AHG Posted March 16, 2022 Report Share Posted March 16, 2022 Works on my spouse’s ‘19 Tiguan (HL+)and my ‘18 S3 8V (FL) Assuming it’d work on mk7/7.5 Rs(and maybe on 8R at some point)so I thought I might share Quote Link to comment Share on other sites More sharing options...
AHG Posted March 16, 2022 Author Report Share Posted March 16, 2022 Notice:We don’t have NAV in our cars, so this post shows how to turn on Traffic sign Recognition in “detection” only modeusing only the LaneAssist camera———————————————————————————Module A5 - driver assistanceAdaptationModule A5 - driver assistanceLong CodingModule 5F - MultimediaAdaptationModule 5F - MultimediaAdaptationModule 13 - ACCLong CodingAnd finally,Module 17 - DashboardLong CodingOnce you do that, a ping will be heardand a message will show on the dashboard:Do not worry, this is ok.It goes away and no fault code is showing.———————————————————————————AddendumWe don’t have NAV in our cars, so this shows how to turn on Traffic sign Recognition in “detection” only modeusing only the LaneAssist cameraIf you have NAV in the car you may want to use fusion instead of detection in the first step (above) and also enable displaying the VZA function to show speed on the NAV screen (see below)Module 5F - MultimediaLong CodingI did not try this last part (VZA) as we have no NAV.You can update here if you try and it works (or not). Quote Link to comment Share on other sites More sharing options...
AHG Posted March 16, 2022 Author Report Share Posted March 16, 2022 This is how it looks in different screen layout- on the analog cockpit of the S3 8V FL- on the virtual cockpit of the Tiguan HL+—————————————————————Also, be aware that if you don’t have NAV (like me) and you turn on traffic sign recognition, you may get a message every time you drive someplace with no traffic signs for a while, or a few minutes after start up, letting you know that it doesn’t have a recent value for speed limit (can happen also in poor weather). Quote Link to comment Share on other sites More sharing options...
AHG Posted March 16, 2022 Author Report Share Posted March 16, 2022 Now all that is left to do is set the warning- In my S3 it only flashes and makes no sound,and allows me to chose off or 5,10,15 kphover speed limit as threshold for the warning- In the Tiguan it allows to chosewarning type Visual/Acousticand a threshold between 0-20 kph above limit Quote Link to comment Share on other sites More sharing options...
AHG Posted March 16, 2022 Author Report Share Posted March 16, 2022 Module 13 - ACCLong CodingNote:I’m not sure what this step actually changesor if it is actually vital for it all to work properlyI hoped it would enable to set ACC thresholdto be speed limit + 15kph, which is great,but it doesn’t seem to affect the ACC so far(maybe in speed limiter mode, instead of ACC,But I love ACC so wouldn’t give up on it).Perhaps I need to code TravelAssist for it to work.If you know something about it, please post here.I don’t mind going deeper into this rabbit hole,and hopeful it will help R owners w/o road signs display. Quote Link to comment Share on other sites More sharing options...
Adamsilver1987 Posted March 27, 2022 Report Share Posted March 27, 2022 Thanks for this. Going to give it a go Quote Link to comment Share on other sites More sharing options...
AHG Posted March 27, 2022 Author Report Share Posted March 27, 2022 Please update what carand if it has NAV or notand of course - if it works or not Quote Link to comment Share on other sites More sharing options...
