LouCyffer 826 Posted June 18, 2017 Report Share Posted June 18, 2017 I notice there are often questions related to what are the common issues on the 7R and 7.5R. So I thought I'd start a thread for us to list them. So, in the first 3 years of the life of your cars, what warranty claims have you submitted to VWUK via dealers that were honoured and rectified. To kick things off here are mine so far: 1. Coolant leak, new thermostat and water pump fitted 2. Oil leak from oil pressure sensor, new washer fitted Quote Link to post Share on other sites
Raffe 986 Posted June 18, 2017 Report Share Posted June 18, 2017 Front n/s wheel bearing which had gone, repaired without question under warranty. Quote Link to post Share on other sites
Farmermitchell 11 Posted June 18, 2017 Report Share Posted June 18, 2017 Complete new engine at only 9,000 miles after exhaust cam failure! Sent from my iPhone using Tapatalk Quote Link to post Share on other sites
rodacollier 35 Posted June 18, 2017 Report Share Posted June 18, 2017 Front n/s wheel bearing which had gone, repaired without question under warranty.How did u know? MK7 Golf R ManualUni Stage 2, JB4, Neuspeed DP Quote Link to post Share on other sites
Raffe 986 Posted June 18, 2017 Report Share Posted June 18, 2017 7 minutes ago, rodacollier said: How did u know? MK7 Golf R Manual Uni Stage 2, JB4, Neuspeed DP Because it was humming, been driving many years so a bit of experience came into play. Hector 1 Quote Link to post Share on other sites
rodacollier 35 Posted June 18, 2017 Report Share Posted June 18, 2017 Because it was humming, been driving many years so a bit of experience came into play.Thanks! Mine doesn't hum, but started making more of a hiss or brake disc noise at 16k and the pads are fine. I went ahead and put new Michelin PS4 tires on and no change. I guess a trip to the dealer is inevitable. I haven't had to use warranty yet. I thought these new cars with sealed wheel bearings rarely needed maintenance. MK7 Golf R ManualUni Stage 2, JB4, Neuspeed DP Quote Link to post Share on other sites
slider09 1,460 Posted June 18, 2017 Report Share Posted June 18, 2017 PCV Valve replaced, leaking oil from rear @ 17k miles. Sent from my iPhone using Tapatalk Quote Link to post Share on other sites
Novus 375 Posted June 20, 2017 Report Share Posted June 20, 2017 6 months old 3000 miles Front seat cover replaced due to sagging Paint defect on door - to be done yet but agreed under warranty Front seat cover to be replaced AGAIN - to be done yet but agreed under warranty Quote Link to post Share on other sites
1nfinite 12 Posted June 20, 2017 Report Share Posted June 20, 2017 Passenger proactive protection fault.. seatbelt replaced, air bags & computer. Quote Link to post Share on other sites
TheLout 4 Posted June 25, 2017 Report Share Posted June 25, 2017 On 18/06/2017 at 18:25, Farmermitchell said: Complete new engine at only 9,000 miles after exhaust cam failure! Sent from my iPhone using Tapatalk I'm with you there. New engine at 8000 miles, crank shaft bearing failure on Christmas Eve. Took the dealer 3 months to sort it and I had the joy of a VW Up! as replacement Quote Link to post Share on other sites
Farmermitchell 11 Posted June 25, 2017 Report Share Posted June 25, 2017 I'm with you there. New engine at 8000 miles, crank shaft bearing failure on Christmas Eve. Took the dealer 3 months to sort it and I had the joy of a VW Up! as replacementReally? Mine was in, diagnosed and replaced within 6 working days. VW Leeds. Sent from my iPhone using Tapatalk Quote Link to post Share on other sites
TheLout 4 Posted June 25, 2017 Report Share Posted June 25, 2017 12 minutes ago, Farmermitchell said: Really? Mine was in, diagnosed and replaced within 6 working days. VW Leeds. Sent from my iPhone using Tapatalk Inchcape Twickenham, couldn't diagnose a cold if you sneezed on them. Franchised garage desperate to get the funds from VW before they would replace the engine. Wouldn't take my calls, accused me of aggressive behaviour (all the guys at work had a laugh at that one, I am Mr Nice Guy). Really didn't know what to do if their diagnostics laptop couldn't come up with a solution. It was obvious to anyone that a bearing had failed just by listening to the engine at idle. Anyway, car is back and running fine. If it does break again might just take it to Leeds AgentFruit and overlooker 1 1 Quote Link to post Share on other sites
Deano 337 Posted June 29, 2017 Report Share Posted June 29, 2017 Nothing so far in more than 2.5 years of ownership. Quote Link to post Share on other sites
alexretro 78 Posted June 29, 2017 Report Share Posted June 29, 2017 1. Haldex pump replaced2. Rear shocks3. Roof corrosion4. Seatbelt pretensioner 5. Heater matrix flap motorThats last 14mts. Pretty sure I've missed something Quote Link to post Share on other sites
LouCyffer 826 Posted June 29, 2017 Author Report Share Posted June 29, 2017 36 minutes ago, alexretro said: 1. Haldex pump replaced 2. Rear shocks 3. Roof corrosion 4. Seatbelt pretensioner 5. Heater matrix flap motor Thats last 14mts. Pretty sure I've missed something 😨 how old is the car, Alex? Quote Link to post Share on other sites
