008213 - Intake Manifold Flap Position Sensor (Bank 1)
Hi all, my MK6 GTI has this error and check engine light on the dash. It's also reporting misfires on 4 and 2. I will post the full error log after this. Car idles very unsteady, constant hiss from the right of the engine when facing it from the front of the car (battery side). Reading online it seems likely to be the intake manifold flap/motor at fault. Anyone with experience of this agree or suggest otherwise?
Also I noticed what looks like a hose missing. See the two circled hose connectors in the pic are just open to the air and nothing connected to them. Is that right? No change in engine idle when I blocked them with my fingers and no blow/suction from either.
Cheers,
Rob
Full log:
VCDS
Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: Release 21.9.0
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000
Diagnostic Trouble Code Report
Saturday,11,September,2021,13:22:14:27123
VIN: WVWZZZ1KZCW072832 License Plate: LN61 XTS
Mileage: 82190km-51070mi Repair Order:
Control Module Part Number: 5K0 907 115 HW: 1K0 907 115 AA
 Component and/or Version: 2.0l R4/4V TFSI 0050
 Software Coding: 0403000C1C070160
 Work Shop Code: WSC 01357 011 00200
 VCID: 678A4462E36B4B0306B-8032
6 Faults Found:
 P2015 - 000 - Implausible Signal - MIL ON
 Freeze Frame:
 Fault Status: 11100000
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 82199 km
 Time Indication: 0
 Date: 2016.02.02
 Time: 13:13:33
 Freeze Frame:
 RPM: 1158 /min
 Load: 46.3 %
 Speed: 0.0 km/h
 Temperature: 35.0°C
 Temperature: 26.0°C
 Absolute Pres.: 1010.0 mbar
 Voltage: 13.843 V
000256 - Mass Air Flow Sensor (G70)
 P0100 - 000 - Supply Voltage - Intermittent
 Freeze Frame:
 Fault Status: 00100000
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 82199 km
 Time Indication: 0
 Date: 2016.02.02
 Time: 13:15:31
VCDS
Page 2
 Freeze Frame:
 RPM: 773 /min
 Load: 26.7 %
 Speed: 0.0 km/h
 Temperature: 43.0°C
 Temperature: 27.0°C
 Voltage: 13.716 V
008852 - Fuel Pressure Regulator Valve (N276)
 P2294 - 000 - Open Circuit - Intermittent
 Freeze Frame:
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 82199 km
 Time Indication: 0
 Date: 2016.02.02
 Time: 13:15:48
 Freeze Frame:
 RPM: 809 /min
 Load: 19.2 %
 Speed: 0.0 km/h
 Temperature: 44.0°C
 Temperature: 27.0°C
 Voltage: 13.843 V
000768 - Random/Multiple Cylinder Misfire Detected
 P0300 - 000 -
 Freeze Frame:
 Fault Status: 01100000
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 82199 km
 Time Indication: 0
 Date: 2016.02.02
 Time: 13:15:52
 Freeze Frame:
 RPM: 723 /min
 Load: 23.9 %
 Speed: 0.0 km/h
 Temperature: 45.0°C
 Temperature: 27.0°C
 Voltage: 13.843 V
VCDS
Page 3
000772 - Cylinder 4
 P0304 - 000 - Misfire Detected
 Freeze Frame:
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 82199 km
 Time Indication: 0
 Date: 2016.02.02
 Time: 13:15:52
 Freeze Frame:
 RPM: 723 /min
 Load: 23.9 %
 Speed: 0.0 km/h
 Temperature: 45.0°C
 Temperature: 27.0°C
 Voltage: 13.843 V
000770 - Cylinder 2
 P0302 - 000 - Misfire Detected
 Freeze Frame:
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 82199 km
 Time Indication: 0
 Date: 2016.02.02
 Time: 13:16:05
 Freeze Frame:
 RPM: 745 /min
 Load: 27.4 %
 Speed: 0.0 km/h
 Temperature: 45.0°C
 Temperature: 27.0°C
 Voltage: 13.716 V
Readiness: 1110 0101
  • 2 weeks later...
  • Replies 4
Sounds like sticking runner flaps. You can get them replaced or do a runner flap delete, which is only really beneficial if you’re already running big power (and trying to remove any small flow restri
Thanks mate. It's booked in at my local specialist. They should be able to put it straight.
Needed a full intake manifold replacement. Fitted £720 but all sorted. They just cleaned the 4 and 2 sparks as the coil pack was fine. Been driving it for a few days since and it's bang on. Don't mind
Sounds like sticking runner flaps. You can get them replaced or do a runner flap delete, which is only really beneficial if you’re already running big power (and trying to remove any small flow restrictions). Cold starts can become an issue with the delete, as well. I’d recommend a proper fix instead.
Hopefully you’ve got a decent garage / specialist that can sort it for you. Good luck!
On 24/09/2021 at 22:48, chontay said:
Needed a full intake manifold replacement. Fitted £720 but all sorted. They just cleaned the 4 and 2 sparks as the coil pack was fine. Been driving it for a few days since and it's bang on. Don't mind spending as long as it fixes it and I trust these guys.
At least it’s sorted now. And yeah we’ve got to commit to maintenance costs if we want to enjoy these cars. You can’t really do it on the cheap!
