The video that jrw posted up, and Lous pics, shows that the grommet is an integral part of the drain tube, so it’s a case of the grommet perishing. If the tube is fitted then it would have had the grommet originally. Just seems to be a weak part very prone to failing.
  • Replies 61
Folks, as the summer rains continue, it’s worth a quick check of the boot badge drain tube. I was surprised to see the end of mine had perished and almost detached completely. This is going to let wat
This video shows how to get all the plastic off. Refitting is just a reversal of the removal. You will see the pieces interlock so you need to do things in the right sequence.
Posted Images
33 minutes ago, Degsy said:
Sorted mine today, been on my mind for months and luckily local dealer had one in stock.
Thanks for all the helpful posts
Also in stock at my local dealer.  No wonder they keep good stocks of these, they know its a crap bit of kit and clearly deemed a consumable item!
On 21/06/2020 at 07:23, Microbe said:
Anyone know whether this is an issue on the estate or is it just a hatchback problem?
Just checked on mine today (June 2017 build R wagon with factory reversing camera), the grommet is still there and intact, but it seems quite hard (I expected it to be slightly soft rubber).  My wagon is usually garaged, so not much exposure to weather.
A little late but ive just checked and  all ok, present and a bit hard but ok, R wagon 66 reg with camera and garaged 👌
  • 3 weeks later...
Swapped mine over today, nice easy job if you watch the video in this thread and follow where the guy pulls the trim it comes away with a bit of effort, harder putting it back to be honest.
The drain pipe was totally perished leaving it just loose inside 5418ceae9e2a898795189ef20b35b1c4.jpgf957310b7fdd86ca7105f134c56a0549.jpgf2b0636aadfe6d6e8f969d554c3c8f1e.jpg
  • 4 weeks later...
67 Estate gone.
I suspect it was there but rubbed off on the body work. However I pulled it through a small O ring/washer and that seems to keep it in place. I do wonder though whether it will sit too proud and get destroyed. Might as well try and see what happens to it as got nothing to lose.
On 10/08/2020 at 12:45, roj1801 said:
Really simple job to do and only took about 15 minutes.  You just need to be a bit brave when taking the trim off, it requires a good pull to remove it.
Second this.  Under £6 for the part and a 15 minute job.  Quoted £70 by Inchcape Chester when picked up during their  "free" health check
  • 2 weeks later...
  • 5 months later...
Hiya.  I think this is the most recent thread on the drain hose leak problem....  I replaced mine today, but broke a white plastic clip in the process ... have ringed it in red on the photo below (photo copied from Roj1801's pics above)
Anyone else had similar misfortune and found a replacement?  I have done a bit of googling of parts suppliers but haven't found anything helpful yet.
Not sure how essential this clip is, but would like to replace it if I can before putting the trim back on.
  • Similar Content
    • By The V2
      Hi all
      Has anybody got any tips for locating a screenwash leak? I noticed that the wash bottle was empty yesterday (which is odd because I top it off every week or so with screenwash I "acquire" at work) anyway, I topped it up today and it was empty by the time I got home from work half an hour later - no level warnign light on and still screenwash coming out the nozzles - therefore I assume not 100% empty (?)
      I've had a very quick look under the car and around the wash bottle with a torch -  can't locate an obvious leak/wet spot, also absolutely zero water in the boot/tailgate etc as per the usual washer leak that was common from the mk4 onwards.
      I'm thinking of putting a very slow hose pipe in the top of the wash bottle and then watching for leaks.......other than this being karma for stealing screenwash from work, any suggestions?
      Hoping I don't have to go the whole hog and remove the wheel/arch liner etc in order to get to it!
    • By Ewansilver00
      Hi, recently purchased a mk6 golf r and I had noticed a small oil leak on my drive coming from the rear diff, upon further inspection I have found it’s not from either the diff drain plug or the haldex plug. Any help would be appreciated.
    • By TechieAli
      Am I right in thinking the cam cover is weaping/leaking here?  is this an issue I should get the dealer to rectify?
    • By Chuckiceman
      As above, my drivers side rear carpet is sodden. I did a previous thread and some said it may be the rear wiper pipework.
      I decided to take my car to the local VW dealer and they said they would charge me £74 to diagnose the issue (I’m out of warranty) which I was happy to swallow.
      Their diagnosis today was that they wanted to take all the seats and carpets out the car at a cost of over £400 to diagnose where the leak is coming from. Even though it is clearly only wet on the drivers side rear carpet which I think is a piss take!
      thought I’d have a go myself if it is reasonably straight forward to lift the rear carpets. Anyone done this ?
      Cheers
    • By SteveK
      Had the low coolant warning light come on this morning in rush hour traffic!..
      I got to work and couldn't see anything obvious, after checking this lunch i noticed the coolant pipe to the right hand side has rubbed on the airbox fin and has worked it's way through.
      Off i went to VW Leeds, after a lot of toing and froing they opened another customers bonnet where i looked and saw that this seem to be unique to my car as the other R DSG had around 1cm space.
      Question is.. is yours rubbing or have you got a gap? it looks like my rad could have moved back or the pipes twisted somehow.
