Sign in to follow this
Roby3087
Brake Pad Warning Light
My Brake pad warning light just came on, How long till they are useless? They look like they still have around 5-8mm left I dont get paid for 2 more weeks and a bit short on funds, to book it in to get them replaced. Am guessing i can still drive but taking it easy to work and back, its not even a 5mile drive there and back. If the worst comes then i guess ill be walking to work.  Also will it be worth changing the discs at the same time?
Assuming its the front pads they are not difficult to change if you have some previous DIY and a set of spanners, would save you a fair bit over getting a garage to fit them.  Rears are much more complicated job and needs specialist tools.
If you are not that handy, or just don't fancy the job, If you search you can buy pads at a discount, and if you have a friendly local garage they might fit them - that would save some cash.
how can you tell if its the front or rears?
would it not be best to replace front and rears at the same time?
I know my money is tight atm, but get paid in 2 weeks so if they will last till then, then ill just do front and rears at the same time
how can you tell if its the front or rears? would it not be best to replace front and rears at the same time? I know my money is tight atm, but get paid in 2 weeks so if they will last till then, then ill just do front and rears at the same time
Only the fronts have a sensor and only on one side(tut!)So it'll be the fronts that are approaching the end of their life, obviously they aren't just going to stop working, but you'll need to get them changed sooner rather than later.
Discs will have a min thickness tolerance, they can be measured to check what they are now.......
You can visually check the rears as the pad material is visible.
I have just bought some new pads from europarts which have a 35% discount going so only costed me £52 for brembo pads and some copper grease.
I was going to ask about the sensor as i looked at them and only one had a sensor on, was going to take them back but thought i would ask here and Veneeringman already answered.
Ill be fitting them tomorrow. Thanks for the help.
So changing the pads didnt go to plan and took a day longer than planned.
Went to take the wheel off and found out the garage that put my new tyres (and bought the car from)  a few months ago stripped my locking key. So it was useless and unable to get any of the wheels off i took it back to them and told them. They didnt put a fight up as it was in their system that i bought the car from them and they did the tyres. They took it there and then to try and get all 4 off without the locking key. I tried the normal nuts as well but couldnt even get them to move so they well over tightened everything.
The service manger wasnt in store today so didnt see him but got told he was going to be ringing me tomorrow.  The Service advisor said they might pay for a new set of locking nuts but the manager has to say yes to it.
Got them to take me home and they delivered the car to my home a few hours later.  To my shock they had washed it 😒 They didnt ask or tell me they were going to wash it. A black car now has micro scratches all over.
I shall bring this up with the service manger tomorrow if he rings me or ill be ringing him.
Am wondering where i stand on this, As they took the car and got the locking nuts off for free without asking so is that them admitting they where at fault? Also them leaving micro scratches by washing the car without asking me if i wanted it washed or not, can i get them to polish them out?
  • Similar Content
    • By Calpeo90
      Good evening all,
      Firstly, I’ve finally decided to bite the bullet and buy myself a Mk7 Golf R after 4/5 months of searching.
      The car is a 65 plate with 30000 miles in Limestone Grey with every optional extra except ‘Lane Assist’.
      The reason for the thread is that during a test drive I noticed a clunk coming from the brake pedal when I released my foot. It seemed occasional although it was very easy to reproduce. I’m slightly concerned with this although the salesman told me it’s normal and happens on them all.
      Any advice on this issue would be greatly appreciated; is this normal and am I being paranoid or is there something underlying that needs addressing?
      I have tried searching but found nothing similar to my issue.
      Many thanks in advance!
      Callam
    • By Roby3087
      My 64plate R has started to make a intermittent scraping sound from the front left. It has had new pads and discs (all round) around 500-700 miles ago. I cant tell if its a pad scraping or a wheel bearing. It sounds like the pad is scrapping along the disc. Sometimes its there sometimes its not. I can just tap the brake ever so lightly and the sound goes away. Then it might come back 10mins later or 20mins later. doesnt matter about speed. it pops up from 5mph to 60mph. Sometimes it quite and sometimes its loud. I dont get any brake squeal when braking.
      Ive bent the sheild back a little incase it was scrapping agasint the disc. There is no groves on the discs to say something is scrapping the disc. Ive stripped the fronts down and cleaned them and appiled copper grease but its still the same.
      Any ideas? maybe change the pads to different ones? If it was still in warranty i would have put it in but it ran out 2-3months ago
    • By 123AlfieG
      Hi Guys,
      I know this is a heavily debated topic, but I am thinking of upgrading my brake pads from the stocks...
      From what I have seen the two options I am deciding between are the Ferodo DS2500 and the EBC Yellow stuff?
      Has anyone tried both these pads and could offer any advice? Any other options people could recommend?
      Cheers!
      (I am running drilled discs by the way, so aggressive pads should not be a problem)
    • By 123AlfieG
      Hi Guys,
      Cheers!
    • By Calyum
      Brake Rotor Tidy Up
      So today was the day i tackled my brake rotors, I've been meaning to do it for while and since VWRoc had the weekend off updating it was time to try and tidy them up.
      I'm going to be honest, i didn't really have a plan going into this so i apologise to any professional paint-slingers that may view this! If you listen to this while viewing the pictures it may help..
      This is what they looked like at the start, i know its a pretty pointless exercise and i could buy new ones but its not something I've not tried before and who knows it may have even lead to a career change..
      Jacked it up, got the wheel off, and set about on the pointless exercise to try and tidy them up ready for the summer. Note; i only needed to tidy up the rear rotors as the front ones are new on.
      Then i attempted to sand them down the best i could, 20 minutes in and there were thoughts about maybe i should have just bought some new ones.. however i powered on and prepped them up. If you haven't clicked that link yet, there's still time..
      Okay so all prepped up, tape everywhere, thoughts of going to VW and apologising for ruining their brake rotor and a can of spray paint, we are off!
      Okay so I've applied the paint, advisory, if you ever do use spray paint be careful, i nearly ended up adding some extra details as you can easily get carried away. Left the paint for a few minutes and then rubbed around the rotor, not really sure why, seemed to work out though. I sanded down certain areas when finished because 1) i didn't want them to look brand new and 2) i got carried away..
      Onto the home straight, by this time I've lost all sense of time and i don't know when the last time i ate was. Wheels back on and time to inspect the damage workmanship. Yeah i apologise once again as i probably should tidied up the alloys for the big shot.
      Anyway that's it, we made it, thank you for taking the time for having a look and im sorry if i raised any blood pressures. I think im going to stick to my design job
