Making some VCDS changes
bah434x
Making some changes tmrw on the MK7R
Anything else worth while doing?
My list so far....
Alarm chirp
Sound actuator volume
Rear brake lights
DRL Brightness
Puddle lights on while folding
Automatic rain closing
Cheers
How do you alter things like this ?
  • Select STG 09 (vehicle power)
  • STG access permissions -> Function 16
  • Enter access code 31347
  • STG adjustment -> Function 10
  • Channel (3) - select windshield wipers SRA washing time
  • Adjust value (from memory the max value you can set is 2500ms)
audi_a3_8v_stg09_bordnetz_anpassung-fron
Cheers
Is there a way to enable the passenger side rear fog? Looks like the LED's are there
Can you explain the headlight washer option ?
bah434x - what do you mean by DRL brightness?
Items I have changed...
DRL brightness when headlights on -also works for Coming Home
DRL dimming when indicators on, fade in/out
Fan speed shown when A/C on Auto
Alarm Beep + enable on Navigation display
Extended Brake Lights - using boot lid LEDs
Traffic Sign recognition
Seatbelt warning
Seatbelt warning
Headlight washer delay basically means that if you pull the stalk to activate the windscreen washers (whilst your lights are on) it will delay the headlight washets from activating for X amount of time. In my case I have set the delay to 2.5 seconds, this means as long as i dont pull the stalk back for more than 2.5 seconds then the headlight washers never activate! Which for me is much better as i find the washer fluid lasts a lot longer before needing refilling.
  • 2 weeks later...
