Showing results for tags 'Vcds coding available'.
  1. VCDS CODING DIAGNOSTICS AVAILABLE **Mk7/GTD/GTI/R Adaptions** •Disable Seatbelt Warning **Disable the annoying tone when the ignition and driver's door open** •Change comfort blinking Adaptation •Rain closing windows •Comfort Close windows •Automatic Air Recirculation....this places the option in the AC setting on the nav screen •Sound actuator (Delete) •Passenger mirror dip •Xenon Range (Change from all 4 lights on to 2) •Disable the little red led's on the side of the taillights •Disable the orange LED "parking lights" below the reflector with cars with HALOGEN LIGHTS ONLY •Disable the orange LED "parking lights" below the orange reflector on Bi-Xenon cars •ESC OFF •Change instruments to Carbon Fiber look •Disable Seatbelt Warning •Gauge sweep •Amount of fuel (in Gallons) used since the last fill up (refuel quantity) •Battery charge level or SOC (state of Charge) •Full DRL Brightness for Parking Light/ CH/ LH do this. Also increases brightness for DRL’s •Disable DRL •Change comfort blinking •Change brightness of reverse lights •High beams and fogs “flash†•Scandinavian DRLs (Tail lights on with DRLs) •DRL off with Handbrake Daytime running •Disable auto unlock (disabled all doors from unlocking on key pull) •Rear teardrop Wipe •Rain closing windows •Comfort Close windows •Comfort closing sunroof •Folding mirrors with lock/unlock Insta: @Mike7RLondon
