Showing results for tags 'coilover '.
Hi All, Fitted my Bilstein Coilovers today, the B16 PSS10 version, not much info around on how to do it and half of what I found online was wrong plus the instructions are not the best. Tools For this job I used. Spring compressors 13mm scocket 16mm socket 18mm ratchet spanner or 18mm ring spanner 21mm ring spanner or 21mm swan neck spanner 22mm ring spanner or 22mm swan neck spanner 7mm allen key - DO NOT START THIS JOB WITHOUT A 7MM ALLEN KEY - THIS DOES NOT COME IN MOST ALLEN KEY KITS Socket set with 18mm sockets 1/4" ratchet with 1/4" extension Vice or Mole grips Flat head screwdriver Masking tape 2 jacks (you only need one) but two is easier 18" piece of 2 x 4 wood or similar timber 2 x axle stands M6CR-V splined drive M14CR-V splined drive Set of star bit screw driver bits 2 x 20mm long cable ties Torque wrench and wheel sockets Ruler Let's start with the rear, break loose your wheel bolts, jack the car up, put your two axle stands where the rear arms bolt up to the center of the car, make sure you're careful to place the car gently on the stands when lowering the jack. Remove you wheels and put them somewhere safe along with you wheel bolts and wheel nut caps. Next move to the drivers side rear shock mount assembly and locate the three fasteners that hold the inner arch cover (you don't need to remove the cover just undo the three bolts that are closest to the shock as pictured below.) Now pull the guard back around the top of the shock tower to reveal the upper shock mount, undo the two 16mm bolts to loosen them off but don't remove totally just yet. Next look at the rear ARB (anti roll bar), get your 18mm ratchet or ring spanner on the nut and insert the M6 splined drive into the inner bolt to hold it whilst you undo the 18mm nut (don't try to pull it out yet as it's under tension) OK now there are two bolts between you and finishing the first part of this part, both require an 18mm ring or ratchet spanner along with a second 18mm spanner or 18mm socket. One holds the rear arm to the rear hub assembly and the other holds the bottom of the shock to the lower arm, remove them both. Note these pictures are for the rear passenger side (there is an extra step for this side when you come to it and that's to unclip the headlight leveling bracket ) The bit in green pictured in both the image above and below. Undo this bolt And this bolt Now pull the rear hub assembly to the side to release the lower arm, now you can remove the two 16MM bolts at the top of the shock mount and remove the shock, if it wont come out, grab the top section of the shock in one and and the bottom section of the shock in the other and compress to shrink it down, now pull you can it out. Finally, you can now push the lower arm up to take the tension off the ARB and pull the rear drop link out the way - you might have to use both hands to pull it away. Part 2 - Disassembly & Reassembly - The Shock Right, grab the black plastic dome on the top of the shock you've just removed and pop it off to reveal the top nut, I found this nut really hard to get to without a top nut box socket so I cheated. Cut the cable tie off the dust boot and pull it down. Now wrap some masking tape around the very top of the piston, grab it with your mole grips or vice and just undo the top nut with a 16mm socket, they're not done up tight and undo with ease. Now pull off the top assembly, put the 16mm nut back on the old shock for safe keeping. Next pull the bump stop out of the top mount of the shock assembly and put it to the side - you don't need this but keep it in case you ever have to put the original suspension back on. Next take your new Bilstein rear shock out of the box, remove the top nut, keeping the black rubber washer in place. Next take the dust cover from your old shock, cable tie it back into its original place on the top mount and put the top mount shock assembly from your original shock onto the new Bilstein shock, replace the nut and tighten (as the Bilstein design is built upside down you can just hold the shock to do the nut up) Great - all done on this part and now on to the spring and platform adjuster Part 2 - Disassembly & Reassembly - The Spring Take the platform adjuster and set you spring perch platform in place (as a rough guide - 35mm from the bottom of the threaded section to the bottom of the lower spring perch lock ring will give you a final arch to top of tyre gap of around 25mm) Next add the spring ensuring you place the blue nylon washer between the spring and the platform adjust to keep things nice and quite - without this is place the spring and perch will knock/clank. OK, just add the big black rubber washer on the top and return to the car. Place the spring in the spring mount of the lower arm being sure to use the rubber spring mount that should still be in fixed into the lower arm - if it came out with the original spring, go and get it and put it back in place - note, you do not need the upper rubber spring mount that was attached to the top of your original OEM spring. Line the new spring up making sure the lower end of the spring meets with the rubber stop in the lower spring mount that's still in the lower arm. Right, time to bolt it all back up again - you may want to use jack to raise the lower arm up so all the bolt holes line up perfectly. Note in this picture you can see I have invested in some shock socks from eBay - I've bought some for every set of coilovers I've ever owned and they are excellent for keeping all the crap off shocks. Now do the same for the other side, refit your wheels, remove the jack stands and you're ready to start on the fronts . . . . want some good news? . . . . . . the fronts are way less hassle than the rears. Part 3 - The Fronts Right, this is the easier part of the job. Undo the wheel bolts on the driver’s side, jack up the front of the car (just one side) place an axle stand in a safe place and remove the wheel. Now look at the top of the brake caliper and you’ll see your brake line is held in place with a small metal tab/spring clip, slip your flat head screw driver