Ben1191 Posted July 5, 2020 Report Share Posted July 5, 2020 I think they just click less than i was expecting, took it for a 5 min spin and they seemed to settle in a little bit and click more now. Cheep and cheerful aha Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted July 5, 2020 Report Share Posted July 5, 2020 I think they just click less than i was expecting, took it for a 5 min spin and they seemed to settle in a little bit and click more now. Cheep and cheerful ahaThat's good then Sent from my VOG-L09 using Tapatalk Quote Link to comment Share on other sites More sharing options...
MartinP Posted July 5, 2020 Report Share Posted July 5, 2020 54 minutes ago, Leespo said: yes I had a small issue the pin hole wasnt quite large enough on the far end so had to make it ever so slightly larger as didnt want to force the plastic Sent from my SM-G950F using Tapatalk What did you use to enlarge the hole? Quote Link to comment Share on other sites More sharing options...
Leespo Posted July 5, 2020 Report Share Posted July 5, 2020 What did you use to enlarge the hole?just used a hole puncher as didnt need too much movement, just to make hole a little larger Sent from my SM-G950F using Tapatalk SpursMadDave 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted July 5, 2020 Report Share Posted July 5, 2020 just used a hole puncher as didnt need too much movement, just to make hole a little larger Sent from my SM-G950F using TapatalkI used a small drill bit carefully by hand, didn't take much Sent from my VOG-L09 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Leespo Posted July 5, 2020 Report Share Posted July 5, 2020 yep that was my 2nd option if it needed any more than just a small pushing openSent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted July 5, 2020 Report Share Posted July 5, 2020 yep that was my 2nd option if it needed any more than just a small pushing openSent from my SM-G950F using TapatalkYeah needed very little at allSent from my VOG-L09 using Tapatalk Quote Link to comment Share on other sites More sharing options...
MartinP Posted July 5, 2020 Report Share Posted July 5, 2020 Perfect, I’ll give it a go 👍 SpursMadDave 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted July 5, 2020 Report Share Posted July 5, 2020 Perfect, I’ll give it a go Just take a tiny bit off and keep trying, as they say you can always take more off but you can't out it back on! Sent from my VOG-L09 using Tapatalk Quote Link to comment Share on other sites More sharing options...
MartinP Posted July 12, 2020 Report Share Posted July 12, 2020 A small round file and a little patience did the trick 😊 Leespo and SpursMadDave 2 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted July 12, 2020 Report Share Posted July 12, 2020 A small round file and a little patience did the trick Glad to hear it, I guess as they are cast in one piece then they will vary ever so slightly and the pins being plastic flex easily, now time to enjoy them Sent from my VOG-L09 using Tapatalk Quote Link to comment Share on other sites More sharing options...
