Mk6 Golf R20 - LED Tail Lights - Enable Inner Tails on Brake?!
Yes…another tail light thread. This might even be the wrong place to post this, but I’ve not seen a thread with any info on this particular configuration.
Just got some new LED tails for my Mk6 R20 and desperately want the inner tails to illuminate on braking. I’ve done an insane amount of digging and came across this thread:
https://www.motor-talk.de/blogs/tba...heckleuchten-beim-bremsen-aktiv-t5216235.html
(granted it’s in German…I just translated the sections I wanted to see.) This process appears to use Vag Can Pro (VCP) to dump the BCM EEPROM to a configuration file where you’d then be able to modify the individual light settings (including enabling the inner tails and specifying brightness). My issue is that I only have “OBDeleven” and it does not have EEPROM capabilities, but I don’t want to go and buy other vag com tools if it won’t work anyway...
Can anyone confirm this on VCP? Has anyone been able to do this on the NAR Mk6 Golf R?
Edited by Sp3<7re
  • Similar Content
    • By TechieAli
      Having just tried to scan my August 19 car, it claims my Hex-Can needs an upgrade. Anyone used the interface upgrade program from Ross-Tech? Did you have to pay VAT on entry to the UK from the USA?
    • By Cruze
      What power you putting out and what have you had done so far? Also wether or not you’ll be doing anything else anytime soon, Remember to post pics of bhp figures and your car 💪
    • By stereonitrat
      Hello all,
      Could you please assist me with the most important/ urgent matters to be take care in respect of the below DTCs?
      Sorry for the fact that it is in Romanian, but I think that the DTC stays the same.
      Respect
      3  coduri de defecte:
      18825 - Pompã antigel pentru rãcire aer de supraîncãrcare
                P190E 00 [096] - alimentare
                intermitent - Neconfirmat - Testat de la ºtergere de memorie
                   împrejurãri cod:
                          Stare defect: 00000001
                          Prioritate defect: 2
                          Frecvenþa defect: 3
                          rulaj: 172244 km
                          Data: 2018.11.28
                          timp: 08:53:20
                          Turaþie motor: 1434.00 /min
                          Valoare de sarcinã normatã: 86.7 %
                          Viteza vehicul: 13 km/h
                          Temperatura antigel: 58 °C
                          Temperatura aer admisie: 41 °C
                          Presiune aer ambiental: 1010 mbar
                          Tensiune terminal 30: 14.420 V
                          Numãrãtor procese de adaptare nereuºite conform OBD: 39
      5290 - Modul de control motor clapeta de acceleraþie
                P2100 00 [096] - întrerupt
                   împrejurãri cod:
                          Frecvenþa defect: 1
                          rulaj: 172238 km
                          Data: 2018.11.27
                          timp: 08:30:22
                          Turaþie motor: 0.00 /min
                          Valoare de sarcinã normatã: 0.0 %
                          Viteza vehicul: 0 km/h
                          Temperatura antigel: 61 °C
                          Temperatura aer admisie: 42 °C
                          Presiune aer ambiental: 990 mbar
                          Tensiune terminal 30: 12.380 V
                          Numãrãtor procese de adaptare nereuºite conform OBD: 34
                          Debitmetru de aer 1 bloc 1: debit de aer: valoare brutã: 0.0 mg/cursã
                          Elem. exec. clap. accel.1 bloc1: feedback poziþie - val. pres.: 0.00 %
                          Elem. exec. clap. accel.1 bloc1: feedback poziþie - val. efect.: 0.00 %
                          Elem.exec. clap. accel.1 bloc1: feedback poziþie - offset înch.: -0.15 %
                          Pozi?ioner clapetã accelera?ie 1 bloc 1: supraveghere - stadiu-Bits 0-7: 0
                          Pozi?ioner clapetã accelera?ie 1 bloc 1: supraveghere - stadiu-Bits 0-7: 55
                          Pozi?ioner clapetã accelera?ie 1 bloc 1: supraveghere - stadiu-Bits 0-7: 2
                          Elem. exec. clap. accel.1 bloc1: feedback poziþie - tens. brutã: 4457.2 mV
      4970 - Senzor turaþie intrare cutie viteze -G182- semnal neplauzibil
                P0716 00 [032] - -
                   împrejurãri cod:
                          Frecvenþa defect: 1
                          rulaj: 172223 km
                          Data: 2018.11.25
                          timp: 23:24:21
                          Turaþie motor: 521.00 /min
                          Valoare de sarcinã normatã: 38.0 %
                          Temperatura antigel: 81 °C
                          Temperatura aer admisie: 73 °C
                          Tensiune terminal 30: 12.400 V
                          Numãrãtor procese de adaptare nereuºite conform OBD: 32
                          Senzor poziþie neutral:unghi actual transmisie: 20.00 °
                          Senzor poziþie neutrã cutie:unghi actual adaptat: 0.00 °
                          Tensiune senzor poziþie neutrã cutie: 0 mV
                          Treapta angajatã-Bits 0-7: 0
      10657 - Semnal turaþie de la motor
                P0726 00 [008] - semnal neplauzibil
                intermitent - Confirmat - Testat de la ºtergere de memorie
                   împrejurãri cod:
                          Prioritate defect: 0
                          Frecvenþa defect: 1
                          rulaj: 172223 km
                          Data: 2018.11.25
                          timp: 23:24:21
      10763 - Autorizare pornire de la senzorii selector treaptã
                P1734 00 [002] - -
