BCS Powervalve launches new Downpipe variant
This is the brand new 76.0mm Golf R Mk7/7.5 Downpipe from BCS Powervalve...
Following on from the demand for ultimate flow we have developed this with clients looking at up to 600 bhp in mind.
Featuring the oversized 100 cell cat with an open area equivalent to an 93.0mm open pipe and the brand new 76.0mm 'Softflex' specifically developed with flow in mind having a genuine 76.0mm I.D. unlike previous 76.0mm flexis which only offer a 69,0mm I.D.
To further compliment the downpipe both the catted and cat delete pipes will now be supplied with the 1200 degree titanium thermal wrap to enhance power further, and the 200 cell lambda mini cat.
Thanks for looking
Nige
12.thumb.jpg.56f6c412990695bb9be9a101ecab55b0.jpg11.thumb.jpg.36e8e20a7e064241dbce6130f8cbb7f0.jpg10.thumb.jpg.58d318b0b81997067857552db71d97f9.jpg9.thumb.jpg.407643ef56f2d1731b48ab5b2272958a.jpg5.thumb.jpg.366a46f4d66cb54dedaa26bf5d0d4014.jpg6.thumb.jpg.2c7053dbe06bfe05945f12cc61ca2768.jpg7.thumb.jpg.7fa6d8d20455391cdd78d9fb09b59bb7.jpg8.thumb.jpg.8ac9d1bcc7f365410ce47096d27fa31f.jpg4.thumb.jpg.1513af85663169cb34b4b8b40961a232.jpg3.thumb.jpg.9d6a0783f7036840739fe47c0e1a7099.jpg2.thumb.jpg.6eec8f06e446593d0d96dea94ec20787.jpg1.thumb.jpg.a27252bf13ae61b36fe427962020ef84.jpg
Edited by nige bcs
mistake
  • Replies 89
Thanks for the support guys... always a real pleasure dealing with genuine R fans of which you all know I am myself. Jeremy - I have tried to answer your questions on here and by email, including
This is the brand new 76.0mm Golf R Mk7/7.5 Downpipe from BCS Powervalve... Following on from the demand for ultimate flow we have developed this with clients looking at up to 600 bhp in mind.
As a generalisation the quality of so called sports cats is something of a lottery to the uninitiated. A 4.0" dia 100 cell cat will deliver an equivalent flow rate of around 72.25mm once cross secti
Posted Images
The pipe was designed specifically in response for customers looking at beyond 600bhp requirements.
3.5 " is not something that we wanted to risk due to firewall proximity, and general safety tolerances along with the fact that a 3.5" Flexible de coupler will not fit into the available space.
Tunnel thermal protection prevents the install of our 140,0mm Mega cat rendering ground clearance unacceptable.
Therefore, the 100 cell cat was specced as it creates a greater flow ratio over the cat monolith than a cat delete pipe, rendering the need for the illegal cat delete unnecessary unless you are considering one strictly on an economic basis.
However, given the 4 - 4.5 hour re fit time to put the OEM cat back for the MOT, it really is a no brainer opting for our fully road legal cat.
Cheers
Nige
does this mean the current 200 cell 3inch downpipe is only a 3inch diameter up to the point of the flexi where it drops to 2.7inch? before opening up again to 3inch diameter afterwards?
Does that not cause a restriction (albeit not a big one) as the gases will still be super hot, fast flowing and expanded at that point?
Edit - not taken pipe wall thickness in to account, is the 3inch diameter measured internally or externally?
Yes Doug...
Although we have been using the Softflex for quite a while now - this new soft flex has a genuine 76mm through bore, coupled with the 1200 degree titanium thermal wrap and now the new 100 cell cat, positioned well away from the turbo ;-)  - we are at the absolute peak of what is possible
Cheers
46 minutes ago, dougaberdeen said:
thanks, fair to say that standard 200cell cats can deal with anything the standard turbo can put out power wise anyway
A 4.0" dia 100 cell cat will deliver an equivalent flow rate of around 72.25mm once cross sectional area has been calculated and laminar flow corrected.
With regard to the road legality it's true that the value lies in the amount of precious metal in the cat wash-coat -  a 5 gram wash-coat will get a cat through an MOT once maybe twice and then it's going to start to struggle due to basic entropy...
In addition the quality of European fuel also has a knock on effect with regard to its long term effectiveness, when compared to say US fuel.
We offer a larger 125mm 200 cell cat which gives a genuine corrected flow ratio of 79.0mm in addition we offer a 40grm wash-coat to provide complete road legal conformity with current MOT legislation and to ensure the durability of the cat.
For guys looking for big power we recommend the new 100 cell variant which definitely out performs a cat delete with a corrected flow ratio of 88.0mm and again comes with our massive 40grm pm wash-coat.
Ultimately the 2 questions that need to be asked are what is the diameter of the cat and what is the weight of the PM wash-coat, if this cannot be answered then fear the worst.
It may be true that there are very marginal gains to be offered by opting for a cat delete against one of our 200 cell cats, but there are also other considerations such as the road legality of a cat delete and the consequences of knowingly running one.
