smokeytiel
I messed my car up with obdeleven
Hey
Bit of a problem
I stupidly tinkered with the steering geometry settings by resetting to factory defaults and now :-
hill hold assist
parking assist
Adaptable cruise control
rear parking sensors
front parking sensors
lane assist
Sign recognition
anti slip
No longer works
is there anyone in Worcestershire or Gloucestershire that can sort this for ££.
otherwise I'm going to have to explain myself to the VW garage :(
i know I'm stupid
James
2018 Golf 1.5 R Line 150 Dsg
This Shpiel is what i downloaded from obd eleven can anyone make hide nor hair of this
OBDeleven data log Date: 2019-03-14 22:16 VIN: WVWZZZAUZKW058934 Car: Volkswagen Golf Year: 2019 Body type: 5-dr hatchback Engine: DADA 110 kW (150 HP) 1.5 l Mileage: 3428 KM --------------------------------------------------------------- 01 Engine System description: R4 1.5l TFS Software number: 05E906018AL Software version: 6084 Hardware number: 05E907309 Hardware version: H22 ODX name: EV_ECM15TFS01105E906018AL ODX version: 003002 Long coding: 012500322364050820000000000000000000000000000000 Trouble codes: U041600 - Invalid Data Received From Vehicle Dynamics Control Module static --------------------------------------------------------------- 02 Transmission System description: GSG DQ200G2_M Software number: 0CW300041S Software version: 1605 Hardware number: 0AM927769E Hardware version: H05 Serial number: CU501810135555 ODX name: EV_TCMDQ200021 ODX version: 001001 Long coding: 0014 Trouble codes: No trouble codes found --------------------------------------------------------------- 03 Brakes System description: ESC Software number: 5Q0614517DE Software version: 0524 Hardware number: 5Q0614517AD Hardware version: H25 Serial number: 62998000005812 ODX name: EV_Brake1UDSContiMK100IPB ODX version: 037009 Long coding: 01FA8AA1242521744780060360C72980512484E26006947338225078C222430B00000012121212B835351919323200 Trouble codes: B116854 - Steering angle sensor No basic setting static U112200 - Databus implausible message static --------------------------------------------------------------- 08 Air Conditioning System description: AC Manuell Software number: 5G0907426AQ Software version: 1801 Hardware number: 5G0907426AQ Hardware version: H03 ODX name: EV_ACManueBHBVW37X ODX version: 004134 Long coding: 00120004200110001100000000000002 Trouble codes: No trouble codes found --------------------------------------------------------------- 09 Central Electrics System description: BCM MQBAB M Software number: 5Q0937084DB Software version: 0273 Hardware number: 5Q0937084CE Hardware version: H38 Serial number: 00001830700449 ODX name: EV_BCMMQB ODX version: 019001 Long coding: 000000000000000000000000000000000000000000000000000000000000 Trouble codes: No trouble codes found --------------------------------------------------------------- 13 Adaptive Cruise Control System description: ACC BOSCH MQB Software number: 5Q0907572P Software version: 0682 Hardware number: 3QF907572A Hardware version: H11 ODX name: EV_ACCBOSCHVW416 ODX version: 002008 Long coding: 330067C159FFC728949C810580400600000000000000000004 Trouble codes: U112200 - Databus implausible message static U112300 - Databus error value received static U112300 - Databus error value received static U112200 - Databus implausible message static --------------------------------------------------------------- 15 Airbag System description: AirbagVW21 Software number: 5Q0959655BJ Software version: 0339 Hardware number: 5Q0959655BJ Hardware version: 006 Serial number: 003VWR4P26VW ODX name: EV_AirbaVW20SMEVW37X ODX version: 002160 Long coding: 98CCC000000000005C0000CF00C800000065 Subsystems: System description: BeltPretRevFL Software version: 0350 Hardware version: H37 Serial number: 34169677E30101820633 Long coding: 333135 System description: BeltPretRevFR Software version: 0350 Hardware version: H37 Serial number: 34169676E30101820128 Long coding: 333135 System description: SideSensor_Df Software version: 0887 Hardware version: 001 Serial number: 35700000000ED664853V Long coding: 2D2D2D System description: SideSensor_Pf Software version: 0887 Hardware version: 001 Serial number: 358000000003C768B53S Long coding: 2D2D2D System description: SideSensor_Dr Software version: 6149 Hardware version: 004 Serial number: 3510001222B805A2D64W Long coding: 2D2D2D System description: SideSensor_Pr Software version: 6149 Hardware version: 004 Serial number: 3520001102B72255078I Long coding: 2D2D2D System description: FrontSensor_D Software version: 6149 Hardware version: 004 Serial number: 3550001262B81A85C676 Long coding: 2D2D2D Trouble codes: U112300 - Databus error value received static --------------------------------------------------------------- 16 Steering Column Electronics Trouble codes: No trouble codes found --------------------------------------------------------------- 17 Dash Board System description: