I know this may have been asked to death, and there are possibly topics already out there, but I am getting my MK7 R remapped on Saturday - Stage 1, but I am slo getting the DSG Tune done at the same time.
I have looked around and seen what they add to the gearbox, but I wondered is there a standard tune they add or can this be a pick and choose kind of options with what you want added
People with the gearbox already done, what are your thoughts?
Lloyd
I haven’t got a map yet but I’ve researched them somewhat in the past, to me it seems like loads of big tuning companies offer a great DSG tune which will be Generic (shift points, true manual mode etc.) but if you went to a tuner who does custom maps then I’m sure he/she would be able to tailor it to your needs within reason for example choose your own shift points and so on.
Theres only so much you can do with the gearbox.
You need to ask the tuner.
As an example you can have any of these features with our DSG tune:
Increased shift RPM in D (doesn't race into top gear so quickly)
Decreased shift RPM in S (doesn't try and rev to the redline on light throttle)
Kickdown disable
Disable up change in Manual
Choose Launch control RPM
Plus there are many other things happening in the back ground by default, but the above are optional.
Rick
Mine is set up like this
kick down swich disabled in manual mode
auto Up shift and down shift disabled in manual mode
3 launch controll  settings
4000rpm,3500,3000rpm.
This is the list for. Apr
  • ster acceleration through application specific optimized shift points.
  • Drive and Sport mode shift maps custom tailored to APR’s power upgrades.
  • User adjustable 3-step multi-launch control RPM limits.
  • User definable* max launch control RPM.
  • User definable* manual mode downshifts via the kick-down switch (on/off).
  • User definable* manual mode upshifts at max engine speed (on/off).
  • Manual mode / TT mode paddle response times optimized.
  • Manual mode / TT mode downshift time optimized.
  • Launch control response enhanced for quicker launches.
  • Torque intervention limits raised while retaining critical protection routines.
  • Temperature management optimized.
  • Gear display enabled in Drive and Sport.
  • Downshift “lockout” disabled below previous gear’s max RPM.
Kickdown disable
Rick
Is this available on the 7.5 DSG as well Rick?
Sent from my SM-G960F using Tapatalk
Kickdown disable
Rick
  • 8 months later...