bikeboy24 Posted May 1, 2022 Report Share Posted May 1, 2022 I've been trying to get this to work on a pre-facelift (2016) R. Still a no go... I'm in Canada, speed signs are in black and white. I followed the instructions down to a T, but I'm still getting "No road signs available" in my dash. Am I missing anything?? Module: 5F (Information electronics) Adaptation → Channel: Car Function List BAP Gen2 - traffic sign recognition 0x21 → active Adaptation → Channel: Car Function List BAP Gen2 - traffic sign recognition 0x21 msg bus → Databus extended Adaptation → Channel: Car Function Adaptations Gen2 - menu display road sign identification → active Adaptation → Channel: Car Function Adaptations Gen2 - menu display road sign identification over threshold high → active Coding → Long Coding → Byte: 24 → Bit: 6 → active (was already on) Module: A5 (Front Sensors Driver Assistance System) Security Access → Code: 20103 Coding → Long Coding → Byte: 01 → Bit: 0 → active Adaptation → Channel: Road Sign Detection Fusion Mode → Road sign detection Adaptation → Channel: Display end of speed limit symbol → active Adaptation → Channel: Valid additional characters (display valid additional signs) → 00100111 (was already 100111) Adaptation → Channel: Display No passing allowed" -> active Adaptation → Channel: Function Module Road Sign Recognition -> On Module: 17 (Instruments Cluster) Coding → Long Coding → Byte: 05 → Bit: 2 → active Reboot infotainment unit by pressing and holding volume knob for 10 seconds. Quote Link to comment Share on other sites More sharing options...
AHG Posted May 1, 2022 Author Report Share Posted May 1, 2022 I didn’t do all of those things (see above)also did not reboot in neither carsJust got out and locked the carThen opened and restartedIt says “no road sign” every time we driveuntil it “sees” a speed sign and recognizes itNo idea why it wouldn’t show your signsVideo on YT say it can show US signs (similar, no ?)Did you go into the dash/info menus to turn it on ?You chose “extended” that would mean the control is on the menu on your extended dashboard, so you can choose it there (I think in digital dashboard you chose through the touchscreen). Quote Link to comment Share on other sites More sharing options...
AHG Posted May 1, 2022 Author Report Share Posted May 1, 2022 Module A5 - driver assistanceAdaptationModule 13 - ACCLong CodingApparently, at least in my car, these two are not necessary (haven’t had time to try it in the Tiguan yet).I turned them back to how they were, and everything still works the same (I don’t think I have the ACC SW that can control it with sign recog.). Not very good, mind you. It notes every sign it sees, even if it isn’t for the lane you are in, and it misses signs from time to time. So I find it cool for construction areas where they temporarily drop the limit and Waze doesn’t know about it. Quote Link to comment Share on other sites More sharing options...
bneh Posted June 27, 2022 Report Share Posted June 27, 2022 I was gearing up to give this a go today and wanting to do some swotting up on the 'How To' above and ... ... before I've even plugged the OBDEleven in, I realise that I've been a bit of a plonker. In the rush of buying the car and wanting to be prepared, I skim read this thread (and a few others) and bought an OBDEleven dongle with the aim of enabling a few features on my R that I've missed from past cars... However, by skim reading, I'd missed some crucial info - that this functionality is tied to the LaneAssist camera (which I don't have) 😞 AHG 1 Quote Link to comment Share on other sites More sharing options...
AHG Posted September 16, 2022 Author Report Share Posted September 16, 2022 Did anyone try to turn on showing Speed Limit on dashboard on a mk8 Golf that didn’t come with it ? Quote Link to comment Share on other sites More sharing options...
TheBlondeFella Posted November 23, 2022 Report Share Posted November 23, 2022 I don't have 'Lane Assist' but I do have 'High Beam Assist'. Does this mean I have a camera and this adaption is possible? Quote Link to comment Share on other sites More sharing options...
AHG Posted November 23, 2022 Author Report Share Posted November 23, 2022 If you have a 8R you probably do have lane assist as I believe it comes standard WW you may not have side assist, tough, as it is optional in EU (letting you know if someone is coming from the back, left or right) If you have an older car, it is easy to see if you have a camera, looking at the mirror base from the outside through the glass (see pic below, there is a triangular space between the glass and the base of the mirror, it is you can see the camera). The basic version of HBA (non matrix, just high or low) use a sensor on the back of the mirror, so HBA does not necessarily mean you have a camera. Quote Link to comment Share on other sites More sharing options...
TheBlondeFella Posted November 23, 2022 Report Share Posted November 23, 2022 I have a 2016 7r. Just wondering, thought I might be able to have for a minute 🙃 Quote Link to comment Share on other sites More sharing options...
