Strange Problem - Help!
Richard_m
Ever since having the GIAC High Output file the car doesn't seem to be driving properly. When accelerating (mainly full throttle) the car seems to rev slightly (around 200-500rpm) before dropping to where it was initially and then the power comes. It's mainly in the higher gears (4th-6th) above 4000rpm but sometimes happens higher up in the rev range in the lower gears. Anyone experienced this before?
th_2152C9BE-0E51-47B7-9950-23A2DADCB8A6_
Just going to get some more videos
  • Replies 15
  • Created
  • Last Reply
Top Posters In This Topic
DSG may recover better than a manual.  In fact re-reading your post I used to get this on my 6R.  Only used to happen around the 4k mark for a few hundred revs... right in the peak of the toqrue curve.  I was only on Stage2 DSG map and did mention it to Statllers, we expected it was a little slip - never really caused me any issues and I never got round to trying out the Stage3 map to see if it cured the issue.
Try and avoid full throttle at its peak - say 4k, if you full throttle from say 3.5k does it do it?
Edit: just seen the video's. It looks similar but not the same, but then you have Stage3 as mentioned above and not Stage2.
Mine used to do this at Stage 2+ ECU. I found that the Stage 3 DSG map with increased clamping pressures helped, but I never ran the HO GIAC file. Giving it full throttle after peak torque avoids it. I found progressing through the gears from 1st or 2nd was fine and the clutches gripped fine. However, if I was in say 4th or 5th at 3.5-4.5k and booted it I saw the same thing - the rev needle wobbled before 'gripping'. I found dropping gears to get the revs above 4.5k and giving it full throttle avoided the issue. I'm not sure if it is the clutches or not.
I've actually found the way torque is delivered at Stage 3 easier to work with.
In this video you can hear what sounds like air being chopped (hard to explain what I mean but you may understand if you can hear it in the video) which makes me think it could be down to a loose clip on air intake, intercooler pipes, turbo pipes etc. Or possibly a hole in one of the before mentioned pipes. Could this cause the boost pressure to fluctuate and potentially cause the revving problem?
th_A79AB512-2C0C-487C-AAB4-9403CAC9045E_
Thanks for the reply, I guess it could be slight clutch slip but I'm no expert on cars. Hopefully John or Steve may have an idea.
I tend to try and avoid going full throttle at low rpm and usually drop down a gear or two. That does sound similar to what I'm getting at 3500-4500rpm although it seems to do it higher up in the rev range if going full throttle through the gears.
Steve at Statller reckons it could be slight clutch slip so it's looking like we might have to reign in the torque or increase the DSG clamping pressure further. Either that or we start a group buy on the Dodson clutch packs haha ;)
Just out of interest, were you running a 3 inch or a 3 and a half inch downpipe when you were getting slip?
Sounds like clutch slip ... I see your DSG and running Stage3 DSG but still could be.
