New mk8 Detail & Ceramic
I thought I'd share my experience of 'new car prep' with new motor. I picked it up unwashed and unloved.. lots of bird crap, sticker residue and all sorts of junk (despite looking ok in the photos below, it was pretty bad).
Snow foam first, 2 doses of bilt hamber's finest:
Wheels first.. I used my pump foam sprayer and some KKD Brakeaway, the medium wheel brush from Gyeon worked really well - apart from beside the front callipers - they were too close to the wheel to get in, for this area I switched to my small ez detail brush. Used a soft detailing brush for round the nuts, nooks and crannies.. microfibre mitt for everything else & a scrubbing brush for the wheels with some Gyeon Tyre cleaner.
I followed Gyeon's advice and washed the car with washing up liquid (it felt wrong...), then used Gyeon Iron all over - not much reaction to it anywhere that I could see, hard to tell on black. Then used some valet pro - citrus tar and glue remover for the glue residue spots - most of which were along the sills and on the windscreen.
A further wash and then dried - mostly with my blo air S hand held drier. Then mopped up with a double twisted loom towel.
Into the garage and taped up the rubbers, I was skeptical of the benefits of this - but very worthwhile time investment!
The last few times I've polished cars - I had all the lights in my garage on. This time around - I found huge benefits in having a couple of spot lights just pointed towards the walls, then using my £15 aliexpress spot torch (brilliant thing!) to check the paint. My 3 x 5 foot LED batons were a bit of a waste, less defused light is better... although I found the baton light better for wiping off the ceramic residue further on in the process.
I found quite a lot of marring in various places - the rear spoiler was particularly bad - the black plastics looked grey with holograms:
Some scratches...
Got cracking with Gyeon primer - it has a light cut and lays down a silicon based primer later, the cut was enough to clear 99% of any marks on the paint. Chasing perfection took about 8 hours on Monday (I took Monday and Tuesday off work...). Am not sure I'd be a profitable detailer - none of the jobs are quick!
Same spot as above after polishing;
Bonnet was probably the worst of the metal panels, which is odd - I thought they were transported with covers over the bonnet... must be wrong.. anyway - looks better now! The paint was particularly rough - grabby when you run the back of your fingers over it.. after polishing - slick and smooth;
Some parts of the panels had weird looking residue on them, possibly due to the fairy liquid :) it all polished away nicely though;
I finished the polishing late on the Monday evening, left it over night (as per instructions) and then gave the panels a light wipe down with Gyeon prep to remove any dust. Then I set about laying down the ceramic... 1 layer of Gyeon Mohs first - got the whole car done in about 1 + 1/2 hours.. Waited an hour (roughly) then started on the second coat. Mohs is one to watch - you can't wait too long to buff off or it gets harder to get off. I went through 2 new cloths per layer (seems a shame to sacrifice brand new cloths to the bin after such brief use - but a necessary evil!).
By the time I'd finished the second coat - it was time for kids football training, so I started the last layer (Gyeon Skin) about 6 hours after I'd finished the 2nd Mohs layer. Even after the 2 x Mohs layers - the gloss and shine looked amazing.
Skin is amazing stuff.. it goes on and bubbles weirdly on the paint, it then buffs off so easily - much easier than Mohs. If I didn't think the gloss couldn't be improved - it really did, I was blown away with the difference after skin going on.
The next day I went and borrowed axle stands and a torque wrench.. I was back at work - so the wheels needed to wait till the evening.. Jacked one side of the car up and put the axle stands in - removed both wheels and gave them a wash again (they were covered in dust and some break dust from the short journey into the garage);
Brought them indoors and then gave them a twice over with Gyeon prep - there were some spots of oiliness behind the spoke after washing. I used a nano polisher to clear some light scratches in the black gloss parts - impossible to get them perfect though. Nobody is going to be on their hands and knees with a torch inspecting your wheels (apart from you!)
Then I started with Gyeon RIM.. this was my least favourite process, although I followed some advice I saw on YouTube and cut a foam wax applicator into 4, 1 for each coat (bearing in mind I was doing 2 wheels with 2 coats - so 4 sessions of coating). The foam lets you get into tough corners and is much easier to handle than the suede squares that come with the coating. The suede and block are good for the barrels.
Again - a good light is vital, without a good spotlight - it would be easy to miss the high spots, once they dry - they're hard to remove without polishing. Yet again - discarding 1 towel after each coat for each pair, so 4 towels in total. RIM is much thicker than the other coatings, goes on thick and is tackier when buffing. I split the wheel into 4 sections and sometimes that was too much - need to be quick to get buffing to make sure it's not a nightmare. 1st coat needs 4 hours to cure before doing the second coat. I was able to do 2 wheels on Wednesday, then finished the other 2 wheels by Friday.
