mattipuh
Worth going stage3 or just stage2?
Hi having a debate whether to go full monty to stage 3 or just to stage2? Car is my daily commuter so would probably be happy with stage 2 performance - nevertheless would get more value of mapping from going directly to stage3, only extra cost would be new turbo.
Pros and cons?
Considering tte525 - now with jb4 and powervalve 100cell dp and mst 3" Intake, stock ic.
Pros and cons?
FWIW, a big turbo with fueling and an charge air cooler will set you back probably close to 7-8k. Is it worth it? No one but you can determine that. My car made 340ish awp (dyno sheet)6932a7229cef08489d26620a5c851422.jpg on a uni stage 2 flash and an AWE downpipe. I hope to make close to 500awp with a boss 600, E85 fueling and an aftermarket cooler. For me .... to much is just enough.
Best luck
UM says to reach the full potential of the TTE525, you'll need port injection.  Also, hope you're not planning on going stage 3 on the stock ic.
So, it's going to be more than slapping a bigger turbo on, if you want to optimize your setup.  As stated earlier, only you can determine if the additional cost is worth it.
Besides the cost of going stage 3, don't you lose some low rev torque by going to a bigger turbo ?  I understand these bigger turbos need more revs to build boost so your useful power delivery is moved higher in the rev band (but there is much more when it does arrive).
As others have already said, it all depends on what you like and dislike (and how much you are prepared to pay for it).
Interesting viewpoints - what specifics are different in maintenance point of view?
Was thinking to run tte525 with less boost targeting BTW 470-490hp meaning less need for ic and less strain for car.
To my understanding tte525 works easier ie it can do more with less boost than stock is38.
Living up north so there's need for ic only if doing one mile runs and maybe 2-3monts in year at max.
I’m curious on your turbo choice... why not efr7163 if you like Borg Warner? I’m no expert but 470-490 whp on a hybrid
with low boost seems like a bit of a stretch. When I was thinking big turbo UM suggested I stay away from hybrids. They said nothing bad about them just that they’ve had better luck with other turbos.
Who’s recommending you go stage 3 without an IC?
If you have the cash stage 3 is great...you won’t regret it...although stage 2 on this platform is so much less expensive and still pretty mental.
Also in terms of turbos take a look at the Turbo Technics offerings. VRS Northampton are worth talking to.
I have a v4 currently (up for sale next week as I’m going v5) and it’s putting out 530bhp with no issues.
Best luck
I see I forgot to post the big turbo dyno runs.
So is38 uni stage2 awe downpipe on e30
GTX30 flex fuel awe downpipe on e30
So for me... yeah, it’s worth it
Don't forget:
For longevity engine build at stage 3
Clutch Packs
Reliable tested kit
Labour + vat
Thats without a proper BBK @ 2k+
Exhaust DP or system
Upgraded decent suspension
Big big money
Also running the V4... can’t fault it!
If you don’t mind me asking... who/where are you getting the V5 from?
Why couldn't you go stage 3 with less boost and without ic? It is not necessary to always push the envelope especially as car is daily driver not a track whuyra(). Been driving tunedstreet cars and race cars for 10years and can't understand this..
1 hour ago, sustanon400 said:
Stage 2 really ought to have IC let alone stage 3!
VRS do a hybrid that will give me 480bhp+ , no extra lag, no need for fuel pump, clutch packs etc. For road use this sounds perfect! All you need over stage 2 is turbo, software and IC
This ^^^
Will at VRS Northampton.
Car should be ready tomorrow 😎
if the car is a daily driver and you aren't aiming for high numbers, what's the point in running a bigger turbo, all you are going to get is more lag which is amply demonstrated by the graph put up where the stage 3 has less torque than a stage 2 until over 4000rpm which for me would just be a chore in daily driving
and you cant get the benefit of the bigger turbo in terms of output without significant spend in upgrades
each to their own but I just don't see the point?
Create an account
Register a new account
Sign in
Sign In Now
