WHY.A.H.WHY.A 145 Posted July 19 Report Share Posted July 19 Hello Ladies & Gents. Just a heads up as i received it from one my club memebers He got a call from the local dealer informing him about a software update for his 7.5 R. I have checked the online tool and retured the below result. I asked him to get the details of the TSB onc he visits the service center. Will keep this post updated Booth11 and bneh 2 Quote Link to post Share on other sites
Booth11 23,663 Posted July 19 Report Share Posted July 19 3 hours ago, WHY.A.H.WHY.A said: Hello Ladies & Gents. Just a heads up as i received it from one my club memebers He got a call from the local dealer informing him about a software update for his 7.5 R. I have checked the online tool and retured the below result. I asked him to get the details of the TSB onc he visits the service center. Will keep this post updated Thanks for posting. Be great if you can get details. There’s also some chaat about the DSG recall in this thread also. WHY.A.H.WHY.A 1 Quote Link to post Share on other sites
FishingVWR 1 Posted July 19 Report Share Posted July 19 I receive the following if I try to do a recall lookup "This is not a recognizable Volkswagen VIN. Please check your VIN and try again" https://www.vw.com/en/recalls.html Quote Link to post Share on other sites
bertj 14 Posted July 19 Report Share Posted July 19 This might be a USA orientated site. If you go to https://www.volkswagen.co.uk/en/need-help/need-help-faqs/recall.html all you get is 'consult your dealer, or the DVLA. AFAIK there's no UK VW site where you can enter a VIN but it would be good if someone knows of a UK recall site. Quote Link to post Share on other sites
FishingVWR 1 Posted July 19 Report Share Posted July 19 If you go to https://www.volkswagen-bahrain.com/en/owners.html#vin-lookup it will accept a UK VIN. Mine is showing the same recall as the OP. I currently have extended warranty so now would be a good time to get this done, in case it does show a fault with the DSG. Right?! Quote Link to post Share on other sites
Bodyboarder81 280 Posted July 19 Report Share Posted July 19 I’m presuming as it’s a recall that any work that needs doing would be covered by vw , even if out of warranty? Quote Link to post Share on other sites
neilybealy 21 Posted July 19 Report Share Posted July 19 It says my vin is valid but not linked to any recall. Thought being a 19 7.5 it would be Quote Link to post Share on other sites
Deano 337 Posted July 19 Report Share Posted July 19 59 minutes ago, neilybealy said: It says my vin is valid but not linked to any recall. Thought being a 19 7.5 it would be The link provided is for VW Bahrain so doubt it works for UK cars neilybealy 1 Quote Link to post Share on other sites
bneh 19 Posted July 20 Report Share Posted July 20 I've got a '19 7.5 DSG with the DQ381 and enquired with my local dealer and they've not heard anything about this. I'm guessing they're just being a bit slow. For those that haven't followed the various links: - The issue seems to be with an oil pump shaft within the 'start/stop' system that can break without warning and destroy the transmission. - The software update is to add diagnostic checks on the status of the pump and flag an issue before it causes anything terminal. Quote Link to post Share on other sites
FishingVWR 1 Posted July 20 Report Share Posted July 20 I enquired today, 17 hours ago, Deano said: The link provided is for VW Bahrain so doubt it works for UK cars That was the only link I could find that accepted my UK VIN. Can confirm it showed my vehicle was part of the recall. Quote Link to post Share on other sites
FishingVWR 1 Posted July 20 Report Share Posted July 20 (edited) 2 hours ago, bneh said: I've got a '19 7.5 DSG with the DQ381 and enquired with my local dealer and they've not heard anything about this. I'm guessing they're just being a bit slow. For those that haven't followed the various links: - The issue seems to be with an oil pump shaft within the 'start/stop' system that can break without warning and destroy the transmission. - The software update is to add diagnostic checks on the status of the pump and flag an issue before it causes a terminal issue. I also enquired today and have been booked in for the software update. They said they'd need the car all day which I found odd! I queried the reason for the recall and it matches what you have put above essentially. The only extra information he added was a "limited run" of the 7 speed gearbox. I've checked a friends R VIN (19 plate) and his did not show as part of the recall. I wonder if this only affects early 17/18 plate 7.5 Rs? For those will in the warranty period / extended warranty I suggest you get booked in as soon possible. Edited July 20 by FishingVWR Quote Link to post Share on other sites
MJC1216 49 Posted July 20 Report Share Posted July 20 Checked mine which is a 19 plate and not showing any recall... Maybe does only effect a limited run but time will tell. Quote Link to post Share on other sites
FishingVWR 1 Posted July 20 Report Share Posted July 20 Does anyone know if updating the DSG Control Unit will also perform a "DSG Reset"? If not, do you think if I ask VW to perform once they will whilst it's in? Quote Link to post Share on other sites
MJC1216 49 Posted July 20 Report Share Posted July 20 1 minute ago, FishingVWR said: Does anyone know if updating the DSG Control Unit will also perform a "DSG Reset"? If not, do you think if I ask VW to perform once they will whilst it's in? Just checking is yours a 17/18 plate ??? Quote Link to post Share on other sites
SloGold 43 Posted July 21 Report Share Posted July 21 Just checked mine and it’s saying I’m part of the recall. 17 plate 7.5 estate. Quote Link to post Share on other sites
