Liborio
Hi - New owner needing help
Hi All,
Im really hoping someone can help.
Yesterday i bought a 2010 VW GOLF R MK 6 AUTO DSG. When going for a test drive and inspecting the car it all seemed fine.
My first issue came when i dropped my friend off that came with me. As i was leaving his driveway, i went to put it in reverse and at that point it gave me an error with an exclamation mark saying gearbox was overheated. I turned the car off and then started it again and seemed fine. I reversed out and went home. At some stage i got a solid engine light appear on my dash.
Today, i dropped my mum off somewhere and when putting it in reverse, it wouldnt select the gear and let me reverse, nor would it let me select drive either. I restarted the car and that seemed to then let me reverse and select my gears. At this point the engine light was still showing.
I took the car to my mechanic to do a check of the car as i just got it and to show this issue i was having. As i was driving to my mechanic, about 15 hours after the initial light appeared, the light went away by itself. He ran the OBD scans throughout the whole car and only found one code - "P2711 - Unexpected / Implausible Mechanical Gear Disengagement", which was cleared because he checked the DSG and it seemed fine as the drive is smooth and the oil was good. We also discovered it could be from aggressive driving which i dont believe i was doing as i have been taking it easy.
When i got home, i went to the gym awhile later, as i was trying to reverse out of my driveway, the same issue occurred where it wouldnt select reverse or any other gear so i had to restart the car to get it to select reverse and the light is appearing again.
Im really not sure what is happening at this point and starting to think this may be a gearbox issue after all.
Is anyone able to shed some light on this?
Kindest Regards,
Liborio - Sydney
I was perhaps hoping it was Trade and then at least you could return to the garage for them to fix issue! As it was a private sale, you have little support. As for diagnosis, I am not that familiar yet with these as only a 3 week old owner myself. Someone with bags more knowledge will surely respond.
Hope it sorts itself
  • Similar Content
    • By JoeB
      Hi there,
      So I have a 2019 R which is ofcourse post GPF filter. I would like to modify the exhaust in any way to make is sound a little louder. I originally thought of a res delete but as far as I am aware the 2019+ models with the GPF filter do not have a resonator from factory. Am I right in saying this? Also if that is the case and there is no resonator to delete what are the other options to get a bit more sound? Or is the only option to get a new exhaust system fitted altogether. Thanks for any help,
      Joe.
    • By Bazzy200
      I bought a used car with an automatic transmission (DSG) a few days ago. It has 245k km on it.
      Today while driving I realized that DSG seems to be slipping when shifting from 2nd to 3rd gear. It revs a bit higher before shifting. It revs like 100-300rpm higher and then shifts. I also hear it from the engine when it revs higher. I tested the DSG in M mode and it shifts perfectly without revving
      Higher than expected. What could possibly be cousing this?
      Here is a video while it does it:
      https://imgur.com/gallery/gB1fPcn
    • By Classicld
      Developed this noise after getting an apr Downpipe and custom miltec exhaust fitted. Made it both on stage 1 and stage 2+ tune. Had people tell me it’s just the wastegate but figured I’d ask other R owners. Thoughts?
    • By Mattalica10
      Hello all,
      I am stage 1 ECU/TCU tuned with R-Tech and the gearbox is acting a little strange when I hit the loud pedal. Sometimes when I boot it in 1st, it climbs through the rev range and wants to hesitate when changing into second gear and holds back for a split second, then changes gear and off it goes through the rev range like nothings wrong. Its also done this a couple of times going from 2nd to 3rd. This is usually done in Race mode and gearbox in S. Both manual and auto mode.
      Any one come across this type of thing before?
      Also when plodding around car parks or town, when i'm at around 2-10mph it likes to increase up on the revs all on its own when coasting. Only very marginal but it likes to 'hang on' (best way to describe it). Quite a difficult one to explain, but if you've encountered the same thing, you'll know exactly what im on about.
      All advice welcome, Cheers.
    • By itsyaMk7R
      Hi everyone, i have a very strange knocking noise coming from the front of my car when i am lighly feathering the accelerator (around 1500 revs) and it also happens when the car is slowing down from a low speed. I have taken it to VW this morning for a general health check in which they said they can hear the noise but can't see what it would be and that it requires further inspection. The car is a 2016 Mk7 R with 19000 miles on it so not enough for long term wear and tear.
      I have a video of the noise but i cannot attach it to the post so if anyone would like to hear the noise if it would help them determine what it is i can email it or send it in some other way to you directly...
      Any help would be grately appreciated!
