smk82 Posted January 12, 2021 Report Share Posted January 12, 2021 Just had the car in for MOT today (which it passed), and i'd also asked the garage to check an error that we'd spotted cropping up intermittently when we started the car - stating "don't move - workshop only" - this would disappear after a while/not come up sometimes - it appeared once whilst moving. On investigation it has been apparently a known issue with the DSG box; which the garage has stated would require replacement of the unit (I thought it might have just been a software issue from what i could find from similar threads on the web) as it might be fine for 6 months, 6 weeks or 6 days.. no way of telling when it would fail.. Advised the cost would be somewhere >£850 ish This is a 2016 R estate (so the 6 speed box) - is this a fair price (independent garage here, not a direct dealer). I checked with VW direct and there wasn't any recalls for this, despite it apparently being a flagged/known issue. Alas as I'm out of warranty I'm having to pay the full whack..😭. I presume also it would just be a direct like/like replacement (i.e. they wouldn't fit the 7 speed box from the 7.5?) Quote Link to comment Share on other sites More sharing options...
slider09 Posted January 12, 2021 Report Share Posted January 12, 2021 Have a watch of this.....this is the common DSG fault and solution. Is this the same error? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Daveleach Posted January 12, 2021 Report Share Posted January 12, 2021 2 hours ago, slider09 said: Have a watch of this.....this is the common DSG fault and solution. Is this the same error? Sent from my iPhone using Tapatalk Think you’ve forgotten to attach the file/video mate. Quote Link to comment Share on other sites More sharing options...
slider09 Posted January 12, 2021 Report Share Posted January 12, 2021 Think you’ve forgotten to attach the file/video mate.Oops. Sent from my iPhone using Tapatalk Daveleach 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 12, 2021 Report Share Posted January 12, 2021 Also a few threads on the issue on here. Quote Link to comment Share on other sites More sharing options...
smk82 Posted January 12, 2021 Author Report Share Posted January 12, 2021 Thank you all, yes I came across that and after doing a little digging it appears the fault code matches that seen for the microswitch issue. I’ll have a look at sourcing the appropriate part, but does one need VCDS to clear the codes once the fix has been applied?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
goodbadboy Posted January 13, 2021 Report Share Posted January 13, 2021 17 hours ago, smk82 said: stating "don't move - workshop only" Had that same message on my Mk 7 R last year.....Replaced faulty micro-switch in DSG gear selector for $100.00.....Sorry to hear your problem is a lot more serious...and expensive.... Quote Link to comment Share on other sites More sharing options...
