larsc2
No oil temp. in MFD Golf MK7 R
Good morning,
I own a Golf 7R my 2015 and am unable to display the oil temperature in the MFD display.
Before this I had an Mk6 GTI and it worked properly.
What I did to try to get it working:
- VCDS oil sensor installed (already checked)
- Read oil temp in VCDS: via the engine adv measuring values I get a temperature of the oil neatly at location IDE00196 (20 degrees C, engine was just on, but you saw temp. Rising)
Via channel 17-Instruments I can also read location IDE00196, but on this I get a fixed value of 197 degrees C
I think that it is the same sensor; since they are in the same location, the instrument computer does not get the same (or any) value from the engine computer.
Oil temperature is also not available in the MFD settings; only when I reset everything to factory settings do I get the oil temperature in the menu; but keep displaying "---" no matter how long I drive. After switching off and restarting the car, the temperature is also gone and I cannot turn it on in the settings.
So something is not going well, but I have no idea where to look for it. Someone who has experience with this?
Thanks in advance!
Edited by larsc2
The only coding i could find was this:
The following coding is to be used:   Select STG 17 (control panel) STG Long coding -> function 07 Byte 10 Activate bit 1
This was activated already..
larsc2: hi. Try this:
  1. Select Instrument module @ address hex17
  2. Select Security Access-16 and enter the magic number 20103
  3. Select Adaptation- 10
  4. Enter "IDE00295" into the search box and select IDE00295-Oil temperature display,
  5. change setting to on
Can't help with the coding but interesting to see the oil temp on my p3 gauge from cold whereas the stock one stays blank until 50... I've had both on together and the stock one is actually lower at 50 (shows 60) and evens up by around 100 probably this is on purpose a bit like speedo showing higher than GPS...
Lowest I've seen it is I think 6 [emoji15]1a3a10edc885daf507ad1018fc1acabf.jpge376e1b5e31b0fdd0892e803eeb145f2.jpg
Hi Don,
Thanks for the reply, I gave it a try and the setting was already ON.
I have made a controller channel map of channel 17, does this help?
IDE00295-Oil temperature display	On
IDE00301-Distance	88302 km
IDE00342-ESI: Resetting ESI	no warning
IDE00343-Language version	Dutch
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK	Manual reset
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel	MFA3-Reset
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas	MFA3-Reset
IDE00345-MAS12879-MFA3-Reset-Nachtankerkennung Elektro	MFA3-Reset
IDE00499-Display correction of consumptions and operating range	100%
IDE00500-Hour	12 H
IDE00501-Minute	48 min
IDE00502-Year	2020 yr
IDE00503-Month	5 mon
IDE00504-Day	7 d
IDE00510-ESI: distance driven from inspection	12403 km
IDE00511-ESI: time from inspection	332 d
IDE00512-ESI: minimum value km-driving distance/inspection	15000 km
IDE00513-ESI: maximum value km-driving distance/inspection	30000 km
IDE00514-ESI: maximum value of time between inspections	730 d
IDE00515-ESI: oil quality	good oil quality
IDE00517-ESI: soot entry	0 km
IDE00518-ESI: thermal load	40600 km
IDE00711-Trip recorder	not installed
IDE00819-Day counter	1872 d
IDE00820-Activating and deactivating all development messages	not active
IDE00827-ESI: minimum value of time between inspections	365 d
IDE01153-SIA: maximum value of distance to service	15000 km
IDE01154-SIA: maximum value of time to service	365 d
IDE02489-Display depiction	Version 2
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration	-12.8 l
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1	-12.8 l
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	-12.8 l
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3	12.7 l
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4	12.7 l
IDE03329-Driving profiled for range remaining	10.4 l/100km
IDE03346-IDE00301-Units adjusted-Distance	Kilometers
IDE03346-MAS01230-Units adjusted-Date	dd_mm_yy
IDE03346-MAS01456-Units adjusted-Speed	Kilometers per hour
IDE03346-MAS02201-Units adjusted-Temperature	Degrees Celsius
IDE03346-MAS02957-Units adjusted-Time	24h
IDE03346-MAS03032-Units adjusted-Volume	Liter
IDE03346-MAS03034-Units adjusted-Pressure	bar
IDE03346-MAS05637-Units adjusted-Operating range consumption
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Liters per 100 km
IDE03346-MAS05875-Units adjusted-Average consumption
IDE03348-MAS01456-Speed warning-Speed	210
IDE03348-MAS01561-Speed warning-Unit	Kilometers per hour
IDE03348-IDE03348-Speed warning-	not active
IDE03349-FIX: Max. distance until next mileage-related inspection	30000 km
IDE03350-FIX: Maximum time until next time-dependent inspection	365 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection	12900 km
IDE03352-FIX: Time since last time-dependent inspection	341 d
IDE03372-Source for synchronization of time	GPS
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function	On
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time	10 s
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic	On
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless	On
IDE03568-ENG102611-Service-key settings-p_write_delay_speed	20 km/h
IDE03568-ENG103545-Service-key settings-p_write_delay_time	40 s
IDE03568-ENG104099-Service-key settings-p_write_distance	20 km
IDE03867-Deactivate seat belt warning	No
IDE04169-Display correction of consumption and operating range
IDE05930-Service notification in days	30 d
IDE05931-FIX: Reset value for next mileage-dependent inspection	30000 km
IDE05932-FIX: Reset value for next time-dependent inspections	365 d
IDE05971-Vehicle Positioning System Interface Control Module	not installed
IDE06425-Roller test bench mode
IDE06588-Ignition active message
IDE06922-No-voltage display	No display
IDE07221-Cylinder shut-off	Display
IDE08140-Driving profiled for range remaining CNG	6.0 kg/100 km
IDE08247-Driving profile for range remaining LPG	10.0 l/100km
MAS03555-Lap counter	Display
MAS03685-Digital speedometer	Display
ENG117917-BAP_Debug_Mode_Release	not_released
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1	OFF
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10	OFF
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11	OFF
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12	OFF
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13	OFF
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14	OFF
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15	OFF
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16	OFF
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17	OFF
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18	OFF
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19	OFF
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2	OFF
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20	OFF
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21	OFF
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22	OFF
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23	OFF
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24	OFF
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25	OFF
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26	OFF
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27	OFF
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28	OFF
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29	OFF
