Mk7 Bluetooth headaches
thanksabunch
Evening
I recently got new phone
whenever connect it to car it works fine until turn engine off, come back half hour later and it’s forgotten phone and started searching for old phone!
have deleted other phones numerous times but soon as leave car and return the old phone is back on there!
Also always reverts to playing radio 1 regardless of what station or SD card album I was on when turning car off!
Been told it could be software update needed but just asking here see if anyone else has experienced similar? and whether software update sorted it!
65 plate car with Non Nav unit fitted
Evening
I think it is almost certainly an update required, cant hurt to get it done and see anyway. If the unit is fubar dont get a new one from VW get a CP removed one as it will be way cheaper!
Thanks mate
yes my plan would be to get a used unit and have someone code it to car etc!
Unsure if the potential issue would be with the screen part in dash or the actual sd card module thingy in glove box!
Thanks mate
The screen is just that, a screen so only faults with that would be display related, any software issue would be the unit in the glovebox
Hopefully a free update from VW will sort it out, dont forget to ask them to update the Nav while you are there too...
2 minutes ago, SpursMadDave said:
The screen is just that, a screen so only faults with that would be display related, any software issue would be the unit in the glovebox emoji106.png
Non satnav unit mate!
unsure if would be free update too as 3.5 years old so expired warranty now 😞
4 minutes ago, R-Estate said:
Have you tried a unit reset?
Yes tried it few times mate
no joy unfortunately
frustrating thing is phone pairs up perfectly
just once car is switched off it forgets the phone
Tried Missus’s  phone too
- exactly same happens
Sounds like it is just clearing the memory each time you turn off the ignition, I'm sure I've read of others having similar issues and it getting sorted with an update
Bummer. Sounds like you’ll need to visit a dealer to have the firmware updated it unless you can find the latest version on-line.