KOMBI Software number: 5G1920791B Software version: 4191 Hardware number: 5G1920791B Hardware version: 403 ODX name: EV_DashBoardVDDMQBAB ODX version: 009058 Long coding: 27E50108678C8E000188FB031401000800000000 Trouble codes: U112100 - Databus missing message static --------------------------------------------------------------- 19 Gateway System description: GW MQB High Software number: 3Q0907530Q Software version: 4344 Hardware number: 3Q0907530C Hardware version: 439 Serial number: 0008609595 ODX name: EV_GatewNF ODX version: 013044 Long coding: 030100047F085700FB00005C1C0B00010001070000000000000000000000 Subsystems: System description: J367-BDMHella Software version: 9070 Hardware version: H10 Serial number: 5653589504 System description: E221__MFL-DC1 Software version: 0052 Hardware version: H11 Serial number: 29180002519230038431 Long coding: 2DFFFF Trouble codes: U021200 - Lost Communication With Steering Column Control Module static U106600 - Radio No Communication static U112600 - Undefined control module No communication static --------------------------------------------------------------- 33 OBD-II Trouble codes: No trouble codes found --------------------------------------------------------------- 37 Navigation System description: MU-S-ND-ER Software number: 3Q0035874C Software version: 0891 Hardware number: 3Q0035874C Hardware version: 853 Serial number: ODX name: EV_MUStd4CDELP ODX version: 001001 Long coding: 02731001FF00000051110101008808001F0506F6012000008E Subsystems: System description: ABT_Std-2_Nav Software version: 8130 Hardware version: H52 Serial number: VWZ6ZHV2951812 System description: ECE1 2019/20 Software version: 1115 Hardware version: --- Serial number: -------------------- Trouble codes: No trouble codes found --------------------------------------------------------------- 42 Door Electronics Driver Side System description: TSG FS Software number: 5Q0959593F Software version: 0287 Hardware number: 5Q0959593F Hardware version: 001 Serial number: YE007RIT18097 ODX name: EV_DCU2DriveSideMAXHKLO ODX version: 001010 Long coding: 003B0220D001048000001000 Trouble codes: No trouble codes found --------------------------------------------------------------- 44 Steering Assistance System description: EPS_MQB_ZFLS Software number: 5Q0909144AB Software version: 1082 Hardware number: 5Q0909144AA Hardware version: 131 ODX name: EV_SteerAssisMQB ODX version: 015157 Long coding: 00020000 Trouble codes: B116854 - Steering angle sensor No basic setting static --------------------------------------------------------------- 52 Door Electronics Passenger Side System description: TSG BFS Software number: 5Q0959592F Software version: 0287 Hardware number: 5Q0959592F Hardware version: 001 Serial number: YE007RIS03513 ODX name: EV_DCU2PasseSideMAXHKLO ODX version: 001010 Long coding: 003B0020DC01048000001000 Trouble codes: No trouble codes found --------------------------------------------------------------- 56 Radio System description: MU-S-ND-ER Software number: 3Q0035874C Software version: 0891 Hardware number: 3Q0035874C Hardware version: 853 Serial number: ODX name: EV_MUStd4CDELP ODX version: 001001 Long coding: 02731001FF00000051110101008808001F0506F6012000008E Trouble codes: No trouble codes found --------------------------------------------------------------- 5F Information Control Unit System description: MU-S-ND-ER Software number: 3Q0035874C Software version: 0891 Hardware number: 3Q0035874C Hardware version: 853 Serial number: ODX name: EV_MUStd4CDELP ODX version: 001001 Long coding: 02731001FF00000051110101008808001F0506F6012000008E Trouble codes: No trouble codes found --------------------------------------------------------------- 75 Telematics Communication Unit System description: OCULowMQBLGE Software number: 5NA035284C Software version: 0824 Hardware number: 5NA035284C Hardware version: H19 ODX name: EV_OCULowMQBLGE ODX version: 004049 Long coding: 02730001EA42180D3F1CBE000045400382E608 Trouble codes: No trouble codes found --------------------------------------------------------------- 76 Parking Assistance System description: PDC 8 Kanal Software number: 5QA919294C Software version: 0050 Hardware number: 5QA919294 Hardware version: H07 Serial number: 00030841801830251165 ODX name: EV_EPHVA18AU3700000 ODX version: 009039 Long coding: 0471151811 Trouble codes: No trouble codes found --------------------------------------------------------------- A5 Front Sensors Driver Assistance System System description: MQB_B_MFK Software number: 3Q0980654H Software version: 0272 Hardware number: 3Q0980654A Hardware version: H09 Serial number: 13081815K12804 ODX name: EV_MFKBoschMQBB ODX version: 001001 Long coding: 0003070000000401000213448150A90094000E000020 Trouble codes: U112300 - Databus error value received static C10ACF2 - Steering Interface for lane departure warning system not coded static
My CLT-L09. On O2.
