slider09 Posted June 6, 2017 Report Share Posted June 6, 2017 Hi Finally received my OBDEleven dongle this morning. Plugged it in and it is showing 3 faults. My car has just come back from vw this morning having had a new pcv valve fitted. Pretty sure they would have scanned the car for faults as part of their health check. So what are these faults? I think I read somewhere that OBDEleven will find these faults and they are not really faults; but can't remember where I read this. Anyone else always show faults when connecting? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 6, 2017 Report Share Posted June 6, 2017 2 hours ago, slider09 said: Hi Finally received my OBDEleven dongle this morning. Plugged it in and it is showing 3 faults. My car has just come back from vw this morning having had a new pcv valve fitted. Pretty sure they would have scanned the car for faults as part of their health check. So what are these faults? I think I read somewhere that OBDEleven will find these faults and they are not really faults; but can't remember where I read this. Anyone else always show faults when connecting? Sent from my iPhone using Tapatalk What faults are showing? Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 6, 2017 Author Report Share Posted June 6, 2017 What faults are showing? I wish I could tell you, can't connect to the obdeleven now. Plug the dongle inTurn on ignitionStart appPress connect. Nothing, just says connecting. Bluetooth is on and is paired with the dongle. Confused. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 6, 2017 Report Share Posted June 6, 2017 2 hours ago, slider09 said: I wish I could tell you, can't connect to the obdeleven now. Plug the dongle in Turn on ignition Start app Press connect. Nothing, just says connecting. Bluetooth is on and is paired with the dongle. Confused. Sent from my iPhone using Tapatalk Ah ok, very frustrating. So when it was connecting assume you ran a full scan then which gives you detail as to what faults have been logged. Keep trying and hopefully you'll be able to access the info. I had a couple faults show ip on mine, one was a static current too high thing and one an aircon thing but pretty sure these are non faults you refer to in your initial post. Car is running fine and no warning lights. Let us know if you get it to work. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 6, 2017 Author Report Share Posted June 6, 2017 Logged out of the app and now can't log back in. It doesn't recognise my email. Crazy stuffSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 6, 2017 Report Share Posted June 6, 2017 Very. Someone else have similar issues in another recent thread. If I were you I'd delete the app and start again. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted June 6, 2017 Report Share Posted June 6, 2017 Would not worry.I've scanned 3 golf's all show the same faults Sent from my SM-N9005 using Tapatalk Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 6, 2017 Author Report Share Posted June 6, 2017 OK, deleted the app and reinstalled, it logged in itself with the correct details - and it connects!! The 3 modules showing as faulty are: 01 Engine P15700 - Engine Control Module (ECM) disabled Intermittent P044100 - EVAP Emission Contr.Sys.Incorrect Purge Flow Intermittent 02 - Transmission P173400 - Starter release from the selector level sensor system Intermittent P170100 - Transmission control unit locked Intermittent 17 Dash Board B104A00 Engine Control Module (ECM) not authorised Static B1301F0 - Transmission control module (TCM) not authorised Intermittent Any ideas? Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted June 6, 2017 Report Share Posted June 6, 2017 is this with engine off ? ive seen these on all the golfs ive scanned.. i think the obd eleven picks up things that are not an issue . sometimes you may find after clearing they are not there the next scan but another day they maybe ,that's what ive found. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 6, 2017 Report Share Posted June 6, 2017 Glad you've managed to get back into it. Your faults are different from the ones mine showed, but as said, think it just picks up faults that aren't really faults, especially if ignition is on but engine is not running. Way I figure it, if a warning lights comes on, or there's some physical indication of a problem then it will get taken in to be looked at. Otherwise carry on as normal. slider09 1 Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 6, 2017 Author Report Share Posted June 6, 2017 Glad you've managed to get back into it. Your faults are different from the ones mine showed, but as said, think it just picks up faults that aren't really faults, especially if ignition is on but engine is not running. Way I figure it, if a warning lights comes on, or there's some physical indication of a problem then it will get taken in to be looked at. Otherwise carry on as normal. The reinstall of the app seems to have workedSo far:Soundaktor turned offComing home lights set to autoPuddle lights on whilst foldingAlarm chirp on lock / unlockAny other recommendations?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 6, 2017 Report Share Posted June 6, 2017 21 minutes ago, slider09 said: The reinstall of the app seems to have worked So far: Soundaktor turned off Coming home lights set to auto Puddle lights on whilst folding Alarm chirp on lock / unlock Any other recommendations? Sent from my iPhone using Tapatalk I did a few: Chirp on lock/unlock - long coded Stop/start disable - long coded Headlamp washers off - long coded Enable fan level display on auto - app Reverse lights full brightness - long coding DRL 100% with headlights - long coding Full brake lights - long coding Coming home lights long coding I think there's a couple of others but forgotten what, lol. My biggest recommendation would be disable Stop/Start, but that's not everyone's choice. I'd add the 5 x brake lights to the list which enables inner rears to work in addition to the normal brake lights. Equally with disabling headlight washers. 5x brake lights Fan speed lights in auto setting (aircon) slider09 1 Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 6, 2017 Author Report Share Posted June 6, 2017 Thanks. I already had the 5x brake lights and fan speed on auto, courtesy of a member on here. I have reversed my stop / start, so by default it is OFF, then press the button to turn it on - so no need to fully disable with OBDEleven. Re the headlight washers, aren't these a requirement for xenons? My car is due it's first mot next month, will leave as they are in case these are part of the test??Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
mickR Posted June 6, 2017 Report Share Posted June 6, 2017 Yes headlight washers legal requirement with xenons.Sent from my iPhone using Tapatalk Pro slider09 1 Quote Link to comment Share on other sites More sharing options...
PraggersK Posted June 6, 2017 Report Share Posted June 6, 2017 Will the OBDeleven work with the Facelift R? Their forum doesnt seem to think so at the moment. Quote Link to comment Share on other sites More sharing options...
