TPIs and recalls for mk8 Golf R *INFO ONLY THREAD*
Booth11
 Share
Dear all
@aldfort has very helpfully made a suggestion that a thread is set up for for posting known TPIs (Technical Product Information) for the Golf mk8R.
As many of us are already aware there are, and continue to be, software issues with the mk8 that VW are attempting to address through dealer actioned software updates.
With the invaluable information shared by @phope on existing TPIs, owners and owners-to be can be better informed when approaching and dealing with their dealership about these issues.
Although TPI info has been posted up in the Gremlins thread, it can be quite difficult to find the relevant posts, so to that end, this thread is set up (and stickied) for members to easily locate TPIs relating to the 8R and for anyone in the know to post up future TPI information.
I will start it off by copying and pasting the 3 TPIs that phope has shared in the 8R Gremlins thread.
Copied from 8R Gremlins thread.  Credit to @phope
TPI instructions for cars with software versions 17** and 18** have been released by VW, under TPI reference 2063230/3 and 2065639/1
This should upgrade your software to version 1890
Further updates for cars running 16** versions are expected in Q1 2022
Details below....go annoy your dealers with these, if you want fixes applied!
TPI 2063230/3
TPI 2065639/1
  • Booth11 pinned this topic
  • 4 weeks later...
For info -
I’ve decided to lock this thread and keep it as an info only thread.   It was turning into a second 8R Gremlins thread and we only need one of those.
If anyone wants has a TPI they would like adding to this thread, please post it up in Gremlins and I’ll add it to this, or alternatively PM me with it and I’ll add the info.
Chat posts from here have been moved to the 8R Gremlins thread.
Please post chat relating to issues in the Gremlins thread.  👍
  • Booth11 changed the title to TPIs for mk8 Golf R *INFO ONLY THREAD*
  • Booth11 locked this topic
  • 3 weeks later...
Courtesy of @phope here is a new TPI issued.  This new one is an update to an earlier one for the main software update to version 1890 - now version 1896.
TPI 2066207/1
  • Booth11 unlocked this topic
I can't see the TPI reference 2066384 yet for MY21 cars, but is likely the same detail as the one above, giving instructions to the dealer techs on how to update to 1896
Hopefully by telling your friendly helpful service advisers about these TPI references and any symptoms you've experienced for your specific VIN, they can help dealer techs update your car to the most appropriate version for this, as well as other related software updates
9 minutes ago, Massimo2323 said:
Found on the German Erwin (Only in German language) the 1896 update for 166x. Number is 2066316/1. The 1810 update TPI number 2065216/6 has been discontinued with reference to 1896 TPI.
For info, above post copied over from @Massimo2323 in another thread.
31 minutes ago, Massimo2323 said:
The difference between 2065216/x and 2066316/x, apart the infotainment software from 1810 to 1896 and the various control units getting updated, is the missing PRCode L0L (Steering on the Right) which means it will be available for Ireland and UK also.
FYI ^
  • 2 weeks later...
So the TPI 2066316/1 for updating the 16xx software to 1896 is out in the UK and Ireland.
3 other TPI's point to this 2066316/1 as the solution:
2065214/2 - We Connect: message for emergency call system/online services not available/event entry U178500 (MOD3.2)
2063712/5 - Driver assistance systems, rear view camera: picture sometimes too dark/shown with delay
2066464/1 - We Connect: "Become main user" not possible/fails (SW16xx, SW1810) [MOD3.2]
There are other TPI's too but in German for now like Keyless Problems(2060781/4), side-assist or parking sensors not working(2064061/4) and various errors and problems with 16XX (2065241/3).
I have both TPI 2066384/1 and 2066207/1 and they are identical.
Only difference is first one is for My21 while the second one is for My22/My23.
Sorry if i am not supposed to post in this thread, but could i ask a question about all these TPI's?
Are all the above reported problem solutions part of the 1896 update or would some, ie Keyless Problems be a separate update?
I just wonder if you get the fix for all the known problems in a infotainment version update ie 1896 update or if its a case of continually having to report every single issue expiranced to the dealer so they check for a specific fix.
I, for example have definitely had a few random issues with the keyless not responding but i have never reported this to the dealier.
Many thanks
(Please delete my post if shouldnt have posted here, i know you want to keep it realavant to just TPI info)
Courtesy of @phope proving a link to the TPI that @Massimo2323 reports on above (big thanks to both for sharing).  I’ve screenshot it and post it below.  It’s a looong one!
TPI 2066316/1 - this is for cars with software 16xx to update to 1896
Many thanks
All those different Tpi’s with different problems are all risolved with the 1896 software update.
This Tpi also brings software updates to other control modules like the brakes, side-assist, parking sensors, Harmon Kardon system, antenna, gateway  central electric, rearview camera, keyless, Ocu. If the Golf is a mild hybrid then the engine and 48v battery module also get updated.
Also of note this Tpi can’t be executed if the hardware number of the gateway is different then 5WA907530C.
  • Booth11 changed the title to TPIs and recalls for mk8 Golf R *INFO ONLY THREAD*
  • Booth11 locked, unlocked and locked this topic
This topic is now closed to further replies.
 Share
