Lowering springs and DCC
Has anyone had lowering springs with DCC installed?
If so, did you have the DCC recalibrated?
I've just had the eibach sportline springs installed and I know it stiffens the rde but it is a little more on the bumpier side than I'd hoped.
I've used these springs before on an M140i and the ride difference wasn't as drastic.
I'm hoping a recalibration could fix this?
  • Replies 2
I had the racingline springs fitted and nearly swapped them out for eibach as the ride was so harsh on small pot holes. From the little bit of research I gathered switching them would make little difference. What did make a big difference was swapping out my hankook tyres for Goodyear Eagle F1 supersports. The side wall is much stiffer than on the hankooks. I also had the DCC reset by progressive parts in Manchester which also helped. If you are based in Manchester try and speak to Mark at Progressive parts.
 Share
    • Raised £165
