Showing results for tags 'front assist fault'.
  1. Had my new 7.5 delivered on thursday, drove it for the first time on Friday and got an amber warning that the Front Assist is disabled!! Can't clear the three faults that VCDS is showing, these being - Mileage: 234km-145mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb Part No SW: 5Q0 907 572 J HW: 3QF 907 572 Component: ACC BOSCH MQB H10 0654 Coding: 3300678159FFC728949C810580400600000000000000000000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_ACCBOSCHVW416 002006 ROD: EV_ACCBOSCHVW416.rod VCID: 3E754E5BA15F3DB6A3-806A 3 Faults Found: 0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned C1103 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 4 Mileage: 33 km Date: 2017.12.08 Time: 10:14:06 Dynamic environmental data: 02 8D Control Module temperature: 31 °C Voltage terminal 15: 14.4 V Velocity_vehicle_reference: 23.11 m/s Longitudinal_acceleration_vehicle_reference: 0.05 m/s² Status_ACC_System: ACC_Off_MainSwitch_Off 0836 - Databus U1123 00 [008] - Received Error Message Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 92 Reset counter: 44 Mileage: 120 km Date: 2017.12.08 Time: 11:48:13 Dynamic environmental data: 02 8D Control Module temperature: 30 °C Voltage terminal 15: 12.6 V Velocity_vehicle_reference: 0.00 m/s Longitudinal_acceleration_vehicle_reference: -0.00 m/s² Status_ACC_System: ACC_Off_MainSwitch_Off 2068 - Databus U1123 00 [008] - Received Error Message Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 45 Mileage: 224 km Date: 2017.12.08 Time: 15:05:52 Dynamic environmental data: 02 8D Control Module temperature: 29 °C Voltage terminal 15: 13.1 V Velocity_vehicle_reference: 0.00 m/s Longitudinal_acceleration_vehicle_reference: -0.00 m/s² Status_ACC_System: ACC_reversible_error ------------------------------------------------------------------------------------------------------- The car is booked into my local Stealers on Monday, so will report back. I have had a look through the gap behind the VW badge and can't see anything dislodged. It hasn't had any snow, ice or dried spray build up on the sensor. Has anyone had a similar issue? Is it easy to gain access to behind the badge? Is there just the one sensor in the badge? I'd rather try resolve myself first as I've got some long journeys before Monday comes around. Any advice greatly welcome.
