Showing results for tags 'water methanol'.
Hey all, So I have an Aquamist HFS-4 system in the build queue right now, and will be installing in the next month or so. I live in the UAE where there is limited availability of knowledgeable shops to help with this kinda stuff, so wanted some guidance on config/setup. Installation will be fine - the shop doing the install is excellent and I trust them to do a good job on installation/wiring - but they specialise in JDM cars, so I don't think they'd know how to set it up right for a VAG car. Looking for some info on nozzle sizes, when to spray, failsafe calibration, and anything else that might be relevant. Some info on the car / setup / usage: - Car is a daily driver, so definitely not needing to push it to the max - Car hasn't been dyno'd in current form, but is probably ~450BHP - I run a Turbo Technics hybrid and MRC software, but low boost (1.95bar) - I'd rather not run a high meth ratio - I don't want to run the WMI system all the time, and I won't be tuning for meth / increasing boost - just want to compensate for ridiculous ambient temperature and shitty fuel quality I've heard the default setup means the car cuts boost to 1bar when the system is switched off as a failsafe, which obviously won't work for me - but want to know how to change that, or if there's an alternative failsafe setting / setup that is advisable. Appreciate any help from those who know the system well and have played around with different settings. Thanks! (PFA)
- 16 replies
