Silk
Mk7R- Reversing Camera Retrofit OEM 5G1054634
Hi everybody and Hi Silk, I'm doing this retrofit to my Golf MK7 R-Line. I've done everything except connect the white wire/7.5 Fuse, I can't find any information about plug a new cable in the fuse box. Can you help me? Thanks!
Hi Silk. You will need on of these to splice into a 7.5amp fuse.
Image result for fuse splice
I installed the oem emblem camera on my 2015 golf r.
Everything works apart from the video image.
Screen is blank.
I did all the coding.
Apparently it doesn't work on my head unit.
Can I replace my head unit and screen?
Which one should I buy?
I have the 3Q0035820A head unit
Hi guys thanks for this post it was brilliant. I also found this video which was perfect step by step guide
My problem is I have not coded the reverse camera but the boot does not open with the key nor the boot emblem lever. Do I have to code it before it functions?
I thought it should still operate as a regular boot opener just the camera function needs coding?
I have no idea why it's not working then?? I connected the original 2 wires from connector to new wiring harness. Just dont know why it's not working? Completely stumped. Checked connections twice too.
Classic example of why we need punctuation .
I think Alex meant.....
No, need coding for boot opening
Hi,
thanks for the write up @Silk.
I have a question for you guys. I have seen OEM camera parts go pretty cheap on our local "Craigslist", but they are typically sipped without the harness. I therefore I help to find the correct part number for this harness.
I drive a 2016 Golf Variant (Station wagon) with Discovery Media.
Thanks!
