RDash warning light has come on for steering On way home. SOS lights up, called dealer can’t get booked in until mid August for a fault diagnosis. Call VW will have to wait until tomorrow, if it can’t be fix I’ll get loan car. Great was going to Yorkshire on Friday.
I had the same recently. First there was a double pop from the centre speaker and I lost connectivity, globe and privacy setting pic disappeared, SOS light (usually green) went off and then the same error appeared, however after the ignition was turned off and restarted the error was no longer there and its been behaving itself since.  Is this the same with yours?
The popping speaker and loss of connectivity happens on every journey now, but it’s the first time I had the fault appear.  Unfortunately from what I’ve read this isn’t uncommon and so far there’s no fix, but if you get it sorted do please let us know 👍🏻
I get the double pop on the speaker within 10 minutes of setting off. The fault happen twice now. Turn ignition off it remains however when turn off a few hours it resets.
I get the double pop from center speaker on almost every journey, but today I got the SOS error for the first time with no connection to server icon.
Then after turning the car off and on I just got "loading settings" and the whole system was unusable for approx a 20 minute journey.
Then after leaving car for approx 10 minutes turned on again and everything went back to normal.
Wow, this system is so "buggy" and unpredictable, you never know what it is going to do next.
VW really need to release an update soon and pay for dealers to update any customer who wants the update as this really is getting unusable!!!
46 minutes ago, Wrex said:
I’ve already been told by vwfs they will let me reject my car as there’s no as update available to fix the errors
I wonder if this is a similar policy to the one Honda had some years ago. It gives a chance to get a poorly behaving vehicle back to figure out root cause.
I recall actually seeing a quite notorious S2000 in their UK training centre, the car had been supplied and the dealer forget to take out the spring wedges used for shipment.  Should of seen it after 500 miles on UK roads!
On 20/07/2021 at 06:58, Dannybear83 said:
My car has this sos error quite often,
I think when you turn your back on today the error will be gone,
Yep I've mentioned this on other thread that I get the double pop noise from centre speaker and a couple occasion had the Error SOS message. I've noticed the double popping whenever I drive through a area with No/Very low telephone signal near where I live, not noticed it happening in any other areas.
@MK1GTI @AndyT970 @Dannybear83 @jason1972 Be interested to know if any of you guys have noticed the double popping noise driving through No / Low signal areas?
When the “pop pop” noise comes again I will look at my signal
