Showing results for tags 'centre console'.
  1. So I'm trying to determine if its possible to retrofit wireless charging into my VW Golf R Mk7.5. I've seen some 3D printed versions for LHD cars which in any case even if it did work for RHD, seem to result in the loss of the USB socket so that didn't appeal to me. I believe I require part number 5NA980611, which is the Coupling antenna 'GSM/UMTS/LTE - £180.06 which is located dash top in the middle. However I think for this to work I would also need to change out the centre console as well? Has anyone done this?
