Wylie Coyote Posted November 25, 2010 Report Share Posted November 25, 2010 Had a search but it didn't seem to show up this issue. Car is parked in a secure multi-story while I'm in work. Came back this evening to find that both windows were open by 2-3 inches! No evidence of an attempt to break in thank goodness. Has anyone else experienced this? It's the first time this has ever happened but it's rocked me a bit :-& Any ideas? If not I'll get on to the dealer to check everything out. Cheers Quote Link to comment Share on other sites More sharing options...
Danno Posted November 25, 2010 Report Share Posted November 25, 2010 It may be something to do with the remote. You know if you press the open button and hold it down the windows go down too. Same in reverse. Perhaps it was something to do with that??? Quote Link to comment Share on other sites More sharing options...
Wylie Coyote Posted November 25, 2010 Author Report Share Posted November 25, 2010 Could be Danno, maybe I kept the open button depressed too long. I think I'll keep an eye on things - it's just weird though 8-| Thanks for your input. Quote Link to comment Share on other sites More sharing options...
Danno Posted November 25, 2010 Report Share Posted November 25, 2010 Try it out and you'll find out how long you have to depress the button. Actually, i wish when the windows were open, that by just locking the car remotely would wind them up, but you have hold the button down for ages!! Must be to protect kids and dogs... Quote Link to comment Share on other sites More sharing options...
harryhackenbacker Posted November 26, 2010 Report Share Posted November 26, 2010 Had this happen on my mk5 Gti and on my current 32 the gti used to open it's windows fully now and then the dealer re set the electrics and never happened again. As for the 32 it seems to use the safety mechanism that is for window obstuctions (where it stops the window from going up and retracts a little bit ) for no apparent reason sometimes when the remote has been held in the open doors position which will then lower the windows fully,or hold the remote closed switch,then closes the windows and sun roof as well. It may be an Electrical Glitch or could be radio interference from somewhere else if it happens 2 or three times get it re set at the dealer or you could try running the full sequence of the windows from the door switches and see if it re sets ok. It usually does it after any window motion in connection with the remote Quote Link to comment Share on other sites More sharing options...
Guest p3eps Posted November 27, 2010 Report Share Posted November 27, 2010 I had this happen yesterday too! Bearing in mind I'm in Aberdeen and it'd been snowing all night, the results weren't pretty. I walked over to the car in my car park, and realised my drivers window was open 2-3 inches. I carefully scraped the snow around it off, and opened the door. I then realised the passanger one was the same - but thankfully the wind had been blowing from the passanger side - so the drivers seat was pretty clear. I scraped the whole window and surrounds clear, and then put the window up. The whole inside of the door was full of snow, so I cleared that up, but my concern was the switches on the door. I then cleared my passanger door and put that window up - and then cleared all the snow off the seat and footwell. I picked as much snow as I could out of the window switches, and then got some kitchen towels and left them in the switches to absorb the remaining bits of ice as they melted. I guess the switches must be fairly waterproof anyway as they get soaked everytime you open the door in the rain. Last night I checked the car at 10pm and the windows were still up! I hope they're still up when I go out today as its been snowing all night again :-\ I did assume that I'd just had the button pressed in my trousers - but I couldn't see how as my house is quite far away from the car! Quote Link to comment Share on other sites More sharing options...
Danno Posted November 27, 2010 Report Share Posted November 27, 2010 WTF?!!!! God I hope this isn't a fault that's developing on the R!!! That would be a real security risk, not the mention the damage that water/snow does.. You'll be having some serious windscreen misting this winter after that mate. I have serious misting on mine and I've been really careful not to let any water in, it's really annoying and not what I'd expect on a new quality car. I even had ice on the inside the other day!!!! Quote Link to comment Share on other sites More sharing options...
Guest p3eps Posted November 27, 2010 Report Share Posted November 27, 2010 I had a quick look this morning - my windows are still up!! I got the majority of the snow out whilst it was still solid - so there shouldn't be too much water left over. No more than taking a couple of passengers with snowy feet!! Quote Link to comment Share on other sites More sharing options...
Sandok Posted November 27, 2010 Report Share Posted November 27, 2010 I tried seeing the max distance the remote works from the car, easily 300-400 meters so be wary... Snowed a TON today and last night, but the windows are closed on mine... Hoepfully this isn't a future problem! > Quote Link to comment Share on other sites More sharing options...
Wylie Coyote Posted November 27, 2010 Author Report Share Posted November 27, 2010 That's weird that I am not the only one....it's the security issue that concerns me more than possible rain/snow ingress. As there has been no hint of an issue up until now, I assumed that I had pressed the remote somehow to cause it. If it happens again I'll be straight up the dealers to get it hooked up to VAG com. 8-| Quote Link to comment Share on other sites More sharing options...
Guest p3eps Posted November 27, 2010 Report Share Posted November 27, 2010 That's weird that I am not the only one....it's the security issue that concerns me more than possible rain/snow ingress. As there has been no hint of an issue up until now, I assumed that I had pressed the remote somehow to cause it. If it happens again I'll be straight up the dealers to get it hooked up to VAG com. 8-| I've had a search around and apparently its a known fault and happens with all models of VW. I'll try my VagCom tomorrow, but I don't know if it will prove anything. I read something about them changing the convenience module. I'll be straight on the phone to the dealer on Monday getting it booked in as I can't risk this happening again. I can hopefully get my dodgy whistling window seals changed at the same time. I put a pot of moisture crystals on my passenger seat at about 5pm, so hopefully they'll absorb any excess condensation that would turn to ice on the inside. Quote Link to comment Share on other sites More sharing options...
Wylie Coyote Posted November 28, 2010 Author Report Share Posted November 28, 2010 Interesting - let me know how you get on and if the dealer knows anything about it... If I need to take it in, mine will need the drivers door tightening as I can hear a fair bit of road noise. Quote Link to comment Share on other sites More sharing options...
Sandok Posted January 19, 2011 Report Share Posted January 19, 2011 Sorry to bring this back from the dead but... yay, it happened to me too :'( p3eps, did your VagCom say anything? I hope it doesn't happen again, luckily we have been having dry nights, but still! Quote Link to comment Share on other sites More sharing options...
Guest p3eps Posted January 19, 2011 Report Share Posted January 19, 2011 To be honest, I haven't checked! It hasn't happened again since, and I'd kind of forgotten about it. My dealer told me to come up and they'd fix it - as it was just a software problem. Quote Link to comment Share on other sites More sharing options...
KevG123 Posted August 10, 2011 Report Share Posted August 10, 2011 This happened to me after getting back to the carpark after my first day at work since getting the car Blimey, what with the deadlock message as well, anything else I should know about ! 8-| Quote Link to comment Share on other sites More sharing options...
