Jeff R
Exhaust valve coding out on a 2019 R
Tried to do this via the usual coding method that’s previously worked no problem  I em on my 3x Mk7’s ... but on my 2019 R it will not accept the coding
heres the code I’m using on a genuine new VCDS cable
1 – Engine module
Exhaust Flaps deactivate
Byte 9
Bit 2 - Exhaust Flaps installed, uncheck box to deactivate it and save as usual.
Thanks for confirming that marshy,
Strange
I’m now unsure about unplugging them whilst the cars in sport with having no VCDS support, just in case something goes wrong ...
For me it isn't a problem - but I'm sure to some people it is, but for me I always cycle through to race mode after starting up. It appears to me that it is not just the valves that get triggered when you cycle through modes, but all maps. You default to normal every time (in my 2015 7R at least), so even if it says race mode because you left it in race mode, you're actually driving in normal mode, engine map as well as every other change the different modes make.
That's why I just cycle to race mode every time. If I simply coded valves always open, I'd still have to cycle to race mode anyway.
Do you actually need to change the drive mode or just quickly cycle through them?
Just cycle through them. You can do it after switching on the ignition, or after starting the engine.
But different cars might be different depending on DCC, whether it is tuned etc. When my car was stock I couldn't tell any difference in engine response whether I was in normal or race mode. But at stage 2 there's a noticable difference.
Normal mode seems to behave like race mode for acceleration, but race mode has much stronger engine braking. I could be wrong about coding valves open making a difference to stock cars with this in mind.
But in any case it is one way to always have the valves open :)
