dj219957
Mk7 Haldex Fluid Change and Pump Gauze Clean
Just changed my haladex oil 2016 golf r
Only 12,000 miles wasn't going to take my pump out to clean it but after reading this thread decided to and it was well worth it I was shocked how much crap was on the filter and in the housing. pump would never have made 30,000 I will be doing mine every 10,000 miles.
Thanks for everyone who has posted great advice.
I wonder if the haldex filter is getting a lot of gunk (presumably from the haldex clutch) initially at relatively low miles, and then there will be significantly less build up of gunk from then on.  Which will mean less frequent cleans will be needed.
It will be interesting to hear from people about their 2nd and 3rd cleans of the haldex filter.  Usage patterns  (lots of AWD vs very little) will be also useful info.
I've been reading through this thread and the other 18-page thread on haldex maintenance. I intend on keeping my R long term so am keen to make sure it is properly maintained, so will be looking at changing the oil and cleaning the filter myself.
Its been mentioned a few times about the optional repar kit with the 2 bolts and the O rings for the pump - I was just wondering what anyones thoughts/experiences are with these, if anyone has used this kit or if you think its actually worth changing these bits or not?
Its entirely up to you if you replace the o-rings and bolts on the pump or keep the old ones, for the sake of £18 I'd replace. Photo below with o-rings and bolts.
The other photo is the drain/fill plugs, crush washer being copper. Again I'd replace both.
You will need:
5 and 8mm hex keys.
Lint free rags.
Cotten buds.
Torx 10 (need to confirm) .
10mm socket.
Flat blade screw driver.
Syringe (or use a freezer bag with a hose if you dont have one).
Containers to catch old fluid.
Haldex fluid g-060175-a2.
1. Raise car.
2. Unclip harness from haldex unit by pushing 2x clips  out.
3. Unclip pump connector using screwdriver and lots of patience (difficult access).
4. Remove sump filler plug with 5mm hex.
5. Remove sump plug with 8mm hex.
6. Catch old fluid.
7. Install sump plug.
8. Remove two bolts securing pump with 10mm socket.
9. Pull pump by wiggling it.
10. Catch old crud.
11. Remove gauze from pump with torx 10.
12. Clean pump and gauze using rags, cotton buds and water.
13. Install gauze on pump.
14. Clean haldex innards.
15. Install pump.
16.Fill sump with syringe until it spills out.
17. Install sump plug.
18. Go for a blap.
19. Check level.
20. Sleep well.
Can’t believe the crud that accumulates!
I've just done mine. A reasonable amount of gelling of the oil around the pump filter. The gel appeared pretty clear with I presume a little bit of black clutch material in it.  I did struggle for access for my torque wrenches so next time VW or indie will be doing it. My car is a late 2015 model with Haldex controller version 'D' and just under 25k miles.
Looking to do a second service / clean, however my local dealer do not have the pump repair kit in stock.
Does anyone know what size the o rings are? Looking at the workshop manual they say 43.5 x 2.5 and M6X35 for the bolts. Assuming the 43.5 is the internal diameter.
Yet, looking on eBay there are several seal kits for gen 5 pumps yet they show two different o ring sizes (and the bolts are different too).
Not too fussed about changing the pump bolts but would prefer to replace the two pump o rings if I can find the correct ones.
Anyone know where can get the oil cheap?
£26 ish seems to be the cheapest including delivery. Not sure if genuine.
https://www.autodoc.co.uk/febi-bilstein/8773507
I’d just buy it from VW (around £40), that way you know you have the correct oil for the gen 5 haldex. Previous generations of haldex used different oil.
Check the date on the top of the bottle. This oil should be used within 3 years of this date. When I looked at oil being sold on eBay I noticed some of the dates were over 3 years old.
Changed mine again the other week, didn’t know about the date on the bottle. Still got the bottle in the garage, will take a look at mine.
Bought it from VW so expecting it to be ok.
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • By Gsolid
      I have recently upgraded my 2015 R manual folding mirrors to original electric ones taken off a 2016 R.  the mirrors and switch are all original parts, the install was pretty easy and I have successfully got the mirrors working (folding via switch, auto folding when car is locked, demister and reverse dipping etc)
      The upgraded ones include puddle lights which fail to turn on when folding in or out.  I was wondering if anyone else has faced this issue before?  I don't have puddle lights on the doors, just a red reflector at the bottom so would this be the cause of the issue or would it be something else?  does anyone know the fuse number for the puddle lights?
    • By Gsolid
      Hi All,
      My 2015 R was involved in an accident and the down pipe has been damaged in the process,  I've seen a couple of original spares for sale but they are of a 2017 Golf R.  I was wondering if anyone has had experience with this before? Do you know if this would be a straight fit? are there and differences i the 2 models etc?
      Appreciate any help on this
    • By JJB
      Hello everyone,
      After recent topics and discussions that I saw on the forum, I think it would be great to get a meet organised, booked and in the diary for 2019. With Christmas coming up, I'm sure a lot of you will be working and/or have ran out of annual leave. Now here comes the difficult part, where to hold it and when to do it. I know as a forum we have people from all over the UK, so I'm thinking of somewhere maybe Midlands area maybe Derby/Nottingham, accessible to motorway routes, giving you guys and girls the best routes without being massively far away.
      In terms of the meet itself, I'd be apt to have this on a weekend morning, so it doesn't take too much out of peoples day, and it's a lame excuse to grab some breakfast and to have a natter. So the general plan would be, to meet up at a Toby Carvery or the like, meet for say 9.30/10.00 am - have a natter prior to going in to getting some food, then back out after a hearty breakfast for another chat, then away we go.
      Who would be up for this? Obviously we have a bit of time before it, so it gives enough notice to clear diaries and the like.
      Answers on a postcard, dependent on the outcome, there will be updates.
    • By Bob
      Ok I've had enough of one shiny pipe. Replaced oem exhaust with Scorpion downpipe with sports cat and scorpion cat back with resonator. Lovely burble with bass note, but sick of oem 'tail pipes'. Going to give this a go. 51mm in to twin 76mm out. Will update- bit of a punt but nothing else out there.
      https://www.aliexpress.com/item/Car-exhaust-pipe-H-Model-Akrapovic-Carbon-Exhausts-Dual-End-Tips-for-BMW-BENZ-AUDI-VW/32912588706.html?spm=2114.search0204.3.17.22d8a061AB6vvu&ws_ab_test=searchweb0_0,searchweb201602_1_10065_10068_10130_318_10547_319_10548_10696_10192_10190_10084_10083_10618_452_10307_10820_532_10301_10821_10303_5727311_204_10059_5727211_10884_10887_100031_320_10103,searchweb201603_60,ppcSwitch_0_ppcChannel&algo_expid=f124379e-0732-436e-880f-062909625cbf-2&algo_pvid=f124379e-0732-436e-880f-062909625cbf&priceBeautifyAB=0
    • By Has7rr
      Hi guys,
      I was wondering if anyone on here  would be able to give some advice regarding the maintenance and or repairability of a mk7 golf leather steering wheel.
      I am the current owner of a mk7 golf r and my steering wheel is beginning  to show marks and fade and I'm  really struggling to bare with them. Hence the reason for starting this topic. I am aware of leather  cleaning kits but it would be nice to get other peoples experiences before going ahead with any purchases.
      Any help or advice is much appreciated!!