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3	OFF
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30	OFF
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31	OFF
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32	OFF
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33	OFF
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34	OFF
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35	OFF
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36	OFF
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37	OFF
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38	OFF
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39	OFF
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4	OFF
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5	OFF
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6	OFF
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7	OFF
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8	OFF
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9	OFF
ENG119875-defuel_threshold	45 l
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1	0
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2	32
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3	66
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4	96
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5	DC
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6	FD
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1	0
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2	0
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3	0
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4	5
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5	14
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6	64
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1	0
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2	0A
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3	32
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4	64
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5	96
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6	FD
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1	2
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2	2
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3	17
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4	32
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5	46
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6	64
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1	0
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2	0A
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3	32
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4	64
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5	DC
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6	FD
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1	0
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2	5
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3	32
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4	50
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5	64
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6	64
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1	0
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2	0A
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3	32
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4	64
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5	96
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6	FD
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1	5
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2	5
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3	0C
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4	17
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5	32
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6	64
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 32
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 64
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	00 C8
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 0E
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 41
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 C8
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1	0
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2	0A
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3	32
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4	64
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5	96
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6	FD
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1	1
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2	1
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3	7
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4	12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5	1E
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6	64
ENG119874-Gas_functionality	not active
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim	terminal_58xt_bus
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm	parking_light
ENG119882-init_fuel_algorithm	No
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0	15 s
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature	4 °C
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature	6 °C
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta	25 °C
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0	5.0 km
ENG102605-ENG103631-outside_temperature-P_speed_threshold	20 km/h
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off	180 min
ENG102605-ENG104179-outside_temperature-p_tendency_damping	15 s
ENG102605-ENG103335-outside_temperature-p_tendency_threshold	1.0 °C
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1	40 s
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping	2
ENG119825-Picture_Upload_Download	not active
ENG119876-Service_Key_Clear_All_Counter	Yes
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms	2
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms	5 s
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt	30 s
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF	300 ms
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms	255 s
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms	5 s
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms	6 s
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms	20 s
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms	900 s
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms	10 s
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms	3 s
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms	10 s
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ	0.20 s
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse	3
ENG109442-ENG101663-time_parameter_display-tDD15_off	0.6
ENG109442-ENG103975-time_parameter_display-tDD15_on	0
ENG109442-ENG100026-time_parameter_display-tDDWUP	0
ENG112418-ENG112412-Total operating range gas-consumption_factor	0
ENG112418-ENG112411-Total operating range gas-consumption_profile	consumption_profile_calculation
ENG112418-ENG112410-Total operating range gas-selection_consumption_factor	consumption_factor_CAN
ENG112418-ENG99298-Total operating range gas-State	not active
Elapsed Time: 00:44
larsc2: Did you set Byte 10, Bit 1 in the instrument module long code string?
Ignore the position of the box in the Binary value in my picture - I originally used the screenshot for another purpose.
