Golf R gremlins
mahalo
So apparently my car has been fixed 😂 I will collect it shortly. I'm a little bit dubious about it all, and to be honest it has certainly unsettled me about its reliability making me think twice about keeping it 😟 The problem is that I love the car and there isn't really anything else i want. Will it happen a third time ? Lol
Glad it’s all done Kev.   Totally understand your concerns after the samr issue twice.  I really hope this the end of the issue on your car and that it is trouble fee from this point on.  🤞 Things like these do really cast doubt over the reliability which is a great shame as they are great cars.
Thanks Becs, that's much appreciated. Im on my way to collect it now.
First proper gremlin today.
said something like, drive to workshop, no power must have been in limp mode. Seems fixed after a restart after a rest for a couple of hours.
5 Faults Found:
23076 - Implausible Data Received from Diagnostic Gateway Module
          U0447 00 [00100000] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 8848 km
                    Date: 2024.06.23
                    Time: 20:29:15
                    Engine RPM: 1423.25 /min
                    Normed load value: 5.5 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 51 �C
                    Intake air temperature: 45 �C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 11.855 V
                    Unlearning counter according OBD: 14
                    LF_MVB_PDU_INTC_DIAG_8: 0
                    LF_MVB_PDU_INTC_DIAG_9: 0
                    LF_MVB_PDU_INTC_DIAG_10: 0
                    LF_MVB_PDU_INTC_DIAG_11: 0
                    LF_MVB_PDU_INTC_DIAG_13: 0
                    LF_MVB_BUS_INTC_DIAG: 256
23093 - Torque Restriction due to Fuel Pressure
          P102F 00 [01100100] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 9208 km
                    Date: 2024.07.13
                    Time: 15:24:39
                    Engine RPM: 1766.00 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 44 km/h
                    Coolant temperature: 105 �C
                    Intake air temperature: 40 �C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 13.964 V
                    Unlearning counter according OBD: 40
                    FAC_TPS_1_SAE: 25.0980396 %
                    FUP_H_SAE: 780 kPa
                    MAP_MES_SAE: 93 kPa
                    Engine status: Part throttle
                    TAA: 19.250 �C
                    T_AST_SAE: 128 s
                    Oxygen sensor 1 bank 1: voltage raw value O2 signal: 1.713 V
15357 - Torque Restriction due to Fuel Pressure
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 40
                    Mileage: 9207 km
                    Date: 2024.07.13
                    Time: 15:22:51
                    Engine RPM: 1416.50 /min
                    Normed load value: 85.1 %
                    Vehicle speed: 16 km/h
                    Coolant temperature: 86 �C
                    Intake air temperature: 55 �C
                    Voltage terminal 30: 13.984 V
                    ECU_STATE: SYN_ENG_IGK_ON
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Status: OK
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: Not operated
                    Cruise control switch actuation-Coding: plausible
                    Cruise control switch actuation-Limit function: not selected
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: Not operated
                    Cruise control switch actuation-Large increment: Not operated
                    Cruise control switch actuation-Control component verified: Yes
                    T_AST_SAE: 20 s
                    T_ES: 21 min
                    Calculated oil temperature: 84.0 �C
15058 - Fuel Rail/System Pressure
          P0087 00 [01100101] - Too Low
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 9207 km
                    Date: 2024.07.13
                    Time: 15:22:38
                    Engine RPM: 953.25 /min
                    Normed load value: 33.7 %
                    Vehicle speed: 1 km/h
                    Coolant temperature: 84 �C
                    Intake air temperature: 57 �C
                    Voltage terminal 30: 14.082 V
                    FAC_TPS_1_SAE: 16.8627454 %
                    FUP_H_SAE: 760 kPa
                    MAP_MES_SAE: 63 kPa
                    Engine status: Idle
                    TAA: 19.000 �C
                    T_AST_SAE: 7 s
                    Oxygen sensor 1 bank 1: voltage raw value O2 signal: 1.987 V
15059 - Fuel Rail/System Pressure
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 9207 km
                    Date: 2024.07.13
                    Time: 15:22:38
                    FUP_H_SAE: 760 kPa
                    MAP_MES_SAE: 63 kPa
                    Engine status: Idle
                    TAA: 19.000 �C
                    T_AST_SAE: 7 s
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 8848 km
                    Date: 2024.06.23
                    Time: 20:29:15
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 9208 km
                    Date: 2024.07.13
                    Time: 15:24:39
                    FUP_H_SAE: 780 kPa
                    MAP_MES_SAE: 93 kPa
                    TAA: 19.250 �C
                    T_AST_SAE: 128 s
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 40
                    Mileage: 9207 km
                    Date: 2024.07.13
                    Time: 15:22:51
                    T_AST_SAE: 20 s
                    T_ES: 21 min
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 9207 km
                    Date: 2024.07.13
                    Time: 15:22:38
                    FUP_H_SAE: 760 kPa
                    MAP_MES_SAE: 63 kPa
                    Engine status: Idle
                    TAA: 19.000 �C
                    T_AST_SAE: 7 s
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 9207 km
                    Date: 2024.07.13
                    Time: 15:22:38
                    FUP_H_SAE: 760 kPa
                    MAP_MES_SAE: 63 kPa
                    Engine status: Idle
                    TAA: 19.000 �C
                    T_AST_SAE: 7 s
Interesting fuel pressure faults. Glad it resolved itself after a "timeout"!!