under the spring clip and prize it up. (NOW BE REALLY CAREFUL) (ONLY ON THE DRIVERS SIDE) You'll see another cable, right next to the brake line, this is the brake pad wear sensor cable and you'll need to very carefully, AND I MEAN very gently prize this apart with a flat head screwdriver, take your time because if you break this you'll need a new one wired in and that is going to be a nightmare. Now you've got your brake line free and separated the brake pad wear sensor cable coupling, you'll need to undo the 18mm bolt which clamps the lower hub assembly to the bottom of the shock using the M14 splined drive and an 18mm ring or ratchet spanner or an 18mm socket. Next undo the droplink which runs from the end of the anti roll bar up to the tab on the side of the shock leg (this is the same as the rear, M6 splinned and 18MM nut) - just like the rear, if you cannot pull it apart just yet, not to worry you will be able to do so in a minute. OK - this bit is a bit more tricky! To release the the shock from the lower hub assembly you can either undo the lower arm which takes a ton of work or you can do the following . . . . Take your 1/4" ratchet and 1/4" extension and feel around to the back of the where the shock goes into the lower hub assembly, now push it into the gap as pictured below, rotate the ratchet an a eighth of a turn to open the jaws of the lower hub assembly - imagine turning it from a square that sits in the jaws to a diamond that just opens them up - I forgot to take a picture of me removing the original shock but you can see what I mean from the picture of the new shock in place below. Now grab the top of the brake disc with one hand and the bottom of the brake disc with the other hand holding the bottom of the brake disc and wiggle - you'll see the lower hub assembly now comes part of the way down the shock leg and stops - this because there's a metal tab on the shock that's now hit your 1/4" ratchet extension. All you have to do is give the ratchet another eighth of a turn, pull it out, push it back in jaws but under the metal tab and give it the eighth of a turn like you did before, again grab the brake disc and wiggle - you'll notice that whilst everything is lose, you can pull more of the shock out but you cannot get the hub assembly low enough to get the shock free completely but fear not . . . Get your jack and piece of wood, place the piece of wood on the jack, placing one end of the wood on the jack platform and position the other end of the wood against the lip of the shock that the shock's coil spring sits on and jack the shock up about 2" - 3" and out pops the shock from the lower hub - it may need a little wiggle - doing this compared to striping down the lower arm is much, much quicker and easier. OK you're on the home straight, pop the bonnet open, find the three clips that hold the plastic trim below the windscreen in place - you're not going to remove it, you'll just need pull the clips out in order to to lift the trim up a little to reveal the three bolts that are now the only thing holding the original shock in place. There is one tab in the middle, and one either side - I've just taken a picture of one side and the one in the middle but you get the point. Middle One Side OK, gently lift up the front, get your 13mm socket and remove the three bolts from the top of the suspension turret mount. Great stuff, now move the shock clear of the car. The next job is to compress the spring with the spring compressors. Get your 21mm ring spanner on the top mount nut and your 7mm allen key to hold the shock's piston that the nut is screwed onto still whilst you undo the nut - do not undo this nut without spring compressors unless you know exactly how to fire a shock down the drive without taking your head off - THE SPRING IS UNDER A FAIR BIT OF TENSION AND THIS COULD BE VERY DANGEROUS WITHOUT SPRING COMPRESSORS. OK if your still reading this, you've successfully removed the top mount from the shock without killing yourself Now all you need to do is remove the bump stop from the top mount of the original shock. Next place the top mount from your original shock onto your new Bilstein shock, add the washer that came with the Bistein kit to the top of the top mount and do up the 22mm nut. REALLY IMPORTANT - Now make sure you top mount set up correctly . . . . 1) If you look at the top mount you'll see two arrows, these need to point to the front and rear of the car when reinstalled. 2) The start of the new spring needs to line up with the locating tab that holds the wedge shaped part of the top mount in place with the other part of the top mount - this will make sense when you have the parts in front of you. 3) Now move your spring perches up like you did on the rear install (a 40mm gap from the bottom of the threaded section of the shock to the underside of the lower spring perch will give you roughly the same arch to tyre gap at the front as you have at the rear) When the shock is lined up to the car it will look like the picture below - I put a little blue paint mark on the outer bolt hole of the top mount to make it easier to see when lining everything up. Start by doing up the three 16mm bolts that hold the shock in place to the top of mount but don't do them up fully as you need some wiggle room to get everything in place and then when everything is bolt up at the bottom of the shock . . . . YOU SHOULD STILL NOT DO THE TOP BOLTS BACK UP JUST YET. With everything bolted back up at the bottom of the shock you should have something that looks like this . . . . OK nice work, put the wheel back on, remove the axle stand and lower the car to the floor - NOW AND ONLY NOW SHOULD YOU DO THE THREE TOP MOUNT BOLTS UP - THIS ENSURES THE SHOCK IS IN THE CORRECT POSITION. Now do the other side - its exactly the same but there's not pad wear sensor wire to worry about. Once finished, put the three tabs back in that hold the trim below the windscreen in place , close the bonnet and skip around your drive at your pure awesomeness. Right, that's it - hope this helps. If you've got any smart tips or questions, just let me know.
