NRW
Tyre Buying Guidance, Tyre Deals and Tips.
My fronts got flagged up by VW as being 'low on tread' recently.
14,000 miles from factory with 10 laps of a certain big green circuit in Germany
Swapped to PS4s on just the front for now and the road noise is SO much more improved! I never thought there'd be such a difference from just changing one axle - and against a similar 'premium' brand.
Conclusion: Bridgestone Potenzas are useless and by supplying them with the car, VW makes a worse car.
In my experience new tyres always sound quieter than old tyres.
Not enough comments are posted about noise levels after
a few thousand miles as I’ve noticed there can be big differences
once they are worn in.
Very true.
its not the actual general noise that people may pick up on, but the absence of certain frequencies and  these coupled with vibrations generated by the tyres on the road. Put new tyres on and you eliminate these, the actual reduction in overall noise may actually be minor.
there are also not enough tyre tests carried out when tyres are at 4mm and 3mm.
this is often where you really see the difference between a cheaper and more premium tyre.
the difference in tyre performance between new and 3mm, is quite shocking and puts winter - summer difference as minor.
there needs to be more emphasis on non straight line braking but include lateral, the type where you brake coming around a corner.
tyre performance between various manufacturers changes as you hit 4-3 mm level.
there is just far far to much emphasis placed on costs and getting as close to the magic 1.6mm limit.
costs, rather than how much risk do I want to put my family in by driving with these tyres.
A new member for the MPS4 Appreciation Society. Interesting about the reduced noise.
Michelin  really need to start offering Periodically, a Group Discount to R people.🤞
10 hours ago, Gavras said:
Very true.
I couldn’t agree more. The wife’s car is an Evoque and I took it to work in the snow earlier this year. The rears were the originals and 30,000 miles in with 3mm of tread. Parked in snow on a level driveway, and tried to pull forward to and just spinning the rears. New tyres fitted and there is nowhere it won’t go.
Hence why Winter tyres need changed at 4mm, in some EU countries its illegal driving on winters with less than 4mm.
Probably why we’re seeing a wave of half worn winter tyres coming through in the uk as regular part worn A grade.
That's thing though for winters in snow, 4mm / 3mm is definite change time.
its really wrong to call them half worn, more like 75-85% worn.
you see it a fair bit with SUV drivers on worn winters, confused why they get stuck lol.
Exactly 👍
One of My local Tyre fitting/suppliers were Taken a back when I answered his statement of “ we’ve a load of excellent winters just come in at £30 fitted for your size “ 🤔🤨
I wouldn’t have those fitted if they were free and My conti 5 on 5mm will do a better job thanks.
They were half budget god knows who I’d never heard of , all at 3-4mm and they were selling like hot cakes.
Major RTA waiting to happen as some unsespecting customers will think they have all the grip in the world now and ready for winter 🤨
Theyre leathal in the wrong situation especially come summer time when these customers are running them to the legal limit.
but then again 90% of them couldn’t care less until there hedge bound backwards..these tyres should be destroyed in the country of origin but the good old Brits love um 😳
27 minutes ago, JoeSepi said:
How have people found the wear on Michelin Pilot Sport 4 S, 19" mine have seemed to wear down on the outer edge on the fronts, is this normal for these or are my wheel spacers causing the problem?
Pretty much any tyre 'should' wear evenly across the surface.
usually incorrect pressures or an element of tracking being out changes where main contact area is.
however driving types and area do as well.
yes potentially, they could, worth getting full check carried out, usual hunter stuff.
Very even wear on my PS4S and they’ve been on for a good several thousand miles now and tread depths checked regularly.
I’d check your tyre pressures first if you are getting quite uneven wear and if not that then a full alignment check is a good idea.
Outer edge wear is typically either under inflated tyres (if both outer edges of each tyre) or they are toe’ing in more than they should be...
Can just be from very enthusiastic cornering too though - is throwing it at corners and messing with understeer.
For what it’s worth the circa 40k miles ive done in my R(s) the tyres have worn evenly so suggests to me either tyre pressures and/or alignment need checking
  • Similar Content
    • By GolfRWag
      Hey all - just had my first service at nearly 1 year/15 000 km, rotated tyres front to back and checking the tread they look pretty evenly worn in to out etc.
      Tyres are Continental CSC5 235/35/19 inch on my 2018/MY19 Golf R wagon. I don't race it or overly flog it every single minute - largely sensible schlepping to work and back in traffic with occasional longer freeway/country trips. They seem to grip quite well, corner consistently at pretty high speed though they drone a bit on our notorious coarse-chip Aussie roads at times.
