Peterb3n
Jb4 installation query
9 hours ago, SpursMadDave said:
Top Man!
How are you enjoying the Merc, made any changes yet?
Thanks Dave 👌
Yeah i'm enjoying it a lot thanks. 1,500 miles so fully run in now and goes well but most of the time I drive it in comfort mode, believe it or not none, only thing I've done is fitted my dash cam to it. Couple of people doing maps for them now though and Milltek now have an A35 development car (hope to see that at Car Fest this weekend) so I think extra power could be on the cards soon 🤣
Thanks Dave
On 30/05/2019 at 16:51, Rob2k68 said:
I have ordered parts to make 4 extensions, happy to post to Canada emoji1063.pngemoji106.png
HI Rob,
Just put my JB4 back on after the service and D plug is a bitch..sometimes!
-Although jacking the car up made me change tyres front to rear ( yes I did both sides before you start🙄)
Send a set of ‘D’ extensions down to Perth, Western Australia..?
Paypal or whatever you need..?
-Yep not enough posts to message you yet.
(im a reader not a poster..😆)
HI Rob,
-Although jacking the car up made me change tyres front to rear ( yes I did both sides before you start)
(im a reader not a poster..)
It sure is - I made my first one after some road kill ripped a hole in my sump and my car was recovered to a main dealer but I had no way of removing the JB4
Tonight I will have 4 made up , one is reserved for amozza20.
I don’t mind posting abroad at your cost. I make the AFR loom for post and pre WLTP cars to save using the posi tap and usually knock a couple of ££ off if buying both.
Keep your eyes peeled for ads appearing soon in the classifieds section.
Pre WLTP AFR loom :-
Post WLTP AFR loom :-
Plug D extension:-
Note: cloth tape has now replaced the short lengths of cable braid for a more OEM look.
Hi Rob
Are you still making these, specifically the AFR harness? I have a mk7 R and am waiting delivery of a JB4. I’d be interested in one of your AFR harnesses which means you don’t have to posi tap the OEM wire.
Hi Rob
Can recommend the D plug extention too as it means you only have to take the u undertray off the once, makes removing the JB4 a very quick job indeed
On 23/05/2019 at 07:03, Rob2k68 said:
I generally keep the connectors in stock to make an AFR (02 sensor) loom which saves the need for using the posi tap. I have parts to make both pre and post WLTP versions.
For the Plug D extensions these are a lot more time consuming so once set up I make batches of 5 or 6 and these are generally pre ordered and paid for. I did say I wasn’t going to make any more LoL but if I get sufficient interest then I may do so drop me a PM if interested WLTP looms are £28 and extensions £38 + postage.
Rob, I’d be interested to buy an extension if you’ve got one to sell, happy to pay today. Cheers
3 minutes ago, Bainzy said:
Also can’t pm, stupid really. 🤔
You  need to great your posts to over 25 to access these facilities.  Just Get posting.
  • Similar Content
    • By ellixtt
      My plan was originally to go with a proper Stage 1 remap with DSG map but having read about the issue with turbos blowing and the cost of repair I decided against it.
      I have been trying to look for any turbo failures from JB4’s but I cannot find anything, so I may go down this route.
      Can anyone shed any light on if this is the case? JB4 is let’s say safer somewhat in terms of turbo failure?
      (65 Plate DSG 24k mileage - 722H turbo)
    • By ellixtt
      So in August I traded my Manual 7R in for a DSG one (65 plate with 23k on clock), I bought the DSG for many reasons but mainly due to wanting to take it to Stage 1. After doing lots of research now I am slightly hesitant
      Would turbo failure be less likely on a car which has more miles problem free? I understand there is an issue with balancing but would this have become apparent earlier or are turbos still just as likely to blow on high miles - This goes for after going stage 1 too?
      I currently have 722H
      £1-2k is hefty (for me) so on one hand I'm thinking leave it but on the other I know there are many people out there running tunes with no issues whatsoever! A DSG map is definitely on there cards though without a doubt.
      ** PS apologies I know the turbo failure topic has been beaten to death 9 billion times **
    • By Dominic
      Afternoon guys and girls!
      As you can tell by the title I’ve gone and done it, I took the plunge and brought a JB4 (thanks to @roberth for the quick delivery)
      It’s seriously no joke, I proudly own a 2016 Lapiz blue manual Golf R and after fitting it (which was actually easy, yes you have to plug a connector at the bottom after removing the tray but that took 5 mins). The next morning I drove to work, after a few miles I hit the dual carriage way and opened her up, she went like the clappers, honestly day and night difference!
      Since then I’ve moved to map 6 as I’m told it’s a bit easier on the clutch, the output still blows my mind and having my catback system makes it sound amazing when it peaks boost, even the odd pop off the throttle!
      Now I haven’t played too much with the settings as they do throw me off so I’ve come here for some advice, what’s the best thing/s for me to change in the app, the only mod I have is a cat back, I’ve sent off a couple logs to @[email protected] for some feedback too.
      Dom👍🏼
    • By Has7rr
      Hi guys , im new to the forum.
      I have a mk7 golf r and i am currently running a jb4 with a resonator delete, vwr600 intake , silicone hose and turbo inlet elbow from racingline.
      I would like to get a downpipe next ,but im not sure as to which would be the best for not throwing any cel lights up.
      Do you need a sports cat such as the bcs 200cell cat or can you just purchase a a downpipe without  the cat.
      Cheers for any help in advance.
    • By Dominic
      Hope everyone’s having a good weekend!
      Im looking to invest into a JB4 soon after hearing so many good things about them, I almost went down the DTUK road but I’ve heard a lot of reports of them leaning out, whereas the JB4 controls the AFR’s and Fuelling. (ps if anyone is selling one secondhand I’ll buy it)
      My R is a 2016 Manual model, all stock apart from a Custom built cat back which some of you may have seen or even heard.
      Im planning on installing the JB4 to reap the benefits of the power gains and logging, but I’m curious to know if I install a decat downpipe will the JB4 take care of this i.e no EML or putting it into a limp mode?
      Sorry in advance if this has been covered, I’m new to the JB4 and if I’m honest the user interface is overwhelming with things to adjust  and the forums are split with people saying the JB4 does/doesn’t sort out a decat Downpipe,
      regards,
      Dom