I will pay any of you if you can help me plzzzzz 😞
James
^^^^ hmm.......... from the report, it looks like your vehicle is in need of a calibration of the steering angle sensor - I reckon!!!
I'm more than happy for you to bring the car down here  (it's not far to Melbourne Australia - just keep driving South and if you get to Tasmania, you have gone too far), but it ain't rocket science to recalibrate the steering angle sensor
I'm writing this from memory, but you could try this (it's best to do the procedure with the engine running):
  1. Fire-up the OBD11 software and connect to the dongle.
  2. Go to the control module list and select Steering Assistant (@ address hex44)
  3. Select Basic Settings
  4. From the options list (see below - yes the screenshot is from old OBD11 software) select Steering angle sensor
  5. Start the basic setting procedure
  6. Turn the steering wheel slowly to the right and then to the left mechanical stop.
  7.  Turn the steering wheel back to the mid position,
  8. Wait for the procedure to show finished
  9. Clear the error message(s) in the control module(s)
  10. When you have successfully completed - pat yourself on the back for a lesson well learned (don't press the factory reset option) and go to the pub for a frosty jug (or 2) !😉
I'm a VCDS man so can't help you with OBDeleven, but as above you will need to do a steering angle sensor calibration.
Once done clear all fault codes in all modules.
Hopefully you won't have to do a front assist (ACC) and lane assist calibration - as that i'm afraid is a trip to the stealers or an alignment shop with the latest hunter gear.
This is the problem with OBDEleven - they have made tweaking ya car nice and user friendly, yet still left the ability to royally F it up amongst the fluffy app options.
VCDS on the other hand looks intimidating and to the uninitiated it feel's like ya walking through a mine field - which is the way it should be, it should never have a fluffy interface, it should be hardcore and scary - so only those who know what they doing dare venture outside a few little tweaks.
With OBDEleven, anything outside some basic harmless tweaks should be tucked away in a separate section which should look nasty and scary and come with a governmental health warning.
Blower: Don't get me wrong - I reckon that VCDS is a very admirable piece-of-kit, but be under no illusion - it's just as easy to select "Factory reset" with any of Uwe's Ross's devices.  The facility is a product of the control module design, it's not a consequence of any particular cable (be it OND11, VCDS, VCP, or any other diagnostic cable)
I have suggested to both manufacturers that a warning message be added to their devices when a user selects "factory reset" - the message would not stop selection of this option, it would just confirm that user actually wants to select the option and it would give a warning of the possible consequences.
Alas, it seems that the voices of others are needed for my suggestion to happen!!
Oh with VCDS it's very easy to annihilate everything and mess ya car up to a far greater degree than OBDEleven.....that's the point i was making, it's hardcore and looks it - you are under no illusion with that 'app' that you should go messing where you don't fully understand what you are doing.
Where as OBDEleven lulls you into a false sense of security with it's nice fluffy interface and it's in-app purchases as if it's some form of game.
Hi Don I tried the above both fast and mega slow and I didn't get a completed message :(
could an electrical failure cause this 😜😜😜😜😜
james
Whilst I think it’s great that people push the envelope in these things, after all you don’t know until you try!  I think for the average uninitiated Joe/Josephine user, a little bit of common sense goes a long way - no offence at all to the OP intended.  There’s a lot of excellent info out there on obdeleven (obdeleven pro boards, car forums etc) where there’s both plenty of expert informed coding, and shed loads of tried and tested coding by end users, that if you get that “shit! I’m not sure I should be doing this” feeling when your finger is hovering over an unknown, little tested or untested option, then it’s probably best to listen to that inner feeling, and stop!  😁
OP, I do hope you get it sorted either with help from experts/obdeleven practitioners, or just head down and get VW to sort it so you can get back to driving your car.