      But the tread-wear indicators show only about 4-5 mm to go (being generous) and makes me wonder what average tyre life is like for these tyres?
      Fellow R owners on here got any experience with the likely Km life you have got out of this particular model tyre?
    • By ReapSTAR
      I have used a set of MPSS and now a set MPS4S.
      My conclusions :
      Michelin Pilot Super Sport - Good tyre all round, excellent tyre lifespan , excellent grip wet/dry
      Michelin Pilot Sport 4S - Good tyre all round, shit lifespan, excellent grip wet/dry
      Anyone else have similar conclusions?? I swear my set of MPSS lasted in excess of 25k miles. The fronts didn't last as long obviously but I put the rears onto the fronts and they lasted AT LEAST 25k miles in total... the MPS4S have lasted not even half of that!
    • By Booth11
      Tyre dressing is a regular discussion point amongst detailing enthusiasts. There are loads around but surprisingly few of them are very good. If they look good, are easy to apply etc, they tend to be lacking in longevity. And some of them are prone to slinging.
      If anyone is looking for very good tyre dressing that gives a really superb finish, is extremely long lasting too, easy to apply and no sling - this one is well worth a look - Hi Shine Long Life Tyre Dressing https://www.achemshop.co.uk/product/hi-shine/
      I've been using it for quite a while from when it was called Quarts Tyre Dressing. Quarts is no longer around but the same product is now available direct from the supplier 'achem' under the name Hi Shine.
      Previously I've tried all sorts in a search for a dressing that combines a great finish with superior longevity. But, as said, if they delivered on one aspect, they disappointed on the other. So I kept returning to trusty Meguiars Endurance gel which is good but not very long lasting - 2 weeks absolute tops. Then Hi Shine came onto my radar.
      It's a solvent based formula, containing silicone, but thinner than most other silicone dressings, so it applies very easily - goes on more like a water based gel, but with the lovely finish and repellency you get with silicone formulas. And it lasts and lasts and lasts - product info states durability is 2-3 weeks but I would say more like up to 4 weeks, which is good for a tyre dressing. And no sling at all. Despite its slightly misleading name, it's actually incredibly versatile in terms of finish and can be anything from matt/satin - satin - gloss depending on how you apply it and how many coats you put on. For a matt finish, give a thorough wipe over after each application. For a satin finish, give a light wipe over each application, and for a shine, skip the wipe down altogether. Whatever finish you prefer one coat gives a great finish, two coats even better.
      I apply it using a foam pad and then wipe down lightly afterwards with an old microfibre, as I prefer a satin finish opposed to hi-shine. Usually I do two coats, time permitting. Here's how it looks:
      On Golf R
      On previous GTI
      And even nearly 5 weeks after application, on a very dirty car, the dressing (though diminishing) is still evident, despite the wheels being subject to some very muddy sites and conditions
      achem do quite a few other car products too and I have also used their Snow Storm snow foam which was very good. My preferred one is still Valet Pro Advanced but the achem one did a good job. Got pics of it on a car if anyone wants to see what it looks like.
      Anyway, what are other people's go-to tyre dressings?
    • By Wagon R
      It seems like Goodyear are going all out to tackle the might of Michelin, who have been taking all the plaudits for performance summer tyres recently. They're releasing no less than 4 new tyres in short order.
      The Eagle F1 SuperSport comes in 3 tiers (Road, Track & Race focused), and the Eagle F1 Asymmetric 5 completes the new range.
      SuperSport Details: https://paultan.org/2018/12/13/goodyear-eagle-f1-supersport-three-tier-uuhp-tyre/
      Asymmetric 5: https://paultan.org/2018/12/07/goodyear-eagle-asymmetric-5-new-uhp-tyre-shown/
      As a longtime Eagle F1 user, I can't wait to read the comparison reviews. 🤗
    • By ALS391
      I'm looking for my winter tyres and wondered if anyone has had any experience of 19's Vredestein on their R ?
      There's a few threads about winter or not or all weather so this is not another on that subject, I am defo a fan and need them having used them on my last 6/7 cars.
      What I like to do is keep the same size and if poss speed rating so has not to involve the insurance company but obviously I don't intend doing 155mph on them.
      So I used Vredestein's on my A-class Merc grip in wet / snow fantastic BUT last year towards the end of the season I got eggs on 2 seperate tyres, because of this I  decided not to use them this year but now I've got the R they do seem to be the only fitment available so I might have to.
      Or can anyone recommend any other makes WINTER only in the R fitment 235 35 R19 ?
