sk8chris 0 Posted February 12, 2019 Report Share Posted February 12, 2019 Hi All, Would absolutely love it if someone could help me out with how to get rid of this irritating warning! I had a minor service done 2 weeks ago (not at the VW dealer) and they obviously didn't reset the reminders as the 'oil change now!' warning has started and it's driving me up the wall! I googled how to reset it and tried everything but it will not go away, Turn ignition off, hold 0.0, turn ignition on, get the reset option, press 0.0 again but nothing, tried it with hazards on as was one suggestion but again...nothing. Any help would be hugely appreciated. Thanks Quote Link to post Share on other sites
rodacollier 35 Posted February 12, 2019 Report Share Posted February 12, 2019 Did you try the infotainment system? Here’s the sequence from my owners manual Sent from my iPhone using Tapatalk Quote Link to post Share on other sites
sk8chris 0 Posted February 13, 2019 Author Report Share Posted February 13, 2019 8 hours ago, rodacollier said: Did you try the infotainment system? Here’s the sequence from my owners manual Sent from my iPhone using Tapatalk Thanks for the reply, yeah tried all this this but the message will not got away. anyone else had this problem? forgot to mention earlier it’s a 64 plate if that maybe makes a difference? Quote Link to post Share on other sites
sk8chris 0 Posted February 16, 2019 Author Report Share Posted February 16, 2019 Nobody else had this issue? Quote Link to post Share on other sites
rodacollier 35 Posted February 16, 2019 Report Share Posted February 16, 2019 Where r u located? I’d let u use my vcds Sent from my iPhone using Tapatalk Quote Link to post Share on other sites
rosshutchie 24 Posted February 17, 2019 Report Share Posted February 17, 2019 You don't need VCDS to do it. Is yours a MK7 or 7.5 with the virtual cockpit? I followed this for my 7.5. Worked 100% Quote Link to post Share on other sites
sk8chris 0 Posted February 17, 2019 Author Report Share Posted February 17, 2019 1 hour ago, rosshutchie said: You don't need VCDS to do it. Is yours a MK7 or 7.5 with the virtual cockpit? I followed this for my 7.5. Worked 100% It’s a MK7 and unfortunately I’ve done all this and the warning just will not go away. To make matters worse I now have ‘error start-stop system’ and the engine managements light on. Really starting to hate this car. Quote Link to post Share on other sites
gregozedobe 2,241 Posted February 17, 2019 Report Share Posted February 17, 2019 2 hours ago, sk8chris said: It’s a MK7 and unfortunately I’ve done all this and the warning just will not go away. To make matters worse I now have ‘error start-stop system’ and the engine managements light on. Really starting to hate this car. Your battery may be low on charge, could be worth checking. Quote Link to post Share on other sites
kiddiecobbler 0 Posted October 21, 2020 Report Share Posted October 21, 2020 I have the same problem after changing the oil on my 2015 MkVII Golf Sportswagen. Tried the dashboard reset countless times - it reset the service alert, but not the Change Oil Now! alert. Also I tried to reset the alert using my OBDeleven twice; did not work - burned 20 points with no effect. I notice that this post is quite old now - did you manage to resolve it? PS: Battery voltage is not a problem, I expect there's some significance to the fact that neither reset method worked. Quote Link to post Share on other sites
Ollievt 0 Posted January 9 Report Share Posted January 9 I have exactly the same issue with a 64 plate Seat Leon. The oil service will not reset using the buttons on the dash, and I now have the stop/start fault too…. Did you manage to get your issues resolved?? Quote Link to post Share on other sites
fastandy 60 Posted January 9 Report Share Posted January 9 Need a scan really with vcds or obb11 for the start stop. With the service reset, all I can think of is the car has been set to variable service regime. Quote Link to post Share on other sites
