual) Golf MK VII R are 225/40-R18, I have been reading that people are using 235/40/R-18 as a substitute for the 19" OEM rims on their DSG Rs for the following reasons I gather:
      My understanding of the benefits of 235/40-R18 vs 225/40-R18:
      1) The 235 has a taller sidewall than 225 (94mm vs 90mm). My 19" Cadiz rims (OEM) only have 82.25mm sidewall height to protect from potholes.
      2) The 235 is wider for better handling in dry conditions to lose
      3) diameter of 235 tires and not needing to do speedometer adjustment
      https://www.mcgrefer.com/sizeinfo/2354018   645.2 overall diameter
      https://www.mcgrefer.com/sizeinfo/2353519   647.1 overall diameter
      As NeilCM noted: For instance check Tire Rack's page on the Bridgestone Potenza RE050A: http://www.tirerack.com/tires/tires....Potenza+RE050A
      The high line R's 235/35-19 tire is listed with 817 revs/mile, and so is the 235/40-18 (speed rating/radial letter omitted here for clarity). They both have the same tread width too. Therefore these are exact substitutions for one another for use on 19" and 18" rims (end quote).
      If I do decide to go with 235/40-R18 (unless someone convinces me otherwise / assuming I am not missing anything) and my priorities are to
      1) avoid doing any suspension mods
      2)  avoiding any 'rubbing' issues or other issues
      To switch to 235/40-R18 rims to use on a 2016 MK VII R that came with 19" x 8" ET50 rims with 235/35-R19 tires and to keep everything safe and just add some sidewall height (11.75 mm), given all the wheel well / fender measurements etc.:
      1) what is the proper (safest) offset (ET45, or rather ET49/ET50? I believe the 19" are ET50 and higher is better for no chance of rubbing?)
      2) what is the proper (safest) rim width (8"? I also see 8.5" used by some?)  The 19" stock rims are 8"
      I am not new to wheels / tires, but offset IS new to me and I also never had to worry about selecting rim width myself since I always went with OEM rim size, but that is not the case here (switching from 19s to 18s).
      Thanks a lot in advance!!!
    • By 314elliott
      I've been offered some ST springs for my 7R, has anyone got them or seen any reviews?
