Mk1 Golf with a R conversion *build thread*
  • Replies 314
So here’s the final result (for now)   its now rolling and steering again
Following my intro in the welcome section last week, I thought I’d start a build thread about a project I’m working on at the moment.    The project involves taking a mk1 Golf and converting it
Finally the moment of truth, we are 4WD!!
Posted Images
As I mentioned in a couple of posts earlier, I have a update to share with you.
now that the main welding on the rear end has been completed, I have decided to work from rear to front.
The main focus has been the passenger floor area, which I wanted to further strengthen up a bit. The mk1 is suffering a bit of corrosion here and there.
the piece of box section added to floor is recycled from the mk7 donor, I’m hoping this will decrease some chassis flex.
With the box sections now in on both sides, I wanted to check the alignment of the subframes.
to make things a little easier to measure I made something called a trammel bar. This would allow me to quickly measure around the chassis, side to side and diagonally.
it’s two square tubes which slide inside each other, the screws lock it into position.
Satisfied that the subframes were in alignment to best of my ability. I wanted/needed final confirmation that things were right. I decided to book the mk1 in for a four wheel alignment.
this would be a true indicator on how front and rear fabrication went.
it was nice to see the mk1 out in some daylight.
Here is picture of the geometry/wheel alignment as I presented the car.
as you can see it was a mess.
I’ll explain the figures (sorry if you know all this)
starting from the top left (FRONT AXLE)
-1.17 is the front left camber angle
0.33 is the front left toe (the wheel is turning inwards)
-0.93 is total toe (both front wheel toe figures added together)
-1.26 front right toe figure (the wheel is pointing outwards)
-1.12 front right camber angle
REAR AXLE
-0.47 left rear camber angle
-0.16 rear toe ( the wheel is pointing outwards)
-0.39 overall thrust angle ( are the back wheels following the rear wheels in a straight line)
-1.61 overall toe angle of the rear wheels
-1.45 right rear toe angle ( wheel is pointing outwards massively)
-1.09 right rear camber angle
After some time adjusting, we managed the following.
as you can see the front end adjusted quite nicely
There is two additional figures in the picture, 10.21 and 10.08 this refers to caster angle. Having similar values side to side is important for high speed stability. Caster angle helps the steering wheel to self centre and it causes negative camber during cornering which helps with grip.
unfortunately the rear wasn’t playing ball, although the left rear came into spec the right rear had maxed out its adjustment.
things are fundamentally there, I just need to understand how the mk7 rear suspension works a bit better.
as everyone has said, amazing work!
this will be an absolute beast when done.
Will the lack of weight in the car in the current form effect the suspension geo much? Or will it need another check when the car is 'finihsed'.
Thanks for the post!
The suspension geometry will definitely change when more weight is added, ie fuel tank, interior and doors etc.
the mk1 is currently sitting on R estate suspension so it may turn out to be too stiff.
This Geo check was mainly to check the fabrication work, how bent things were and to make sure the car will go in a straight line.  Will definitely need setting up properly once complete with weight etc.
Cheers
22 minutes ago, v7fmp said:
ah of course, i dont know why it didnt click that it was to check alignment of your handy work.
Any rough guesstimate of its finished weight?
And is it staying red?
The hope is to stay under 1000kg.
it’s unlikely to stay red, but haven’t decided on the final colour just yet.
  • 4 weeks later...
Considering the amount and nature of the work undertaken I think getting 3 of the 4 wheels setup correctly without too much trouble is a great achievement, bravo!
I'm sure you now have some ideas on how to sort the 4th having had a bit of time to think about it? Another good test of your already finely honed logical thinking and ingenuity...
Well done,  another major step forward, and validation of the care and skill used to get this far.
I do think, though, that you're going to face a major compromise when thoughts turn to brakes, which will influence wheel size, and will, in turn, have a significant impact on the appearance, ride height, suspension and ride quality of the finished car.
I'm eager to see what you come up with.  Keep up the good work!
Hi Chris
Thanks for your post,  I’m pretty chuffed how the geometry went.
I’ve found a solution to the rear tracking issues, which I’ll be sharing in the next couple of days.
Thanks Mike,
ive seen a couple of brake kits out there, around the 290-300mm disc size.
my main focus at the moment is to try and hit my target of completing the fabrication by the end of May.
