Terryw New member - mk7 help please
Hello - new member here.  Could anyone please advise?
I have a MK7 R with DSG - about 6 months old.  I just want to know if there is a shortcut to getting out of Sport Mode - other than going to the Mode button & going through the modes & re-selecting say Normal or ECO.  Reason I ask is that it's a simple tap backwards on the shifter to get it into Sport but can't find a simple way to go back to "non sport".   Hope I've put it in reasonably understandable way.
Also, anybody out there could tell me how to use the heater - without putting the Aircon on?
Have looked at the manual but it's still unclear.
Thanks for any advice.
As Taz says, a brief pull back on the gear lever will change between sport/drive. If not already done so, there's an excellent thread on here by Belfast Col that gives a great insight into how to get the best out of DSG. Took me about 2 weeks of reading and practice before I appreciated what it could do.:afro:
Thanks Taz & Mick R - as I was writing the question I was wondering if that was the solution.   I'll give it a go.
Any advice about the heating system - without putting the Aircon on ?
BR
terry W
I very rarely put the A/C on, I just open the windows for a bit or the sunroof. But as I said I think in a year I've probably only had the A/C on for a maximum of 1hr in total.
Modern HVAC systems are designed to be on continuous.
most are no longer just air con.
they actively remove moisture that sensors within the cabin detect.
also, a lot of modern systems activate by themselves even when set to off.
apart from all that it is really bad prictive not having air con on as it can really bugger up the system, seals dry out, you get leaks etc.
Hi, I've taken the liberty of adding to your original thread title to give a bit more idea of what the thread is about.  ☺️
BR
terry W
From my experience i keep the climate control system on "auto" and "sync" the selected tempreture. This will automatically turn on the "A/C" when this happens, just push "a/c" button to turn it off.  Then from that point onwards just push "off" button to turn system on and off when you need some heat/cool air.  A/C should only come on when you press it.
Hope that helps.
Hi Mick,
Thanks to all who have contributed.   Mick - nothing specific except that (probably very last year) you used to be able to have the car heated without turning on the Aircon which in itself consumes a fair amount of  power & can prevent the Start/Stop from operating (some on here might welcome that !!)   I just wanted to know if the heating & aircon could be used separately.   Hope this is making sense.
Thanks everybody !
BR
Terryw
  • Similar Content
    • By guy9159
      So I'm deciding whether to buy a 2015 MK7 Golf R white for £17,400 with 29k miles (private) OR 'Approved Used' 2015 Lapiz Blue MK7 Golf R for £19,100 with 12k miles.
      The approved used one is from a dealer so it comes with 12 months warranty which I would've bought (extended warranty for a year) so it saves me ~£630.
      All the other MK7 Golf Rs I can see for sale are around £18,000 for 2015 with 30-40k mileage and £19,000 for 2016 models with roughly the same mileage.
      I will be selling the car in a years time so I'm not too sure which one to go for? This might be a dumb Q but does mileage outweigh the reg/production year even if the car is lower mileage than the 2016 higher mileage? I will probably do max 7000 miles in the year.
      Also, if the Used Approved ones are ex-demos should I avoid them??
      Been looking for quite a while so would appreciate your suggestions- many thanks!
    • By BobTheGreek
      Hello folks, just joined this forum and I am new into the Golf R ownership club! I recently bought a used - 30k miles - Golf R Estate M7.5 and although I saw the interior quirks when checking the car I decided to go ahead with the purchase anyway.
      The stuff that I am talking about is the amount of scratch marks than can be seen on the inside of the rear interior boot trim panel is beyond imagination. These even extend to both sides of the C pillars! I mean, I don’t know what the previous owner was doing, but he must have been transferring large sharp objects constantly banging at the back! And all over the place for that matter.
      My question is: where do I find replacement parts for these panels? I contacted my local VW dealer but I am expecting them to come back with eye watering numbers to get things right. Is there a website that I can trust and order these from?
      Finally, the steering wheel at the top has visible wear so any suggestions on how to recondition that (other than those Amazon diy kits!) would be hugely appreciated.
      Many thanks.
    • By basharR
      Volkswagen Golf R MK7 Test Drive & Review - A Great Hot Hatch!
      The new Volkswagen Golf R was a very good ride and I really enjoy it... It is very quick and exciting hot hatch.
      Enjoy and please don't forget to subscribe to my channel
      https://youtu.be/5kcxgeDm7rg