1 hour ago, Booth11 said:
“Have you tried turning the car off and on again?” 😁
Oh, I loved the IT crowd. Miss it dearly.
O’Dowd still does a few thing on Apple TV, but nothing like IT crowd.
1 hour ago, dopper99 said:
These cars remind me of Windows 95. A reboot often fixes it. 🤣
Still way better. I worked on 95 a few years (during my MSc, ran numerical analysis and wrote my thesis on it)  and it was like owning an old Alfa, great while it works but required a lot of attending to.
Bit, yes, I am reminded of it every day when I turn on my car, electrically, buckle up, put on my shades, connect my phone, and only then ignite the engine 🙂
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 8848 km
                    Date: 2024.06.23
                    Time: 20:29:15
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 9208 km
                    Date: 2024.07.13
                    Time: 15:24:39
                    FUP_H_SAE: 780 kPa
                    MAP_MES_SAE: 93 kPa
                    TAA: 19.250 �C
                    T_AST_SAE: 128 s
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 40
                    Mileage: 9207 km
                    Date: 2024.07.13
                    Time: 15:22:51
                    T_AST_SAE: 20 s
                    T_ES: 21 min
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 9207 km
                    Date: 2024.07.13
                    Time: 15:22:38
                    FUP_H_SAE: 760 kPa
                    MAP_MES_SAE: 63 kPa
                    Engine status: Idle
                    TAA: 19.000 �C
                    T_AST_SAE: 7 s
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 9207 km
                    Date: 2024.07.13
                    Time: 15:22:38
                    FUP_H_SAE: 760 kPa
                    MAP_MES_SAE: 63 kPa
                    Engine status: Idle
                    TAA: 19.000 �C
                    T_AST_SAE: 7 s
@TechieAli: Hi.
Thanks for posting-up the part-SCAN - but it's far better NOT to edit SCAN reports because every piece of deleted (assumed irrelevant) data will very likely be read by someone else's fresh-eyes as being valuable diagnostic information.
With absolutely no offense to @blizzard60 and while I also hope that "it resolved itself after a "timeout"" - I suspect that it might not!!
So, my hunch is that you can probably ignore the  23076 - Implausible Data Received from Diagnostic Gateway Module error. Look at the date stamp (2024.06.23) and at the Fault Frequency (1) and at error status (Intermittent - Not Confirmed). These data-points ALL suggest that this error has a fault-category that I call an "aged fault" - meaning that this error has NOT been repeated in a "driving-cycle" since first registration in fault memory.
The remaining 4 x error codes are ALL related because the date/time stamps are diagnostically close! However, since we know nothing about the engine in this car (another consequence of posting-up a part SCAN -is this engine diesel, or petrol?) it ain't possible to comment further!
Nevertheless, the obvious place to start diagnostics is to check the the fuel pump(s) (plural because possibly this car has both a low-pressure pump in the tank and high pressure pump on the engine - maybe?). But- these type of fuel-based faults can be tricky - less probable, but still viable causes include engine timing and the build-up of gunk inside the inlet manifold