One of the ways that we will be further enhancing the performance of our downpipes is by the introduction of the new 'Softflex' on all 76.0mm downpipes from 2018.
The benefit here is that it has a genuine bore of 76.0mm as opposed to the braided 76.0mm flexi's which in truth have only a 70.0mm bore.
Our downpipes and cats are not the cheapest but I think you will not find it possible to source a better one by application once you have determined your individual requirements.
Hope this helps
Nige
  • Similar Content
    • By Golphin
      Hello.
      I'm currently running Revo Stage 1 with a panel filter (snow grate removed), turbo pipe and muffler delete.
      Is going to stage 2 worth it?
      Who here has been stage 1 then moved on to stage 2 with Revo with GPF?
      Interested to hear the pro's and con's.
    • By purplepulser
      So I've just come back from MRC Banbury, after having the full intake hardware fit treatment, including muffler delete, along with their Custom Stage 1 ECU and TCU remap.
      I can safely say I'm so impressed with the results.
      After intake stuff fitted
      Car sitting waiting to go on the Dyno, it was a fantastic day weather wise. Clear blue skies and sunny, but cold. Good for intake temps.
      Dyno Results
      Power wise, from stock run with intake hardware fitted, it made 323ps.
      After the 2nd dyno run following the remap, it made 395ps.
      Torque, from stock, it made 413.89Nm (305.27lb ft)
      After the 2nd dyno run following the remap it made 547.63Nm (403.91lb ft)
      One the brakes side of things, I decided to assess the direct OEM replacement hooked discs all round, along with braided lines from HEL. Pads, I've gone with Ferodo DS3.12 for the front, and Ferodo DS2500 for the rears.
      Front
      Rear
      I purchased this totally stock car back in Dec 2020, and although it was quick, I always felt it was holding back a lot. An example of this is that I could be on a dual carriageway doing 50mph for instance and floor it, and it would pick up speed ok (relatively speaking) but there didn't seem to be any urgency to it. I always got the impression it was constantly restricting the boost and fuel, deliberately limiting power, just to maintain its factory output figures. In stock form, most of its speed seems to be concentrated in bursts from standstill up to about 60mph.
      I had some time to test the results on my 100 mile drive back home!
      Now, its completely different. Everything about it is urgent. From standstill, not using launch control, it really punches in the power, and the DSG shifts are now more aggressive and quicker. I now get the sense of being pushed back in the seat while accelerating in every gear. The power delivery doesn't stop either, it just keeps going until it hits the rev limiter and then upshifts.  If I put it in manual mode, it is just that, and it wont upshift until I change and will bounce off the rev limiter.
      And then there is the noise. I can hear much more of the intake noises. Makes a massive difference. Oh and it pops and bangs a lot more in race mode!
      I don't have a draggy, so I can't test its 0-60 times, but I imagine its going to be less than 4 seconds.
      Looking forward to Mallory Park on Thursday.
      What does everyone think? Any questions, let me know.
      As always, let me know of any further recommendations.
    • By DaveAberdeen
      Hi Folks,
      Taking delivery of my second golf R next week. It's currently got a Milltek cat-back system on it but I want to run a Scorpion sports cat DP (as I know that will pass MOTs) for stage 2.
      Question is - are there any compatibility issues when fitting or straight plug and play?
      TIA
    • By AceGolfR
      Hey all!
      I figured I’d start a topic for my lovely OPF 2020 Golf R! This topic is mainly to showcase the journey of my Golf R and encourage other Lapiz blue owners to share theirs!
      I’d like to welcome and share:
      1. Car modification journey
      2. Road trips/ scenic photographs
      3. Any other Lapiz blue R related stuff!
      I want to share my cars modification journey (it’s currently completely stock) and have many ideas for build. I also plan to take my car around Europe and vlog it for YouTube- I’ll be sharing the journey of that too!
      ALL LAPIZ BLUE MK7/7.5 OWNERS WELCOME! (Sorry to other colors haha, All Golf R’s are lovely regardless what colour but this one is for my Lapiz people!)
      My car Instagram: @AceGolfR
      😎😁 Follow me & share your Lapiz!
      #shareyourlapiz
    • By smokeR
      Evening Folks hope your all doing okay.
      Decided to remove the JB1 from R and try a Revo Stage 1 remap. Car is standard except a drop in filter, turbo elbow and pipe (snow grate removed). Still running a pedal box too.
      The remap pulls harder through the rev range and there is more power at the top end than the jb1 gave. Its drives like factory but with a load more power.
      Is it worth 3 times the price of a used jb1.....quick answer for me is mmm yes. But different horses for different courses. It also came down the the garage doing the work - very experienced mech / race car builder tuner. And local too! Got me involved and made me feel right at home, so worth every penny. Discount on future work tops it off.
      I did consider the dsg remap but feel its not need with the 7 speed dsg box, especially as I always drive in 'manual' . No issues so far. If any slippage occurs ill get Tvs to up the clamping pressure.
      The in dash power gauge has been recalibrated and reads 287kw /385 bhp. Not sure how accurate that is.... I would estimate torque at 500ish. It really does pull hard in gear now.
