Showing results for tags 'Discover Pro Retrofit'.
Hello everyone, this is my first post on here and after reading about retrofitting the Discover Pro into a MK7 Golf R I would like to offer some advice. I purchased my wife a brand new Golf R back in February this year, the car was at the dealers and had been ordered by a customer that never went through with the transaction and it had all the options on it that I wanted apart from the Discover Pro satnav so I bought it there and then. I contacted OEM retrofits in Bradford because they are local and they said that they could fit me the unit I wanted for £1200, I asked if it had component protection and they said that none of the units they fitted had component protection so I went ahead and asked them to fit one for me. After picking up the car I took it home and plugged in my wife's iPhone into the USB port only to find it wouldn't charge or display on the head unit so I tried my Nokia and that wouldn't work neither. I also discovered that the 'mode' button wouldn't change the engine settings so I took the car back. After 2 hours of messing with the head unit I was told he would have to do some research into it and contact me when he found a cure, 3 months later and still no contact, I phoned them, texted, emailed but no answer or reply so I took it to VW and they couldn't help me because they can only download data from Germany to put the car back to standard & how it left the factory. I have vcds but it couldn't find the 5F media, I ran a diagnostic and the result was that the component protection was coming up as a fault and wasn't letting me read the head unit. So, this was my expensive way to find that OEM Retrofit's head units have component protection enabled so unless you can put up with having no USB charging & like driving your car stuck in eco mode then spend £1200 on having OEM retrofit you a Discover Pro, if you like having everything working in your car then I'd stay well clear of OEM Retrofit in Bradford, you have been warned!!! Regards, Lee
