KAR_120C Posted September 26, 2020 Report Share Posted September 26, 2020 20 hours ago, SpursMadDave said: Nice find, I will just keep using an older device anyway but hopefully it might get an update Sent from my VOG-L09 using Tapatalk And tonight my copy of Torque updated to an Android 11 compatible version. 😁 Now I can try that oil temp PID tomorrow.... SpursMadDave 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 27, 2020 Report Share Posted September 27, 2020 And tonight my copy of Torque updated to an Android 11 compatible version. Now I can try that oil temp PID tomorrow....Nice Sent from my VOG-L09 using Tapatalk Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 28, 2020 Report Share Posted September 28, 2020 Had a play around with different dials stonefish 1 Quote Link to comment Share on other sites More sharing options...
EPV77 Posted December 14, 2020 Report Share Posted December 14, 2020 (edited) @stonefish , would you be able to disclose how you go about finding the equations for custom PID's . Thinking of generating a long list of more values for members on here. Edited December 14, 2020 by EPV77 Quote Link to comment Share on other sites More sharing options...
stonefish Posted December 16, 2020 Author Report Share Posted December 16, 2020 Most of the equations are pretty similar and many don't need converting.: Check out OBD-II PIDs - Wikipedia I use VCDS and a CAN BUS logger to get the command strings used for torque pro. The equations are worked out from the VCDS log values. e.g. Exhaust temperature bank 1, request value is 22 F4 3C reply is 0D 3F which is 3391 and VCDS says 339.1 degrees therefore equation is (A+B)/10 Quote Link to comment Share on other sites More sharing options...
KAR_120C Posted December 16, 2020 Report Share Posted December 16, 2020 10 minutes ago, stonefish said: e.g. Exhaust temperature bank 1, request value is 22 F4 3C reply is 0D 3F which is 3391 and VCDS says 339.1 degrees therefore equation is (A+B)/10 Shouldn't that be (256 * A + B ) / 10 ? Quote Link to comment Share on other sites More sharing options...
EPV77 Posted December 17, 2020 Report Share Posted December 17, 2020 Some equations are easy, but not all. How did you figure out the oil temperature equation as it's not as obvious , (((A*256)+B)-2731)/10 Quote Link to comment Share on other sites More sharing options...
KAR_120C Posted December 17, 2020 Report Share Posted December 17, 2020 43 minutes ago, EPV77 said: Some equations are easy, but not all. How did you figure out the oil temperature equation as it's not as obvious , (((A*256)+B)-2731)/10 I not sure how the original chap did it, but that is the same basic equation, convert the two bytes to a decimal number. The result is the temperature in tenths of Kelvin, so subtract 273.1 (x10) to convert to tenths of Celsius, and divide the answer by 10 to get Celsius. Quote Link to comment Share on other sites More sharing options...
EPV77 Posted December 17, 2020 Report Share Posted December 17, 2020 Doing some work on MED17 equipped vehicles, most equations from Simos18 don't work. The main (A*256)+B part of the equation must be different. Quote Link to comment Share on other sites More sharing options...
Quest Posted January 26, 2022 Report Share Posted January 26, 2022 On 9/26/2020 at 4:18 PM, stonefish said: Created a PID file for Engine Oil temperature. I've not got round to testing it yet as a bit busy. https://www.dropbox.com/s/1fjl8cqoj5xryjy/oil-temperature.csv?dl=0 Oops, I left FL in "short name" please ignore or DIY edit. Hello! I have a big request. I used your PID for oil temperature and DSG temperature, but it doesn't work on my car. I have a 2.0 TSI engine (DKZA) and a MIB3. Can you help me? I don't know where to look anymore .... 🥺 Quote Link to comment Share on other sites More sharing options...
Fero Posted March 19, 2023 Report Share Posted March 19, 2023 On 16/12/2020 at 18:21, stonefish said: Most of the equations are pretty similar and many don't need converting.: Check out OBD-II PIDs - Wikipedia I use VCDS and a CAN BUS logger to get the command strings used for torque pro. The equations are worked out from the VCDS log values. e.g. Exhaust temperature bank 1, request value is 22 F4 3C reply is 0D 3F which is 3391 and VCDS says 339.1 degrees therefore equation is (A+B)/10 Im very sorry to reopen a dead post but can you explain how you're doing that? I was inspired by you to try this and actually did but have no idea how to read the Can Bus logs I was able to sniff. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 13 Report Share Posted April 13 Found an old Android 13 phone so set up AATorque ahead of my trip to Wales next month, all working perfectly 👌 Quote Link to comment Share on other sites More sharing options...
