Showing results for tags 'snow foam'.
Found 2 results
  1. Just a quick question on Valet Pro Snow Foam. Was looking to buy some as the sample size Magifoam I got with my lance is nearly empty. Just to make things more confusing, I notice there are 3 different types, Ph Neutral Snow Foam Advanced Neutral Snow Foam Snow Foam Combo 2 Now the magifoam itself was ok, on a filthy car it left it with a reasonable shine from snowfoaming alone, but understandly didn't shift much muck. Wanted to try the Valet Pro stuff, thought it would be a simple purchase but obviously not. Can anyone advise on the differences to the above? Is there any value in paying extra for the advanced over the standard? Thanks in advance
  2. Hello people, After some help with cleaning. I live in a block of flats which has an underground car park where my R is parked. It has a water tap (really high mains pressure), but no power points anywhere to plug in a pressure washer. Is there anything out there that I could make up for a normal hose that would apply and rinse off snow foam? Like a higher pressure hose lance or the likes? Can't really find much online and was wondering if anyone had anything similar. Total pain in the arse to try get the car cleaned just now. Just take it to a contactless place for a snow foam and blast at the moment but I'd rather do it myself.