In between coats - I put some RIM on the brake callipers and on the exhaust tips - 2 x coats each.
My wife did think I was taking the piss when I brought the wheels inside :D worth it tho! Great to get the coating on these early - I was shocked by the number of fine scratches on them with them being brand new.
Wheels back on and then another sleep to cure... Saturday morning then was my least favourite bit.. GLASS! multiple runs with prep and then fast glass - eventually got all the smears away.. Then Gyeon Quickview - I really rate this product, easy applicator and buffs off nicely.. The hydrophobicity is better than anything I've used before (including the g-technic products).
Gyeon Tyre express applied and then fitted the aliexpress footrest, cill protectors and black mirror caps;
The mirror caps were easier than I thought!
The finished product...
It's hard to have a brand new car in the garage for 5 days.. am sure a pro could do it in 2 or 3 days.. The price of the kit and products I've bought over the last years I could have paid a professional to do it for me.. so satisfying to do myself though.. I learnt a lot - especially with the products and coatings I'd not used before, it was a bit stressful working in a cramped garage with numerous damage hazards.. It's amazing how long everything takes twice as long as expected.. Am looking forward to washing it in 2 weeks and seeing how it performs then..
Some crazy beading this morning;
  • Replies 17
I had trouble with wiper judder after putting H2Go glass treatment on my R windscreen.  A bit of 303 on the wiper blades helped, then a thin smear of graphite powder fixed it.  Neither last very long,
I found some Gumifpledge on the wipers helped a lot with judder. Most of my driving is motorway so I always put up with the odd judder in town for the huge extra safety margin when the heavens opened.
Some scratches...
Cracking write up with brilliant results.😎
Just wait till you try and snow foam it,it won’t stay on for long.
great write up, way more patience than me, and like others, I would of taken one look at the instructions, and driven to a pro.
Tbh, if my estate is a keeper, I may treat it one day to a professional job, as I find I have less and less time to work onmy car now (even though I do enjoy waxing it etc, and have a broken back the next day and lots of other aches and pains).
Good work! Love a bit of Gyeon detailing.
You don't need to throw the buffing cloths away though, stick in a waiting bucket of strong mix washing up liquid and water and when you're finished stick into washer wet. This doesn't give the coatings any chance to dry, let alone cure so the cloths come out like new.
Let me know how you get on with the quick view.  I put some on the passat a few months back and then it sat in garage for a good while before being used again (around 2 months iirc) and the wipers judder terribly when it rains.
I've yet to try it on anything else yet!
Re the Rim, I find I can easily coat a wheel inside and out and buff it off without having to split into sections. I find it the longest of all the coatings for flashing off.
If you've not already get some wet coat and some cure.
Use the cure on the rims to extend the coatings.  Wet coat for top ups to hydrophobics when the skin starts getting a little clogged.....or bathe+.
I had trouble with wiper judder after putting H2Go glass treatment on my R windscreen.  A bit of 303 on the wiper blades helped, then a thin smear of graphite powder fixed it.  Neither last very long, so I have to keep re-applying (I do like the way heavier rain just blows off at speed, so I'll persist with the H2Go).
aha, I missed the boat on the bucket of water :D I'll keep that in mind for next time. I got stung a few months back when doing my wifes car, didn't swap buffing cloths enough and ended up with holograms from the dried product (cancoat) on the cloths. This made me overly paranoid of doing the same again.. I'd accepted the price of the cloths as worth paying for that peace of mind.
On quickview - amazing performance, I'd been using it on my last car and it does hold up well. My wife's windscreen is only starting to fade now after about 3 months.. I do get pretty hefty juddering on the couple of occasions it's rained since.. I meant to apply some quickview to the blades at the weekend but forgot.. might try that and see how it goes. Will give the blades a good clean with prep first. Just had to check, the wiper service mode process is the same as the previous models.
Rim - I found it got quite tacky, maybe because I was indoors and quick warm environment (I couldn't bare being on my knees in the garage much longer!)- it got quite hard to buff off the bigger area I did. Buffing into corners was a bit of a pain - but there's no getting away from that :) I guess I wasn't brave enough to experiment too much, succumbed to following the instructions to avoid disaster.
Yeah, I've got both Cure and WetCoat - am looking forward to seeing how they all hold up over winter! I read that water spotting can happen during the curing phase, but none to be seen & it's hit 2 weeks tomorrow since application (3+ days in the garage afterwards seems to have helped reduce the chances of that, as painful as it was).
Colder morning this morning meant fogged up windscreen and dew.. showed up a few smears and strips where there had been sticky tape on the interior glass. I really dislike interior glass :(
