rsul18
Junior Members
Everything posted by rsul18
  1. Thats perfect i think. What is it like in eco? Is it bearable when cruising around lowe speeds or on motorway?
  2. Got the socprion decat, and going for a low drone res delete pipe. Should be okay wit this i hope
  3. Do you have any sound clips off both? I just want to be sure in Eco it is not too bad at all.
  4. Hi all, Car is booked in for a stage 2 in a couple weeks from now. Currently got the Scorpion decat downpipe going in. My car is pre opf, so i am wondering if i should leave the resonator in. Anyone had any experience with decat and res delete and got any clips. want to know what its like in eco mainly as i want to be able to tone it down when i want to. thanks
  5. Ayy can't wait. Just want to be sure i'm fine without the intake kit as i am going for the IC, as at the minute it is one or the other.
  6. Rick is able to do the 'pikey mod'? I didn't think to ask as I believe he doesn't fit any hardware? I can imagine that induction noise sounds amazing
  7. How is the car running, and what power are you at?
  8. Does that snow grate removal NEED to be done? Also, how easy is it to do as my hardware is going to be fitted elsewhere so need to see if they can proivde this mod.
  9. Hi all, Anyone running a stage 2 on a stock intake. Spoken with Ricky at unicorn who suggests it will be fine with just a turbo elbow, IC and downpipe.
  10. Any recommendations for any tuners in the north west UK? Im aware of Unicorn at the minute who I have enquired about. Just wanting to look at others just to see whats the best option for me. Anyone recommend Vudu performance of anything of the shelf or had any experience? Thanks!!!
  11. Nice, do you have any sound clips of your setup? I have read in to the 'pikey' r600 mod, looks good and a cheaper option out of it. I should be fine for a stage 1+ with these mods then, sounds like it will get me the best figures without changing too much hardware.
  12. Is it that bad without the anti drone res?
  13. I feel like that sound combo will sound a lot better than the decat which comes across just way too loud and i'm not a fan of the tone personally. Are you running the Sports cat and res setup yourself? For the intake mod... would a panel filter upgrade do? I will be going custom so going to ask my tuner to try improve throttle response. Anything else i should look into?
  14. I am probably going to go ahead with the DP as i want it for sound purposes too, as i will run a sports cat with a res delete. I'm more than likely going to be running with Sports Cat DP, Airtec Intercooler, Turbo Elbow + Hose, and some sort of airbox mod.
  15. Ive been looking around at tuners. Heard Rick at unicorn is one of the best up north near where i am. However he doesn’t offer hardware fitting so the costs would add up if i go elsewhere for fitting then unicorn for the tune. Are there any limitations on power with a sports cat compared to the decat? I’m just unsure on the sound from the decat as on a stock catback i don’t think they sound that good. At the moment i’m looking at a scorpion sports cat, r600 intake, turbo elbow and hose and possibly a turbo muffler delete. If i was to add the intercooler then i’m guessing it would just be a full stage 2 at this point.. but trying to get a stage 1+ custom tune and get to that 400
  16. Hi all, Looking to get my car mapped at the start of summer, currently running stock. Been looking into hardware options but unsure what to go for. Ideally i want around 400bhp and probably go for a sports cat downpipe or decat but am unsure. Any hardware recommendations that will push up figures to 400?
  17. Finally, all sorted. OEM pads seem to have sorted the issue, as they already come with the new clips, whereas Brembo don't apparently, which is weird. No sound at all anymore, and brakes feel very good.
  18. The tab was 'put back into place' apparently, however it is that damaged they have said it is worth just buying new VW pads which come with the new clips. The sound is still there after trying to put the clip in position. . Also, the £300 charge was excluding labour, funny enough I spoke with VW and managed to buy the same parts of them for £182. Found a different garage to fit these new genuine parts so hopefully that's the end of this brake pad issue!
  19. Update: Just got it checked from a VAG specialist near me. They have found one of the retaining clips to be 'bent' which is causing the pad to slide up and down the carrier. Been recommended to go for OEM pads but quoted at £300? Any other options I have?
  20. Unfortunately i am unable to PM yet as i do not have enough posts. You could always send me an email i do not mind... sully.76@icloud.com
  21. Ahh shame. Wanted to hear what the setup was like. Thats fine mate
  22. Is there an instagram post or anything you have?
  23. Ahhh thats a shame. I mean if theres any other platforms you use can take it on that?
  24. So just got new Brembo brake pads and disks fitted to my 7.5 R. Noticed since then, there has been a clunk sound coming from the right pad, when going over bumps or reversing and turning at low speeds. I have read this could be the pad clunking against the calliper due to the size... any ideas or resolutions?
